Question about Marantz Audio Players & Recorders
My 12 yr old Marantz SR-18EX reciver stopped wotking. It has power, but no audio. I was listing to a CD and it just cut out. It smelled like something shorted out. There's no output to the speakers when I run the audio test. I'm thinking it's may be the amps. Any suggestions before I send it off for repair?
    Brigadier General:
  • 8,546 Answers
Maybe open it up and sniff for burnt components, but even if you see something obvious and replace it you migh not know what the original cause for failure was, so you may just be wasting time and sacrificing new parts.
I
Posted on Apr 03, 2011
My sr 18 has no audio output,on all speakers,but video is good.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR-18EX-Receivers-manual/id/511ci766/t/2/
Headphones connected?
Disregarding specific sources, how does it do with test tones?
Jul 09, 2011 | Marantz SR-18EX Receiver
Marantz SR-18 NO Sound No Data error for DSS (Directv) only
You need to check the connection of the lead that carries the audio from the DSS to the amp, move it to one of the other channels ie vcr and see if it can be heard when set to and switched to vcr. Then we know if we are dealing with the Amp or the source..
Dec 23, 2007 | Marantz SR-18EX Receiver
Hi, I try to connect the Kenwood EQ to my Marantz SR-18, where is exactly RCR jack should I connect?
you want the audio signal to go to eq input then out of eq into rec input of your choice
Jun 05, 2011 | Marantz SR-18EX Receiver
I cannot turn on my Marantz SR-18EX after a storm couple of months ago. Is there a solution to that or I need a new one? Thanks.
hello do you mean is total dead if so check the glass fuses inside, but beware if you put another 1 in and it blows again then theres a dead short someware also make sure you use the same rated fuses the value will be on the end of the fuse or on the fuse holder on the power board. fingers crossed.
regards
shaun
Nov 29, 2010 | Marantz SR-18EX Receiver
I need the remote control code numbers for the SR-18 so I can turn it on with my Direct TV remote.Do you know what they are?
the best thing to do is a code search per the directv manual and hope the Marantz powers off when you find the code.
If it turns off, you have won half the battle. Save the code and try turning the Mar back on.
The issue is that these universal satellite remotes are very limited on there funtionality with audio systems.
Keep in mind that if you find a code that turns it on & off, you will probably be limited volume only. If you get those three functions, you are very happy and call it done.
Hope this helps.
This goes for all sounds systems and not only Marantz.
Jan 19, 2010 | Marantz SR-18EX Receiver
Marantz SR-18EX Loses Memory and Has Distortion on Center Ch.
There is a 1 Farad "super capacitor" that needs to be replaced. You need soldering skills to do it. The board is accessible if you remove the front panel of the receiver. The part # is DB-5R5D105; you can get them on eBay for about $2.00 each. Regarding the center channel issue, you may have a bad solder joint on the P781 connector on the P774 board. This is the board that houses the output transistors for the 3-channel main amp board (P704). If not these solder joints, you have a weak driver transistor on P704, and troubleshooting would probably be best left to a pro. Good luck!
Aug 17, 2009 | Marantz SR-18EX Receiver
On the Marantz SR-18 amp how do I switch the DSS setting from Dig 2 to Dig 3? Our sound is coming in on Dig 3 and somehow the setting got changed, probaly an errant command on the remote
You have to assign the digital inputs on the setup menu from the remote control while you have the On screen display on a monitor or TV screen.
Feb 10, 2009 | Marantz SR-18EX Receiver
Marantz SR-18ex remote control number
If you mean the model number, that is: RC-18SR
Jan 10, 2009 | Marantz SR-18EX Receiver
Do you know the remote code for the Marantz SR-18ex receiver? I want to control it from my Comcast remote and can't locate a remote control number.
The stock remote for the SR-18EX is the RC-18SR - that's the one it shipped with when new. You can also use the RC-2000, RC2000 MkII, and I have an aftermarket RC-1400 that works perfectly with my SR-18EX, AND offers 15 macros instead of the standard 4 you get with the stock remote.
Marantz part for SR18
www.futurlec.com
0.20 US each
Feb 02, 2008 | Marantz SR-18EX Receiver
69 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
