Question about Atlas Translator Atlas 205 Connector 3 Single Pole Single Throw Switch
I have an Atlas 205 connector and the wiring digram on the package is so faint I cannot follow it. How do I wire it on my O gauge train layout to control sidings?
89 4.3 oneinjector wire no good
Well, you need to replace or reconnect this wire. It's got to be either a power wire or a ground wire. The power wire is a splice from the other injector power wires.
The power wire originates from a fuse in the fuse/relay block. It is hot with key in run or on or start.
The ground wire goes from the injector connector and into the pcm or engine computer. To check this wire: disconnect battery from car, pull the connectors from the pcm, then use an ohmmeter to check continuity of the ground wire from the injector connector to the electrical plug on the pcm. You might be able to find this ground wire terminal by following wire colors, but a wiring diagram showing the layout (pin identification) of the pcm connector will surely be helpful.
Dec 23, 2017 | Cars & Trucks
2004 f150 no left turn/break lights fuses ok runnig lights and right side works fine bulbs ok checked wiring ok do not have tow package but has trailer wiring harness.
Generally,on a Ford pickup it will be the wiring under the truck.Follow the wiring and look for corrosion.Pull on every wire at every connector,you most likely will find a wire corroded apart at a connector.Just bypass this bad connection by wiring around the connector.
Sep 28, 2017 | Cars & Trucks
What guage wire should I use to connect a train transformer to the O gauge lockons on the train track? thank, E.S
I have used 18ga lamp wire but you can use wire as thin as telephone wire. My rule of thumb is to use thicker wire (lower gauge number) the more motors on the train you are running. 20 or 22ga is generally used by most.
Jul 05, 2012 | Lionel The Polar Express Train Set
I have a 99 dodge caravan 3.3l the problem is that all the gauges will go off and sometimes wont come back on for days i did get a 1698 code
Since they come back on every now and then, I would say you have a loose wire somewhere. The circuit is probably behind the steering column. I would check all the wires and make sure none are loose. Check your grounds. The wires are black. I would replace the dash fuse also, just to be sure. You could have a wire going bad as well. You can check them with a voltage meter. If you have a question, please let me know. I am here to help. Thanks for using FixYa.
Feb 23, 2011 | 1999 Dodge Caravan
How many ways can the wires be hooked up for the fuel pump? i am not sure if i have them on correctly.does not seem to be getting fuel to the fuel rail.my wire harness has three wires to hookup on top of...
One of the wires is for the gauge sender. You can check for voltage at the ends of the wires using a test light. There should be voltage there briefly (one second or so) when you first turn on the ignition. You need to get the polarity of the pump wires correct, so you might have to try both ways and see which way it pumps fuel. Was there not an electrical connector on the tank? You could also find a wiring diagram and determine which wire is which by color, and then check the connector pin digram to determine which color wire goes to which pin.
Aug 24, 2010 | 1988 Ford Bronco
Im installing a new stereo and need a wireing digram
You'll need to determine which of these connectors match yours, then follow the appropriate diagrams:
Nissan Audio Wiring - 1985 to 1994:
Nissan Audio Wiring - 1995 onwards:
Let me know how you get on...
Cheers,
Scott
Nov 12, 2009 | 1994 Nissan Pathfinder
Cooling fan will not come on
you need to remove the connector at the fans and then take a jumper wire from batt. positive to one terminal of the connector and then a grounded jumper wire to the other...Do the fans come on? if not your fans are bad...If they do you might try a coolent temp sensor
Mar 28, 2009 | 1999 Pontiac Grand Am GT
Fuel Gauge Wiring
check this link out' it might help you: http://www.hdtalking.com/self-help-2003-night-train-fuel-gauge-wiring-instructions-preview.htm
Nov 20, 2008 | 2005 Harley Davidson FXSTB - FXSTBI Night...
Wire digram
larger gauge red is +12V for screen
larger gauge black is ground for screen
smaller gauge red is +12V lights
smaller gauge black is ground for lights
I am unsure what the purple wire is
Hope this will help you out.
Jan 12, 2008 | Liquid Video MVOHD70 Car DVD Player
Atlas Translator Atlas 205 Connector 3 Single Pole Single Throw Switch Logo
100 people viewed this question
Top Atlas Translator Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Atlas Translator Electrical Supply Expert? Answer questions, earn points and help others
