Question about Sewing Machines
Kenmore 17922 sewing machine belt timing
I just changed the belt on the lower shaft of the sewing machine but now the needle and bobbin are out of timing...Are there timing marks anywhere?
  • molly1221 Mar 16, 2009
    kenmore model 1207 needle jams in down position, works if I take bobbin case out.....it doesn't have the original bobbin case, but one that's sort-of backwards.... but I don't think that's the issue. How do I go about fixing the timing????
SOURCE:
snakehead
  • 1074 Answers
SOURCE: Kenmore Model 16221 sewing machine
your machine needs to be clean take it down clean and oil it up and you will have that problem no more.good luck.
Posted on Jun 04, 2007
  • 15 Answers
SOURCE: kenmore 12 stitch sewing machine-wont sew
repair and parts it's all here just open this link....
all the advantages is here , hustle free, saves time and money ...
www.myrepairmaster.com.
Posted on Dec 10, 2007
RickE1
  • 202 Answers
SOURCE: Kenmore sewing ma. model #17922 has a differnet model # for parts
Hi. The issue is probably because 17922 is only part of the model number. Your missing the prefex 385 which makes this model number actually a 385.17922. All Kenmores have a prefex before the actual model number. Other prefixes were 117 , 158 .
Hope this helps .
Rick
Posted on Jan 21, 2009
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
  • 5 Answers
SOURCE: replace a motor belt for sewing machine
The top tension is dependent not just on the tension dial, but also on the little disks that you go through to thread the machine. If it is not threaded correctly, you will get bunching underneath. Sometimes I just have to rethread the machine-- when you get to the disks- hold the thread taut and push it through the disks before going up to the arm part. Here is a threading picture I found- but it doesn't point out the disks too much. Once the machine is stitching nicely, then the tension dial can be used to flatten out the stitches.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_900_futura_threading.htm
Posted on Mar 14, 2009
I have a Kenmore confidence stylist sewing machine that makres a clunking sound at times. Also it doesnt feed at times and gets tangled in reverse.Other than that it is a great machine lol,
indications are a loose item ( bobbin holder on shaft, loose shaft) or interference making the shaft move sideways ( cotton , lint around shaft)
the problem is most likely causing an alteration of the needle /hook timing of the needle / hook proximity
if under warranty have it checked and adjusted
If not have a sewing machine mechanic check it out
Apr 11, 2018 | Kenmore Sewing Machines
Parts Diagram For Needle Shaft.
send ur exact model and brand name ..will get ur schematic diagram soon
Sep 20, 2008 | New Home L-373 Mechanical Sewing Machine
Kenmore sewing maching model 17922 seizing up. I have oiled it and cleaned it but it still will not work. Suggestions? It was working fine, then just stopped.
Depends with what and where it was oiled. Use only fresh good quality sewing machine oil--NOT 3-in-1, WD-40, cooking oil, or grandma's old stinky brown sewing machine oil.
When a machine has seized, I prefer using liquid Tri-Flow Synthetic Lube (hardware store or bike shop). Open the top, side over the needle bar, and the bobbin area. Gently wiggle the handwheel and apply 1-2 drops each place where metal rubs on metal. Do NOT oil belts, synthetic gears, cams. Then direct hot air from a handheld hairdryer into the internal mechanisam. Get the metal parts hot. If it still doesn't move freely, repeat. Avoid over oiling as the result is you will be spending a lot of time mopping up the excess.
In the future, oil the shuttle/hook every 8 hours of sewing, do a light all-over oiling (as described above) every 40 hours of sewing, or every six months if the machine is in storage or not in regular use.
Oct 23, 2016 | Kenmore Sewing Machines
Code 88 starts flashing as well as all the stitching lights on the panel when I try to thread the bobbin. I can sew, that is NOT the problem, threading the bobbin is. What is Code 88? I am not interested...
