I own a Samsung HLR4667WAX/XAA DLP. The cable guy replaced the hd box and said it was the TV. The Lamp and the fan work and then go out. "Standby/Temp" in red comes on the front of the TV. There is no picture. I'd like to know what the possible issues may be? What should I look at. For example where is the color wheel? Thanks,
  • 2 more comments
  • fan4football Apr 03, 2011
    We bought the TV on January 10th 2008
    and replaced the bulb in late September 2009
    The standby/temp light is solid.
  • fan4football Apr 04, 2011
    We do not get any high squeeking sounds.
    Where is the power supply section left or right side when looking a the back.
    would the leaky capacitors be clear leakage or brownish?
    Power supply board capacitors are clean no leaks and no bulges.
    Tried to send a pic from phone but didn't work.
    I'm unable to do this, would you guessimate ( and I under stand it's a big ball park) what I might expect to pay to a repair shop with the information you have.
  • 10,594 Answers
Does Standby/ Temp light blink or solid?
How old is this tv and when did you replaced lamp last time?
These info will help me to diagnose p[problem.
Thanks.
Posted on Apr 03, 2011
  • 3 more comments
  • Shahid Electronics
    Shahid Electronics Apr 03, 2011
    Standby/Temp light is solid that means problem could be in power supply section of tv.
    Check power supply board for leaky capacitors, color wheel is located next to lamp housing in light engine and not easy to access. lots of parts will be removed from light engine to view color wheel.
    Do you get any high pitch scratching sound when turn On tv? If not then color wheel would be OK.
    Thanks.
    Shahid Electronics Apr 04, 2011
    Please check below image where power supply board location has been marked with yellow outline.
    Leaky capacitor top would be bulged/ puffed or it would have liquid at bottom where it attached with circuit board.
    Click HERE, HERE and HERE to view few examples of leaky capacitors to have better idea.
    Thanks.
    Sorry, forgot to post tv image for power supply, here it is....
    Output volts of power supply board need to be checked with multimeter to find out what output volts are missing or low than requirement and causing problem.
    How is your expertise level in electronics and can you take readings of output volts of power supply board?
    Thanks.
    I think repair would cost between $300 to $400 by local tv repair shop.
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
SMASUNG DLP 50 HDTV
defininatly the fan that cools the lamps is either not working or going out and needs replaced
Nov 12, 2007 | Samsung DLP HL-P5663W 56" TV
I have a samsung HLR6167WX/XAA dlp tv. I replaced the bulb, it worked for 1 day and didn't turn on the next day; no lights, no noises, nothing. So then I just replaced the ballast, still nothing.
Have you reset the lamp time after lamp replacement? If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2250 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 10, 2013 | Televison & Video
Samsung HLR4667WAX/XAA made a loud popping sound, picture went out and then the sound
Your lamp is burnt definitely (lamp makes that sound ,take lamp out and You will see inside lamp) no sound ,because unit goes to protect mode and shouts down power
Aug 08, 2011 | Samsung - Lamp for Samsung HLR4667WAX/XAA...
Bad picture on a Samsung DPL TV
Failing DMD board or it is also possible it has bad ribbon cables
Jan 31, 2010 | Televison & Video
Samsung Model HLR4667WAX/XAA is making a buzzing sound
It is likely the color wheel motor making noise
Check this link
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
If it helps be sure to vote/rate me Thanks
Oct 06, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP - Model HLR4667WAX/XAA
A stuck color wheel can cause this exact problem.
Feb 26, 2008 | Televison & Video
Televison & Video Logo
127 people viewed this question
Top Televison & Video Experts
Electro Med Services...
