Question about Frigidaire Freezer FFU1423
Frigidaire freezer\r\nSER; LFFU14F5HWC light inside is working, everything in freezer is thawed out.
  • Frigidaire Master
  • 2,699 Answers
On the compressor there's a start device but they call it a controller part number 216954200 and it's around 40 to 50 dollars.do you hear a clicking sound every couple of minutes or did you smell a burning smell.it sounds like the compressor isn't running if the freezer is warm,also on the model number there should be a dw and a number at the end,you have to get the model number off of the machine not the book.unplug the machine,remove the back bottom panel and you'll see the compressor,remove the metal clip and slide the controller off of the compressor,when this part fails if you shake it and hear pieces banging around you'll know it's bad or it might smell burnt or you can check it with a meter for continuity.don't remove any wires until you get the new part so you don't get confused when installing the new part.also do you know if the compressor is running?if it is you could have a freon leak in the saeled system,if so change it out.i looked up this machine,do you defrost this yourself?i can't find any defrost parts and how old is this freezer?
Posted on Apr 03, 2011
Lffu14f5hwc The light on the front shows 8 then changes to 4. The insde light flashes then goes out. the freezer is running and keeping things frozen.
Thank you for your post, Linda!
I see that you are having difficulties with your Frigidaire freezer, LFFU14F5HWC, changing on the display and the inside light is flashing off. This sounds like a possible problem with your panel or socket. I would recommend performing a reset on your freezer and you can do that by unplugging the power cord for at least ten minutes. If this does not help correct your issue I would suggest having a professional technician out to perform proper repairs. This will help you avoid any unnecessary part purchases. I hope this information is helpful to some degree. -Matt
Apr 06, 2015 | Frigidaire Freezers
On Model LFFU14F5HWC what is the thermistor used for?
If no help from owner's manual; go online to the company. Check customer service.
Jun 05, 2014 | Frigidaire Freezers
Freezer gets to cold
HI
If your thermostat cannot control your motor automatically for on and off then you should change it as it is the only unit that can cause this problem.
Feb 13, 2014 | Frigidaire Freezers
Not freezing
Check your circulatation fan. It may be stuck. Keep me informed The Raz Shack
Apr 20, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Have a 17 cu ft upright manual defrost freezer. Started to notice that items in door were soft a week ago. Warning light was on, but the rest seemed OK. Today noticed a puddle from thawed meat. Sounds like...
I believe you freezer has sprung a Freon leak. You described it and if it changes levels is a way of measuring what Freon you have remaining. Sometimes they can be repaired it depends on how they were built. Hope you did not loose much food, Sea Breeze
Mar 21, 2010 | Frigidaire Freezers
It quit running and everything thawed. It's got electric going to the dial. plugged it in and can't hear anything running.
The power coming into the fridge goes to the thermostat and when it's time for cooling the thermostat tells the compressor and other components to come on so it has to be the thermostat..Does the light insinde the fridge work? If so i would replace the thermostat and it should fix the problem!!!
Nov 06, 2009 | Frigidaire 12 cu. ft. / 340 liter Upright...
Upright frigidaire freezer not running properly
Sounds like your defrost timer has packed it in you need to fit another timer to it and everything will be as good as new.
by turning the timer you have forced it to run nothing to worry about. It has just stopped in the defrost position. What you have done is the first diagnostic test a tech would have performed. I hope this has helped you out.
Jun 30, 2009 | Frigidaire 14 cu. ft. / 396 liter Upright...
Defrosting???
your food should not thaw in a frost free freezer. but I can not tell you why it is thawing, sorry.
Apr 25, 2008 | Frigidaire 13.7 cu. ft. Upright Freezer...
Frigidaire Freezer FFU1423 Logo
186 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
