Distortion & low signal
I have purchased a second-hand Fostex FD-4, set it up (normal mode) as per manual instructions. On attempting to record/monitor a guitar track the gutar signal is coming through at a) an extremely low level- LEDs only go up one or two with guitar at full volume & input/master faders up to 7/8 and b) distorted.
This has happened with both an electric and electric-acoustic guitar, I have tried swapping leads and all four input channels (including the two that have high/mid/low switches) I have tried lowering instrument volume and pretty much everything else I can think of.
The manual lacks a troubleshooting section and I've gone through the setup step by step.
Help!
  • moundev Aug 05, 2008
    Thanks for the tip (I'll do it regardless) but I don't think its the answer: I've run a keyboard into the system (using same leads/inputs) and its fine..
    Could it be an impedance issue?
  • 682 Answers
Use new connection cables with its new jacks------bring a contact cleaner spray and apply it in all of your sockets(the places where you put your jacks)and turn your system off put your jacks in sockets-----in----out many times-----then turn system on.--also apply your contact cleaner in all volume control and move it continuously.
Posted on Aug 05, 2008
  • mohamed eltoni
    mohamed eltoni Aug 06, 2008
    if every thing is clean-jacks and cables are ok.you may have a problem of mismatching and needs manual of equipment to assign the right matching level.
Looking for a manual for a Fostex FD8
Look here: http://www.fostexinternational.com/docs/tech_support/manuals.shtml
for the link to download the user manual. For FD-8 there are links to PDF for owner's manual, supplement, and quick guide. I assume the owner's manual is what you seek.
May 10, 2014 | Fostex Mr16hd 16 Track Digital Recorder
Need to reset atomic clock to Virginia time zone; now 4 hours ahead
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
May 31, 2012 | La Crosse Radio Controlled Atomic Clock
I am having trouble setting the alarm on my clock, it has options mode, max/min, up down and snooze. i am not sure how to set i , can you help?
Hello
Select a location to place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal. The WWVB time signal will easily penetrate Masonry and wood framed buildings. WWVB will penetrate almost every residential building and most steel buildings if they have adequate windows. It is not possible, however, for WWVB to penetrate most indoor shopping malls and rooms in the center of large office buildings that do not have windows. In buildings that WWVB cannot penetrate you may set the time using the manual time set button. When the clock is exposed to the WWVB signal it will automatically set the hands to the exact time.
OK.
Aug 10, 2011 | La Crosse Radio Controlled Atomic Clock
It looses time and the radio controlled feature does not bring it back to the correct time. I put in a new battery and it still happens. It is a La Crosse Technology Radio Controlled clock Model:WT-3101
When the battery is installed the second hand will advance eight seconds (2 seconds per step x 4 steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Jan 24, 2011 | La Crosse Radio Controlled Atomic Clock
Nelsonic watch with no instructions
Copy and paste this link. It will take you to Bulova's service centerwhere you can download instructions for any of their watches.
http://bulova.com/service/servicecenter.aspx
If you appreciate me finding this answer for you then please rank this solution as "fixya" or at least "helpful" as what I have found for you will solve your problem. :-)
Jan 09, 2009 | Bulova Watch
Alternative compact flash cards for fostex mr-8
Fostex has a list of tested and confirmed Compact Flash Cards for the MR-8:
(It is under Support on the Fostex USA main page)
http://www.fostexusa.com/support/pdf/fostex/mr8/mr8_confirmed_media_list.pdf
Looks like they have tested up to 2GB with no problems...
Hope this helps
Nov 19, 2008 | Electronics - Others
SamsungSGH-A411/T305 compatibility
both units were returned to the purchaser who by using the hardware compatibility list in the phone selected the T305 option. from there on evreything went smoothly as per the manual. Maybe a problem with the signal selection software?
Aug 24, 2008 | Motorola Mobility Bluetooth Hands-Free...
Timex 1440 sports watch, WR50M
In "Time Mode" when time is displayed, hold the "mode" button until the alarm flashes. Press the "mode" button again and the display should change to the seconds flashing. Press the st/stop button to change location between seconds, minutes, hours, date, month, and day. Use the lap/reset button to make any changes.
Feb 15, 2008 | Timex 1440 Nylon watch
Fostex FD-4 manual.
You can try the following site. I believe they are free downloads. Good luck!
http://safemanuals.com/annexe_SERVICE%20MANUAL_FOSTEX_FD-4-_E.htm
Nov 13, 2007 | Audio Players & Recorders
Instructions for casio wave ceptor 4303
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Nov 06, 2007 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
117 people viewed this question
 Grubhead
Grubhead
