Question about Echo Garden
I was cutting a large log and the saw kicked back. Echo GS 300. It now won't throttle up, acting like the kickback safety is locked but it is not. The throttle linkage is still connected also. Any suggestions?
  • Echo Master
  • 2,239 Answers
Does sound like the brake has activated, pull the hand guard fully back to the top handle until you hear it click off, now try again
Posted on Apr 04, 2011
How do you replace clutch on cs 350 echo chain saw
I am guessing what you are calling the clutch band is the anti kickback brake. It is operated by a "lever" in front of the hand grip on the front of the saw. Pull that lever towards the rear of the saw to get more slack in the band.
Jul 31, 2014 | Echo Garden
I bought a ls1016 coupond mitre saw this week. I was cutting cedar 2x6 's today and had a few kick backs. I am building my deck and do not feel safe using the saw after the kick backs. Why as this...
Sounds as if the blade is dull. Or perhaps bent. A dull or bent blade blade will 'grab' the wood, rather than cut it, resulting in binding, or kickbacks.
Solution; replace the blade with a fine-toothed, good quality blade. If the blade is new, then check that the blade is bolted tight on the arbor. If the blade is loose, it can result in kickbacks.
Also, check that all the bolts/fasteners/locking mechanisms on the saw are tight, and in good working order. Sometimes a tool new out-of-the-box will have loose screws/nuts/bolts that need to be tightened up.
Also, when cutting, use a smooth, slow, motion, being sure to give the saw the time it needs to make the cut.
Jun 19, 2011 | Makita LS1016LX 10inch DualSlide Miter Saw...
Cs 400, first time cutting great, then the saw did not cut perfectly. Recently it worked poorly. When I push the saw a little bit hard against the log, the saw did not running(the engine is working)
suggest you sharpen the chain, sounds like it's dull like maybe the log you cut had been fallen on ground for awhile, this causes dirt build up in bark and acts just like cutting Dirt and we all know what that does to your chain...dulls it fast ! I learned from experience I cut an oak tree that was cut down for about 2 years when I got permission to cut it up,needless to say it had a lot of dirt in the bark! hope this helps you !
May 15, 2011 | Echo CS400 18" Chain Saw
Blade shaft slipping
It could be a number of issues. These saws have a built in vari-torque clutch used to prevent kickbacks. Basically, when the blade binds while cutting, the arbor spins but the blade won't (prevents kick-back). It works by not over tightening the blade washer (this is the slip clutch), if you over tighten, the blade washer can't prevent kick-backs because it has no room to slip, if you under tighten, the arbor spins, but the blade won't. I'd try to tighten the blade washer 1/8 turn and see what that does. If your actual arbor shaft is not spinning, you could have a gear issue. If you hear the motor running and the arbor slips (not the slip clutch) sounds like there might be a gear issue,If the rotor is spinning (the part inside the stator-i.e. the electric motor section) but it is not transfering that movement to the arbor, it has to be a gear issue.
Jun 07, 2010 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
My Echo CS starts fine but then will not accelerate. Sometimes, after it's warm, it will work OK, but more often, it acts as if the chain lock is engaged and almost wants to stall as the throttle is...
Can the chain be pulled by hand fairly easily? Check the fuel filter, air cleaner, and muffler for plugging. Inspect the fuel lines for decay or other damage. Make sure the carburetor fasteners are tight. Try turning the H jet needle CCW about 1/8 turn--the engine should 4-stroke when running free at speed, but 2-stroke when cutting. Hope this helps!
May 12, 2010 | Echo CS400 18" Chain Saw
A fellow firefighter was cutting with his Echo
The cylinder (if engine running too lean) would be badly scored as well as the piston and rings. Knowing today's prices for parts and labor, $300 is probably not too far off. At that price though, he might consider replacing the entire saw rather than repair. I have noticed a number of Echo saws that don't seem to 4-stroke when running at speed, but not cutting. A properly tuned 2-stroke should always 4-stroke at speed, but immediately 2-stroke when cutting--this produces the most power and least heat. The fuel should always be premixed in the can, agitated well during mixing and again before using in the saw. Agitate the saw after adding the new fuel as well. At 50:1 ratios, there isn't much spare lubrication in the engine. He might consider another brand of saw if buying new. Hope some of this helps!
May 10, 2010 | Garden
It starts up, but when trigger is pulled, the
Most saws have a safety or anti kickback brake. Yours might have tripped. There is a guard in front of where your left hand holds the saw. With the saw NOT running, pull the guard HARD towards the back of the saw. It should move a bit ant you may hear a click. The chain should now move. If the chain moves easily when the saw is not running, but doesn't move when you rev the saw up, the clutch is broken.
Sep 10, 2009 | Garden
There s a huge amount of kickback when starting the saw. its very aggressive.the power isn't delivered calmly anymore
That is actually normal.. As the motor brushes get warn - it will kick on a bit more abruptly.. The cause of the "kick" is from the initial centrifugal force - kind of like a gyroscope..
PLease dont forget to rate ;o)
Aug 14, 2009 | Saws
Open Questions:
Garden Logo
64 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
