Question about Dell Computers & Internet
How do i find the right replacement board - Dell Computers & Internet
  • Alan Hohenbrink
    Alan Hohenbrink Apr 03, 2011
    Is this a desktop or laptop? What is the problem causing you to seek a new motherboard?
    Sergeant:
    Champion:
  • 217 Answers
For the correct board go to Dells site and enter the service tag number in the parts search area. (enter model number if you don't have service tag). Once you have the boards part number write it down and you can search online for the correct board if you don't want to buy from Dell.
Posted on Apr 03, 2011
  • Dell Master
  • 27,725 Answers
First you will have to work out which operating system you want to install then look up the requirements for this motherboard eg: the ammount of RAM how big the hard drive and which type SATA or EIDE and the ammount you $ can of afford or click start right clik on my computer select properties you should see all imformation about your computer including the motherboard another way of doing this is to click start all programs accessories system tools system imformation there you will see all imformation on your computer this may vary depending on which operating system you have hope this helps
LG 55LM4600-UC LED TV I have was squirted with a squirt gun. Would replacing the t-con board fix this tv? Please read further details.
when water shorts out something it overloads a lot of other components so the best advice is to take it in for a proper diagnosis.
you just replace a board but another board is damaged it might just blow the board you replaced and that would prove nothing
Jan 09, 2017 | LG Televison & Video
Right have of led tv is darker
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 13, 2016 | Samsung Televison & Video
I have a Sanyo DP55D44 television and the right half of the screen is darker than the left half. Any ideas what part might need replacing?
Oct 31, 2016 | Sanyo Televison & Video
Hi,I've got a Samsung 46 inch led TV and the right half is darker than the right,is this able to be sorted.
Aug 13, 2016 | Samsung Televison & Video
Sharp TV model LC-70LE650U Dark on Right side
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
Jan 27, 2016 | Sharp Televison & Video
Right hand side of the screen loses picture
Jul 14, 2015 | Samsung Televison & Video
The only button on the panel that will light up is the 4 hr delay nothing else happens
This type of diagnosis will require taking voltage readings at the control board with a meter to find the root cause of the failure. Please see the rest of the information provided & the images below for the accessing, testing & replacement instructions.
1). Put the washer into the Diagnostic Test Mode per the Tech Sheet. 2). Did the Right Hand Interface light up? 3). IF the Right Hand Interface did not light up in Step 2 check for 5 VDC on the UIP3 wire connector coming off of the control board to the Right Hand Interface from (Pin 1 to Pin 2) and from (Pin 1 to Pin 3). 4). IF you do not have the 5 VDC then remove the MI3 connector from the Machine Control board. IF the display lights; replace the Motor Control board. IF the display does not light; replace the Machine Control Board. 5). IF you do have the 5 VDC then replace the Right Hand User Interface. 6). IF the Right Hand Interface does light up. Lock the controls by pressing the control lock button for 3 seconds. 7). Once the control has been locked press the power pad. IF the control lock light blinks when the power button is pressed it tells us the power button is sending the output from being pressed to the right hand interface but the right hand interface is not responding and will need to be replaced. 8). IF the control lock light does not blink when the power button is pressed replace the center user interface.
Jan 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Hitachi p50s601 recently went dead and was send to the repair shop. They found the problem with the SDR boards, both upper and lower, but they can't order them any where. So I took it home and look for...
the streeks are from the cables not being installed right. the cables that plug into the sdr board. if they are not seated right you get lines in your video. going side to side. some times it takes many tries until you get them in right. you can kind of guess what ones are not in right from were the lines are for the connecting cable to the screen. what i do is i do one at a time and see if the video gets better or worse and power it back on and off and work my way down until the video is normal.
Nov 27, 2010 | Hitachi Ultravision P50S601 50 in. Plasma...
How to fix my lg screen is only half viewable. the visable area is 50% and only on the right side. thanks
The problem is in the right (viewed from the back of the panel) X- Drive Board (A-Board). Replace it. Model number is needed for the part number of the board.
Before servicing your unit, touch your fingers repeatedly to a ground connection point or unpainted metal in the product. Before removing a replacement part from its package, touch the anti-static bag to a ground connection point or unpainted metal in the product. Handle the electronic control assembly by its edges only
  1. Remove the back cover by removing the screws holding it.
    (The Stand does not need to be removed).
  2. moz-screenshot.pngThe right X-Board is located at the bottom part of the TV beneath a heat sink. moz-screenshot-2.png
  3. Disconnect Main Board connectors.
  4. moz-screenshot-1.pngRemove the Main Board by removing the screws holding it.
  5. Remove the screws holding the heat sink of the X Drive Boards in place. Rock back and slide down to remove.
  6. Disconnect Right X Drive Board connectors. Take extra care not to damage the locks and TCP films. They can be easily damaged.
  7. Remove the screws holding the Right X Drive Board in place.
  8. Remove the Right X Drive Board.
  9. Replace the defective Right X Drive board and reassemble the unit in reverse order.
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
Washer will not fill or wash
theres 2 boards in unit console,,you should have replaced the control on the right side with the door switch..if replaced control board on right side just check door switch..onthejob
Feb 07, 2009 | Whirlpool Washing Machines
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
