Question about Sys 4.1 pc. 140 Watt Speaker Computer Speakers
Hello, I dont have any sound on my speaker.When I run dxdiag I found this "DirectSound test results: Failure at step 19 (User verification of software): HRESULT = 0x00000000 (error code)".When I checked in my Device Manger is there is a yellow mark in PCI simple communication controller.There is distorted voice is coming through the speaker.I am using windows xp,intel p4,256 MB,80 GB. Pls advice me ASAP. your help will be appreciated.
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Apr 03, 2011
4 Suggested Answers
SOURCE: DirectSound test results: Failure at step 19 (User
Please follow the steps below,
1. Start / Settings / Control Panel / System / Hardware / Device Manager
2. Scroll to bottom of list, click on System devices
3. Scroll down to Microsoft UAA Bus Driver for High Definition Audio
4. Right click on "Microsoft UAA Bus Driver" and select Disable - screen will refresh
5. Right click on "Microsoft UAA Bus Driver" and select Uninstall - screen will refresh
6. Reinstall the RealTek HD Audio
Problem with the Xp SP3 high defination
Regards,
Posted on Feb 11, 2010
SOURCE: DirectSound test results: Failure at step 19 (User verification of software): HRESULT = 0x00000000 (error code)
help me fix it! (sound cans be displayed)
Posted on Oct 14, 2008
  • 5 Answers
try 56 divide it 16234978=0.0000034
Posted on Apr 06, 2010
Run the dell diagnostics on the sound card .
1. Restart your computer
2. tap on the f12 key slowly five times
3. select the option Boot to utility partision or diagnostics
4.select dell 32 bit diagnostics
5. Select customer test and test sound
If the test pass, try system restore , probably the problem is with the sound card drivers
if the sound test fails , shutdown the system again and remove the cmos battery and start the system without it once.Check sound again .
Thanks
proton
Apr 28, 2009 | Creative Labs SoundBlaster Audigy 2 ZS...
Sound card installation problem
You download the AC97 codecs from Realtek and retry your install. You have a choice of two - standard AC97 (try this first) or AC97 HD, both are available from the same link and one or the other should be compatible with your device.
Post your results here, especially if this doesn't fix your problem.
Apr 04, 2009 | Computers & Internet
Regards,
Mar 04, 2009 | Sys 4.1 pc. 140 Watt Speaker Computer...
It sounds like you may need to Update the Drivers. If not you may have a Bad Sound Card.
Jan 22, 2009 | Computers & Internet
No sound!
Did you get the driver from HP? Here is a link to install (or download) the driver for your system. It may be beneficial to download it to your computer in case you need it again.
SR1603WM Audio Driver
Dec 22, 2008 | Computers & Internet
Sys 4.1 pc. 140 Watt Speaker Computer Speakers Logo
335 people viewed this question
Top Sys Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sys Audio Player and Recorder Expert? Answer questions, earn points and help others
