Question about Minn Kota iPilot for Riptide SP ()
I have a new (reconditioned) Terrova with I Pilot bought from Motor Clinic in Bloomington, MN Foot pedal works fine but remote just shows flashing "F". I have done the Learn function several times - get four quick beeps and still the flashing F. Have delployed and stowed motor seveal times hoping powering on/off would help - didn't. Was trying inside garage but moved out doors incase GPS needed signal - still no luck. Help
  • 3 Answers
SOURCE: Prop spins slow on any speed on the foot pedal
There is a good chance that the control board is bad. This is a common problem with these units. I have replaced my control board twice. When the control board goes out, some function of the unit will not work correctly while other functions work fine. The first time mine went out, the prop motor would not work. The last time the board went out, the unit would only steer right.
Posted on Jun 04, 2009
  • 157 Answers
SOURCE: minn kota problem
Hello Jim. You have lost your power some where. Start with the wire & terminal connections to the battery. Open the bottom of the foot pedal and check the wiring connections there. Note be very careful here for you have the battery still connected. You may have a fuse in line some where blown. You can check for voltage with a VOM(volt meter) on the wire terminals. Good Luck.
Posted on Oct 02, 2008
  • 3 Answers
SOURCE: Minn Kota power drive trolling motor will not
There is a good chance that he control board is bad. This is a common problem with these units. I have replaced my control board twice.. When the control board goes out, the some function of the unit will not work correctly while other functions work fine. The first time mine went out, the prop motor would not work. The last time the board went out, the unit would only steer right.
tbreeze47
  • 3083 Answers
SOURCE: model sp 70. When
The co-pilot control could be faulty, supplying full voltage to the motor with reverse polarity. Try to check, or have someone check the voltage out of the control to see if it's reversed. If it is, the control is bad. The other scenario might be a connector that came loose, and was accidentally connected with reverse polarity, but that's a long shot and guess. Since there is no control over the voltage, I would suspect the co-pilot remote circuit or control first. That seems like it would be the most likely suspect culprit. Good luck, and hope this helps.
Posted on May 05, 2010
micromatikal
  • 2777 Answers
SOURCE: I have a copilot w/
Yes this sounds like the remote add-on is having issues, or the receiver portion of the remote add-on at least. Hopefully it is still under warranty and you can get it replaced at no cost.
Thanks
Tim
Posted on Oct 11, 2010
Home Audio system MS9825 The remote became corroded and we ordered a new reconditioned one which still doesn't work. Can you help or can we order a new remote from you?
You bought a "new" reconditioned remote and it doesn't work?
You should send it back for exchange or refund.
I haven't encountered reconditioned remotes before. I doubt there is much profit in reconditioning remote controls when new dedicated replacements are available at such reasonable prices. Often new original remotes aren't expensive if they are available.
Feb 04, 2018 | The Audio Players & Recorders
Machine ran on when pedal when released, pedal now no longer works and machine wont sewing more than one layer of fabric without getting jammed
How are you making it run now since the pedal doesn't work?
You probably should take it to a repairman/shop. When this happens, sometimes the pedal is shorting out and it kills the pedal and you will need to buy a new pedal. When it ran by itself, it might have either gotten a piece of material or thread caught in the shuttle or it might have knocked the machine "out of time" and you will need to have it put back in time so that it will run properly again. I don't know what the prices are in your area but I would imagine that it will all run about $125. Sometimes you can get a used pedal off ebay (check to make sure that the configuration of the plug is the same). Good Luck.
Mar 12, 2015 | Janome DC3050 Computerized Sewing Machine...
Does not run. Where can I find fuse schematic #240
A circuit breaker is recommended but not included. Do you have a circuit breaker? If there is a fuse it should be inline with the battery wire.
See link below.
Fuse and Circuit Breaker Overview
Jul 30, 2014 | Minn Kota Terrova 80/US2/i-Pilot w/Foot...
Minn kota
I have a terrova with i pilot same thing happened found out it was the remote, if thats not it then you will more than likely have to send it in for repair.
May 13, 2014 | Minn Kota Riptide Sp Saltwater 70 Bow...
How do you reset remote for w75 wireless trolling motor
Its very easy:
Reprogramming the Wireless Foot Pedal or RemoteNOTE: This activation procedure applies to the foot pedal and remote.
IMPORTANT: To activate multiple foot pedals or remotes, the motor must be unplugged from the power source and then plugged
back into the power source between activating each control device.
1. Unplug the battery cables from the power source. Wait 30 seconds and then plug the motor into the power source.
2. In less than ten seconds, press and hold the "+" and "-" buttons on either the handheld remote or the foot pedal controller
simultaneously.
May 07, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
I have a Terrova 101 w/ auto pilot. The unit is
Your batteries are possibly low on voltage. Have you checked that?
Aug 31, 2017 | Minn Kota Terrova 80 w AutoPilot and US2...
White 1600 SpeedyLock. Power, but foot pedal won't engage. Took foot pedal apart, mechanically looks fine-- computer board in there. Do I need a new foot pedal?
When stepping on the foot control, does the motor hum or anything? Or is dead silent? If it sounds like it's trying to do something, the serger probably needs to be serviced. If it's silent, you probably need a new foot control.
Feb 22, 2010 | White Sewing Speedylock 1600 Mechanical...
My LG37LC2D-UD's remote control stopped working.I tested it on another exact same tv and it worked fine. That set's remote would not work my tv. I now know the ir receiver on my set is faulty. I found a...
For Eastern US customers, LG parts distributor is:
Vance Baldwin Electronics
1655 Lakes Parkway NW
Lawrenceville, GA 30043-5858
P (954) 723-9191 (800) 432-8542
F (678) 377-7599
You can also check if it is in-stock in this address:
9201 Penn Ave S.
Suite 40 Bloomington, MN 55431 Work (952) 881-6492 Toll Free (877) 881-6492 Fax (952) 884-5028
Jan 01, 2010 | LG 37LC2D Television
Minn Kota iPilot for Riptide SP () Logo
527 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
