Hi. I have an OKI C3300 printer, which is not printing. Yesterday the error was "Black Drum cartridge Life", but this morning it says the error is Printer Connection Error". The Okidata/StatusMonitor says "Online" and "Drum Life (Black)". Just a little bit confusing, but can you help me get it printing again? Ted
  • 2 more comments
  • Ted Brown Apr 04, 2011
    Hi
    The answer to your question is no, I have not replaced the toner.
    But I have tried printing again, which gave me a message box, with the message
    "Black drum cartridge life." in the main window.
    The below,
    " The above warning has been issued.
    "If you want to continue printing, press the Continue button, and
    "If you want to cancel printing, press the cancel button.
    I selected Cancel, but if I had selected Continue would that have had adverse effects on the printer?
    Is the warning saying the life of the drum is at an end, or just nearing an end.
    Ted
    Hi
    I will get a new drum cartridge, but a link to a site where I could get a service manual would be very helpful.
    Thank you.
    Ted
    Looking at your response again brings up a point of confusion.
    1. What is a toner drum.
    2. What is a toner cartridge
    3. What is a drum cartridge.
    Ted
    Thank you for your assistance.
    I will know tomorrow, when I get a new drum, whether or not that is where the problem is.
    Ted
    Sergeant:
    Champion:
  • 209 Answers
Have you recently replaced the toner on this machine?
Posted on Apr 04, 2011
  • Julie Endres Apr 04, 2011
    I have had some difficulty finding that particular error code, but on my printer I get the same basic error when the print cartridge is getting low. It would probably be a good idea to buy a replacement toner drum and be prepared to replace it when the print quality decreases. As long as the printer continues to print, you should be fine. Let me know if there is anything else. I did find a service manual on the website if that would be of any help to you.
    OK, in a laser printer there is ink toner (which is approximately equivalent to a printer cartridge) and a printer drum. Both need to be replaced at different times but the ink toner is good for about 1500 pages and the drum is good for about 15,000.
    This first link explains how to replace an ink toner - which I do not think is your issue at this time based on the message you got.
    http://www.c3300.co.uk/index.asp?menumod...
    This link is to change the image drum which I believe is what needs to be done right now.
    Hope this works out for you.
Can I reset the belt
How to reset your OKI C3300 C3400 C3600 laser printers ...
? 2:40
https://www.youtube.com/watch?v=czyqKMpy2-E
Oct 6, 2014 - Uploaded by Toner Man
How to reset your OKI C3300 C3400 C3600 laser printers drum unit ... drum message you can install the chip on your drum unit and continue printing. ... Replacing the Transfer Belt on an OkiC3000 Series Printer - Duration: ...
Nov 26, 2015 | OKI C3400n Laser Printer
I HAVE C5500 OKI PRINTER AND THE ERROR SAYS REPLACE IMAGE DRUM 561:M DRUM LIFE I PUT IN NEW MAGELN AND STILL HAS THAT MESSAGE
oki printer c5950 fix new cartridge & drum coming error replace image drum 561:m drum life
Jan 15, 2013 | OKI C5500n Printer
My oki c3400 printer makes a really loud clicking noise when you first turn printer on and it cycles through, and it also does it when it cycles through printing. Any ideas what the problem could be?
My OKI C3300 was the same and an engineer found the Cyan drum was bouncing on its gears being very stiff to turn. We changed the drum but it was still the same. Changing the cartridge cured the problem, that was jamming the drum.
Mar 10, 2010 | OKI C3400n Laser Printer
How to reset black drum counter OKI C3300 ?
Buy a pack of 10 x .062A (1/16A) pico fuse RS part No 738-3062. Switch off printer. Remove the drum and toner together from the drum slot to be reset. Carefully crimp the legs of the fuse around the contact wires on the right side of the drum slot. Make sure fuse legs are making a good connection to the wires and aren't touching the frame. switch on printer and allow it to detect the absence of the drum. Switch off printer and carefully remove the now blown fuse. Re-install the toner and drum assemnbly. Drum life is now reset. see pic:
Sep 15, 2009 | OKI C3400n Laser Printer
Replaced K toner and machine is telling me there is no toner in it.
There are sensors along the inside right wall that tell the unit if there is a K cartridge inserted. Usually what happens is that due to a toner spill, the sensor LED is covered with toner and or is bad . Hence it does not see the K cartridge. This happens mostly with the black or K cartridge. Get some compressed air and lightly shoot some into the hole that corresponds to the K cardtridge. Only in the hole, do not spray the air anywhere else in the printer.
If this does not clear it up, you would need to replaced the sensor board which is held in with 12 springs!
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 03, 2009 | OKI C3200n Led Printer
OKI C3400 printer keeps saying
Okay, I had the same problem with my C3300. I phoned the people i purchased from and this is what fixed it for me:
looking directly at the printer:
-open printer
-remove drum in question (the drum is what houses the toner cartridge) in my printer it is black.
-look on the right side of the drum & there is a little (approx 5mm x 5mm) hole that has a little panel that opens- push this up to open it.
-replace drum close the top and try printing.
I had to do this 2 times before it worked, but it worked.
Jan 19, 2009 | OKI C5100n Laser Printer
Oki Printer c3200 error code
Suggest you order a black drum, which may include a black cartridge. Replacing BOTH the cartridge and the drum should solve the sensor problem, then you can swap parts to isolate where the problem is.
May 27, 2017 | OKI C3200n Led Printer
Okidata c3200 - "needs new drums" message
Check your page count, drum life on a C3200 is roughly 15000 pages. This information can be found on the information menu map.
Information Menu ecblank.gif ecblank.gif dot.gif ecblank.gif Menu Item Default Setting PRINT MENU MAP EXECUTE Prints the MenuMap (menu listing) with current settings shown. Information about your printer is also
shown at the top of each MenuMap page.
Life Expectancy ecblank.gif ecblank.gif dot.gif ecblank.gifToner Cartridge
Life expectancy approximately 1,500 pages, assuming about 5% coverage, which means that 5% of the addressable dots in an image are printed with this color of toner. See Toner Cartridge..
Image Drum
Life expectancy approximately 15,000 pages, assuming an average of 3 pages per print job. If the average print job is longer than this, the image drums could last longer, but if the average print job is shorter, then image drums will be used more quickly. See Image Drum.
Transfer Belt
Life expectancy about 50,000 letter-size pages. See Transfer Belt.
Fuser
Life expectancy about 45,000 letter-size pages. See Fuser.
Feb 11, 2008 | OKI C3200n Led Printer
OKI 5600 - Can you do a 'clean'?
Here's the 'secret' sevice manual: http://www.feedroller.com/Store/Service%20Manual/50_53_5600.PDF
I would also (very carefully) check for torn paper around the rollers of the imaging drum that might be rubbing the area.
Nov 09, 2007 | OKI C5200n Laser Printer
398 people viewed this question
k24674
