Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
I have DC 14 AND IS THE BRUS IS NOT WORKING IS REAL HARD AND DO NOT ROTATED IS BROKKEN APART PLEASE LET ME KNOW THE NEAREST SERVICE CENTER CLOSE TO KISSIMMEE FL 34758
Battery not holding charge or charger not charger
Hi
I am sorry to hear that your battery or charger are no longer working. I would suggest locating your local service center to have your charger and battery tested. Depending on the age of your unit, the battery may have reached the end of its life. Our service center would be able to determine exactly which is not working properly and determine warranty status. Please follow the link below to locate your nearest service center.
Thank You
Black + Decker Customer Care
blackanddecker com
Feb 27, 2015 | Black & Decker CHV1510 Vacuum
Dirt cup release button is stuck and not operating even after pressing very hard. i am worried it will brake. Please guide.
Hello there! The dirt cup bottom door should swing open quite easily when the release button is pressed. If you are concerned that you may break the dirt cup we recommend you take your vacuum to a Hoover authorized service center for assistance. The UH70015 comes with a 60 month limited warranty. Follow the link below to locate the nearest service center to you. Service Center Locator
Hope this helps!
Sep 17, 2014 | Hoover UH70015 Bagless Upright Cyclonic...
How do I install Hoover part 41911014
Hi Jeffrey, we actually recommend having an authorized service center replace the cord reel assembly on your vacuum. Please follow the link below to locate the nearest service center location to you. Thanks!
Aug 19, 2014 | Hoover S3630 WindTunnel Bagged Canister...
How do I replace a Hoover Steam vac 60 turbine
Hello! We recommend taking your cleaner to an authorized service center to have the turbine & gear assembly replaced. Please follow the link to locate the nearest service center to you. Service Center Locator Thanks!
Jun 03, 2014 | Hoover SteamVac F5914-900 SpinScrub...
How do you open the dyson 14 to replace the belt?
It has torx head screws you will need a set of them to take it apart the screw driver type will work better than the bits because they are recessed.
Aug 15, 2013 | Dyson DC14 FS Telescope Complete Lifetime...
Bissell proheat clearview red pump pulley
Yes, it should be spinning and driving both belts. If it is not you would need to have it fixed by a service center. This should be covered if your machine is still in warranty. Here is a link to find your nearest BISSELL Authorized Service Center:
May 23, 2013 | Bissell ProHeat Turbo Deep Cleaner Upright...
Electrolux Epic series 3500 model Upright Vacuum cleaner motor(replace old one)?
I don't know what your question is, but replacing a motor for Electrolux, now Aerus, should be done by an authorized Aerus Electrolux service tech. The uprights are especially tricky to take apart and reassemble correctly. The address and phone number of the Aerus store/service center nearest you can be found at the site below.
http://www.aerushome.com/storelocator/
Mar 13, 2011 | Electrolux Vacuums
Hi - We can't get the bar to
the roller bar is very touchy, work with it by rotating the ends,it will reseat.
Oct 18, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
My brus on my Dyson won't turn after some fringe got stuck in it.
You sound like you've broken your belt! If the roller gets stuck the pulley that rotates the belt will have burnt a hole in your belt and broken it. You'll need to contact your local Dyson to obtain parts,
Mar 09, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
32 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
