Question about Hoover Washing Machines
Hoover Washing Machine Door wont open. Please help the door opener feels slack! How do I get it to open. Its a hoover nextra. Thanks Lisa
  • 3,230 Answers
Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Posted on May 19, 2009
The lock on my Hoover Nextra front loader washing machine snapped off when attempting to open the door on completion of wash. Can this be repaired
if it.s the inner door lock catch, that attached to the front door handle
yes it can be replaced, take photo and model number of machine
order from washing machine repair shop. or download manual from malefactors site for correct part number, ,or if you need a repair engineer ring for a quote first, how much will it cost to replace my hoover inner front door catch, good luck
Oct 05, 2016 | Hoover AAA160 Front Load Washer
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
After a power cut my washer wont work the door security light just keeps flashing! Model Hoover Vision HD
Ihave a Hoover Vision HD washing machine and the "Door Security" light keeps flashing. I have looked in the manual and it says the door is not properly shut. However the door is correctly shut and as a result the machine will not operate . The door will open or close but will not start a cycle to wash. Any suggestions please????
Apr 24, 2011 | Hoover Washing Machines
Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 18, 2010 | Hoover Nextra HNF 2137 Front Load Washer
I need to fix the handle of a hoover washing machine hnf3157.I have the kit but can work out what way round the spring goes. Please help. Thank you Silvia
the hook faces away from the center of the door.
The handle goes around that.
The spring goes around both, on the inside of the hook, facing the center of the door.
Jan 16, 2010 | Hoover Nextra HNF 3157 Front Load Washer
HELLO , I HAVE A HOOVER NEXTRA MEGA LOAD WASHING
Hi John,
it has been a while since i worked on one of these, but I might be able to talk you through it, first make sure you have the correct bits to replace. i.e. the inside of the handle and the latch match the same that is on that you can see before you go any further.
using a torx size 15 I think remove the two screws on the door hindge, and then remove door by pushing up by a 1/4" then the hindge should pull away from the machine. using a torx size 10 then proceed to remove the four screws from the inside of the door frame, ease the door pannels appart and the glass bowl and lock should be exposed. there should be a further two screws holding the latch in place, just be careful when taken these out as they may be under load from a spring, note the positions of the latch and replace all back in reverse order.
Cheers,
Sep 07, 2009 | Hoover AAA160 Front Load Washer
Hoover washing machine door handle
if any one is stuck fitting a door handle to a hoover washing machine HNL 6146 nextra series then please email me johndgill49@hotmail.com
Aug 29, 2009 | Indesit W 123 Front Load Washer
Hoover 1300 washing machine door wont open
Hi.
The door will not normally open if there is water left in the m.c. check pump, and make sure the belt is o/k, as some hoovers do not let you open the door if the belt has come off. Please leave feedback.
Thanks.
Nov 25, 2008 | Hoover Washing Machines
Washing Machines Logo
774 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