Turn your machine off and leave it off. Remove all bobbins - in the machine & from the pin. Remove all thread - from threaded machine and bobbin thread path. Clip the machine thread at the spool and pull the needle thread towards yourself. Clip bobbin thread at spool and close to bobbin, then pull towards you through thread guides. This keeps the tension where it belongs. Move the bobbin winding shaft from normal sewing back to winding bobbin a couple times. It should click in place when moved to the winding position. Check to see if there is any thread that has slipped under the bottom of the bobbin and wound itself around & under the bottom of the shaft. Carefully unwind to clear. If the shaft does not easily move back to the sewing position it is probably stuck in the winding position. Don't force it, but try to get it out of the winding position. Leave it to the left in the normal sewing position (unclicked). Check to see if there is any thread caught anywhere along the path from spool to the winding pin. Pay close attention to the first thread guide and the two discs the thread slips between that control tension. Hand wind the wheel on the right towards you to raise and lower the needle a couple of times. Stop with needle in highest position. Do NOT wind hand wheel backwards (away from you). Make sure the bobbin pin is not in the winding position. Now turn on your machine. Needle should jump to default position. Move the stitch length and stitch width guides to the far right, then far left, to attain the green lights. Press the reverse stitch button to raise lower and raise the needle. It will stop in the highest position. If you still have the error code - make sure the bobbin winding pin is NOT in the winding position. Remove the needle. Lower the presser foot and run the machine without any thread a bit. If the needle bar does not go up and down most likely the bobbin pin is stuck in the winding position. If the code has cleared use your manual to carefully wind a new bobbin. Make sure you are using a 15J bobbin which this machine requires. It will not work with just any bobbin. Next, raise the presser foot then carefully thread the machine. If you don't have a manual you can download one from the Singer website. You might consider cleaning the entire machine paying special attention to the hook area and feed dogs while the power is off. If you find a lot of lint do this more frequently to prevent buildup. Take special care when replacing the bobbin care. Hope this helps. If not call Singer. It may take some time but you should be able to reach someone to help you troubleshoot. If this is an older machine I recommend taking it for repair yourself instead of sending to Singer
reference: http://www.amazon.com/Singer-7466-Electronic-Sewing-Machine/forum/Fx3BSOY0VA78VQ4/-/1?_encoding=UTF8&asin=B000B91B3K
Mar 28, 2015 | Sewing Machines
Skipping stitches on bobbin thread Juki DDL555-5. any suggestions?
sounds like u have the wrong needle or machine is out of time. if its a needle feed machine u might have the wrong bobbin case. try lowering the needle slightly. machine is easy to time. theres a mark on the needle bar which u align with the bottom of the bar guide then loosen the hook (3 screws) and move hook till it just starts to meet the needle. careful of side to side movment. bobbin case has to remain in the finger.
Mar 27, 2014 | Juki Sewing Machines
LOWER BOBBIN BINDING UP
Readjust the needle timing and check the thread tensions top and bottom.
Jun 09, 2013 | Kenmore Sewing Machines
Bobbin is not working
try rethreading the machine top & bobbin
make sure the bobbin is not warped
change the needle
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
if these suggestion don't help then the machine may need to be
checked to see if it's out of time
Jun 06, 2012 | Kenmore Sewing Machines
How to check timing on pe180d embroidery machine
In case of adjusting sewing machine timing, there are twomain parts that you should follow.To adjust the hook needle timing on the rotary hook, first,remove the bobbin, bobbin carrier, and covers so you can see the movement ofthe hook. This may involve removing the needle plate for top loadingassemblies, or removing the hook cap from the front of the machine. Itoften requires the removal of the lower covers to reach the componentparts. Adjust as needed when doing sewing machine repair.Set the machine to a straight stitch at the defaultposition. Different models have different default positions including themost common far left and center positions. If no problems are perceivedin needle bar positioning, the default position will suffice. If thereare needle bar position issues, these need to be adjusted prior to adjustingthe timing. Follow proper sewing machine repair procedures.Rotate the hand wheel toward youuntil you see the needle reach its lowest position and begin its rise. Now lookfor the point of the hook as you continue rotating the hand wheel. Thepoint of the hook should strike inside the needle scarf above the needleby about 0.5mm. Sewing machine repair is vital for smooth operations.Check to see if the hook fails topick up the thread. Double check the needle bar positioning including thehook needle spacing. If these are appropriate and the point of the needlestill fails to pick up the loop thread, proceed to adjust the timing of thehook. Maintain regular sewing machine repair. Look for the lower drivemechanism. It may be a lower shaft with gears on either end. If this isthe case, look to the right end of the shaft for a gear with adjusting setscrews. Loosen and manually adjust the position of the hook. Tightly hold thehand wheel while turning the drive shaft to set the proper position. Retighten adjusting screws. Some models have timing beltsthat control the timing of the sewing machine. Look for a belt connectedon each with to drive gears. Look for work cogs on the belt. Inmost cases, you can reset the timing belt, without replacing it. If,however, the belt requires replacement you will need to do so. Loosen the drive mechanism on the right side to free the movement of the belt.Manually adjust the position of the hook to the needle and re-tighten set screws. This knowledge is vital for effective sewing machine repair.Once the timing has been reset,conduct thorough test sewing on the sewing machine to make sure everything isworking properly.Hope this will help you. Good Luck.
Oct 16, 2011 | Brother Disney PE-180D Computerized Sewing...
I've removed the Timing Belt on my Wifes 3820
adjust your tension, change your needle and adjust also your rotating bar.
Mar 27, 2010 | Kenmore Drop-In Bobbin 16231 Mechanical...
Open Questions:
Sewing Machines Logo
215 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
