Question about Roku XD Streaming Player 1080P Wireless-N (2050X)
As far as i know evrthing is hooked up right but no code appears on tv screen for me to go any further
  • 2,632 Answers
Welcome to Fixya. To verify if the setup is correct you can use the video guide below on how to set it up and how to obtain and register the code.
Roku: How to Setup
The video below shows you on How to use Netflix, Amazon Video on Demand, and Hulu Plus
Roku: How to Use
If you have questions please let me know. Thanks for using Fixya.
Posted on Apr 03, 2011
Strange codes appears on my TV screen
Contact the authorized service center for Philips. Do not make any further experiments with it, please. Gopakumar Gopalan Google
Mar 14, 2014 | Televison & Video
Sharp aquos LC-60LE640U flashing error code 2-5.
Dont buy a Sharp. Buy a Sony, Panasonic, JVC, Visio, ANYTHING but sharp!
Jan 27, 2013 | Sharp LC-60LE640U 60 Inch 1080p 120Hz LED...
What do i need to do to make the dvd player appear on screen? help!!
read instruction manual, color out from player to set one at a time===pretty straightforward stuff. inputs on set are labeled so select that input and you should be set.
Sep 03, 2012 | Emerson LC320EMXF 32 in. LCD TV
Lost the code sheet to my sanyo tv and my panasonic vcr
I am sending you links to all the codes I have found so far.Older style TV's have 3 digit codes and flat panels USUALLY have 4 digits.VCR codes are 3 digit codes.No matter what brand the universal remote is,the TV codes are just about a universal number also.Make a list.Some of the links are newer and probably have repeat numbers but contain a couple extra codes.The first 3 links are 3 digit TV codes.The last is 4 digits for flat panels.A couple of the lists also have VCR codes,a couplr are TV only.If any codes do not work for either one,just reply back here and let me know and I will get an autolink to your post and I will reply ASAP.Also,I would like to know if the TV is a flat screen or not so I can research further.Good luck! Greg
http://en.kioskea.net/faq/281-universal-remote-codes
http://www.universal-remote.net/philipsmagnavox.html
http://www.thompsontv.com/rcarc.html
http://www.rockabilly.net/ofa/codes-tv.shtml
Sep 27, 2010 | Universal Remote Control GE174Universal...
Black box appears when I hook up xbox or dvd player?
Try turning off any closed captioning if it is on.
Sep 21, 2009 | JVC Televison & Video
Using Plasma as a monitor? Screen is to the right.
Try changing the Refresh frequency to a higher one (in the Display properties)
Jul 20, 2009 | Televison & Video
Trutech plv1615t 15 in. lcd
Open the back of the TV,and look at the can shaped items on the board that the power cord is hooked to.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.So far I have fixed four of the same make,and model TV as this,and they all had either one,or two bad capacitors.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
Apr 05, 2008 | TruTech PLV1615T 15 in. LCD Television
Hook up
Have you changed the input on your television to reflect what port on your tv you plugged it into? You say the color codes match so you didn't use the coax. So I assume your most likely plugged into line 1 or 2 of your tv. If you have a snowing picture or you see a tv show, your not on the right input.
Dec 30, 2007 | GPX D1816 DVD Player
Tv want show
Look at the back of your TV.  Make sure your cable is hooked up to connector on far right, NOT the far left. (For analog cable TV.)
Push "source" button on remote or side of TV to cycle through TV inputs.  Wait one second between pushes.  You want to stop just before the source that displays "AV" on TV screen.  It should show a number, for the current channel number.
If you are using an analog cable box, try setting the TV channel to 3 or 4.  If you use no cable box, try changing channels on TV to find an active one.  If no luck, make sure your cable service is active (subscription active).  Cable companies disconnect it between residents of an apartment/house.
Oct 19, 2007 | Akai LCT3285TA 32 in. LCD Television
Select Language
With electronics sources or monitors,asking a language preference is a first or early step in initial programming.To analyze the source of the "which language " request--dis-connect the cable box temporarily and hook up signal direct to tv.If ? is still there,the tv is asking it. If ? is gone,then the source box was asking. Any further assistance needed,please let me know.
Oct 03, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Roku XD Streaming Player 1080P Wireless-N (2050X) Logo
168 people viewed this question
Top Roku Televison & Video Experts
David Payne
David Payne
Thomas Stauber
Thomas Stauber
ray gallant
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
