Question about KitchenAid 400 Watts KN15E1X Accolade 400 Stand Mixer
Hi, I was just using my Kitchenaid Accolade 400 (2005 vintage, model kn15e1x) to make a double batch of high-gluten bread dough, and it stopped working. I was running it for about 10 minutes (bad, I know, but the dough wasn't adequately hydrated and mixed yet) when the dough hook pinched a big ball of dough up against the side of the mixing bowl. The motor just stopped and I haven't been able to get it to work again (even after letting it cool down for a couple of hours). No motor, no noise, nothing. Did I burn out the motor, or is there a fuse in there that can be replaced? I found an owners manual and parts list (which doesn't even have the circuit board depicted) online, but I can't find a service manual. This mixer has had pretty light duty over the last 6 years, maybe used 25 times and only for dough 2 other times, so it's quite surprising that it conked out already...
  • KitchenAid Expert
  • 188 Answers
All I can do is to refer you to the Service Manual at:
Posted on May 02, 2017
5 Suggested Answers
  • 135 Answers
SOURCE: KitchenAid 600, Stand Mixer -
Hi. Stop using your mixer. If your mixer is still covered by warranty, call Kitchenaid Customer Service, they are very good with warranty repairs.
If your mixer is out of warranty, remove the silver band that surrounds the top of mixer. Remove the top cover. At the front of the mixer, locate the transmission housing which is now exposed. Examine this housing carefully for cracks. If you find cracks anywhere in this housing, you have found the under-engineered plastic transmission housing. Kitchenaid's replacement housing is made of metal. Your plastic housing has no business being in a mixer that is marketed as being able to mix bread dough. It cannot!
If you're confident that you can make the repairs yourself, go to the Kitchenaid website and download the parts drawings. Remove the Trans. housing, remove the worm gear shaft assembly which is driven by the motor.. Remove and save as much grease as necessary to thoroughly inspect the worm gear. Inspect the worm shaft bearings. Look for cracks, or missing pieces on the bearings. Look for crunched cogs on all gears. Be prepared to wait at least a month for your parts to arrive after you order them. The replacement grease should be Shell Darina 2, or Chevron FM ALC EP 2.
If you're not confident about repairing this yourself, call Kitchenaid and determine the nearest "approved" repair shop.
You may be able to pressure Kitchenaid to pay for the damaged parts in your mixer. They are still installing these plastic Trans. housing on new mixers. Insist on a metal cover when replacing. Apparently, Kitchenaid feels no shame in their manufacturing process, and will not issue a recall notice for these housings. They are substandard at best.
If you found this solution helpful, please rate it. Good luck! ricardok45.
Posted on Feb 13, 2009
  • 135 Answers
SOURCE: MIxer quit working while mixing 3 batches of oatmeal cookies
Hi. Kitchenaid's warranty is 1 year.
Most likely, the plastic transmission housing has failed, causing damage to the working parts inside your mixer. Take it to a local repair place and have them work up a quote to repair it. It will take at least a month to get the parts.
If this solution has assisted you, please rate it. ricardok45
Posted on Mar 24, 2009
  • 137 Answers
SOURCE: bread dough hook slips when mixing
This is not a solution but I think you have a serious problem you might have sheared some gear teeth whent the mixer jammed and it only manifests itself under a heavy load, I would take it to a repair guy, those mixers are expensive and it would be worth it.
Posted on Mar 28, 2009
  • 27 Answers
SOURCE: Hobart A-200 3943. Having a problem with torque.
Check your recipe against the capacity chart found here:
You may be overloading the unit. Hope this helps.
Posted on Oct 19, 2009
Testimonial: "Thank you for the chart! I will check up on the recipe. "
Kitchen aid mixer kg25hoxer repair manual
Request the repair manual directly from KitchenAid.
Feb 26, 2018 | Food Mixers
What is spiral hook dough?
A Spiral Hook Dough Hook is one that is used for making bread dough. It mimics the action of stretching and kneading the dough by hand. This develops the gluten content which is the elastic part of the dough that traps the bubbles of carbon dioxide from the yeast.
Oct 14, 2017 | Food Mixers
KitchenAid ACCOLADE 400 Mixer. When mixing dough the bowl jumps out of the bowl lock. How do in resolve this problem?
Make sure that the bowl is fully tightened in the bowl lock. If this does not solve the problem it may be that the lock disc itself needs to be replaced or that the amount of dough is more than the dough hook can handle.
Feb 22, 2015 | KitchenAid Food Mixers
Mixer arms shake when kneading bread
You have not supplied a model number and the bowl lift models are not all the same. A couple of items you could check, make sure that the bowl retaining clip that engages with the dimple on the pedestal side of the bowl is not broken. Make sure any bolts/screws holding the pedestal to the base or the pedestal to the motor are tight. Even if you supply a model number I can't think of anything else to look at unless the handle is not lifting the bowl up tight enough. I think on some models the arm holds the carrier up with some pressure which would help stop the wobbles.
Jul 13, 2017 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
My mixer revs up full bore and then quits, on any speed level
has the breakdown of the parts. Item 8 is the controller board and item 9 is a sensor which monitors the speed. If either one is fried it will run wide open and then quit.
Mar 25, 2010 | KitchenAid 400 Watts KN15E1X Accolade 400...
Which kenwood mixer to buy?
Hi. Congratulations for researching mixers. I wish I had before I bought my Kitchenaid HD Pro. All mixer manufacturers over-rate their products. Goto and do a search for each mixer you are considering. Most mixer failures are caused by mixing heavy cookie or bread doughs. Although manufacturers claim that their mixers can easily handle these doughs...They cannot! My Kitchenaid self-destructed after 30 batches of bread dough. "For the way it's made"! Indeed! I solved my problem by buying a Hobart N50 mixer. It's a 5qt. and handles anything I throw into the bowl. I bought mine used, and refurbished it myself. New these units cost $2,035.00 USD.
If this solution has assisted you, please rate it. Good luck! ricardok45.
Mar 15, 2009 | Kenwood KM800 Major Classic Stand Mixer
Pops out of lock under a heavy load
Hi Susan. There is no worse feeling than the feeling you get when you find that you've been seperated from your hard-earned money by a company that markets a product with glowing phrases of what their product can do...And then doesn't deliver on it's promises. Kitchenaid mixers can make short work of bread dough NOT! My Kitchenaid HD Pro (475 watts) self destructed after only 30 uses of making my Sourdough Bread. The problem? A cheap piece of plastic that takes the stresses of two important shafts in the mixer. Cheap, shoddy parts in a mixer you paid top dollar for. Kitchenaid shows no shame in doing so.
What is happening with your mixer as it tries to mix your dough is that the head unit is thrust back and forth and side to side (bucking). Eventually hinges become loose and sloppy. Kitchenaid's behaviour is legal and beyond reproach, so make your next mixer purchase an informed one.
Goto and do a search for your Kitchenaid model. You'll notice that you're not alone in your mixer troubles.
I solved my mixer problems by buying a used Hobart 20qt. Commercial mixer (A200) and rebuilt it. When mixing heavy dough you should only use about 60% of the bowl capacity. less, if your mixer is agonizing with the amount of food in the bowl..
You will be able to replace the thumb screw. Be prepared to wait for at least a month for the part to arrive once ordered.
Mar 08, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Bread dough
Dec 10, 2008 | Hobart N50 Stand Mixer
My mixer was straining to stir bread dough. Now the motor turns on, but the arm does not rotate.
Did you hear a CRACK sound just as the mixer stopped running? If so, the plastic transmission housing may have failed & destroyed the worm gear and the front and rear bearings and possibly deformed the bearing seats as well. It happened to me. Although these machines are marketed stating that they can knead bread dough, they can't. Mine failed 5 months out of warranty, after only30 batches of Sourdough Bread. Take the top cover off of the mixer and look for the transmission housing near the front of the mixer. If there obvious cracks in it, it is your problem.
Dec 03, 2008 | KitchenAid K45SS Classic Stand Mixer
KitchenAid 400 Watts KN15E1X Accolade 400 Stand Mixer Logo
154 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
