Question about Solar Intermatic Self-adjusting 7 Day Wall Timer St01c
I am programming my sto1 and I cannot get to dusk setting to program dusk on dawn off i have followed instructions and get only to dawn I have cleared and started over but to no avail purchased on 2.23.11 received on 3.3.11
ST01C instructions are confusing, and are longer than space allowed for free answer.
Open following link for re-written instructions that might be clearer, with illustrations how the display should look.
http://waterheatertimer.org/ST01C-program.html#astro
To clear the timer, hold down on-off button and press reset button.
Release reset button and keep holding down on-off until INIT displays.
If you go through re-written instructions and get confused, add a comment with exact step where it is confusing and I'll pull out the ST01C I use for testing and maybe I can find what is causing the problem.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 03, 2011
Why can't we select "astro am" or "astro pm"?
Timer is not identified...
Trroublehoot on following link:
http://waterheatertimer.org/How-to-troubleshoot-timers.html
Various dawn-dusk timers appear on following link with manuals for each:
Oct 07, 2017 | Hardware & Accessories
Setting a dawn/dusk timer for the Utilitec 0192773.
You may have to repeatedly advance the hour setting to get it to change from AM to PM.
Mar 25, 2017 | Hardware & Accessories
I have a Intermatic self-adjusting wall switch timer and I can't program it even though I have followed the instructions 3 times.
Program 1 is ON, and program 2 is OFF, 3 is ON, and 4 is OFF, etc
Copy following link for EZ step-by-step programming for ST01C timer:
Jun 05, 2012 | Intermatic Inc. ST01C Digital In-Wall...
Why does light blink off and on when set at dusk/dawn
If lights blink on-off, then red wire is connected where blue wire should be.
Red wire should be capped, and not used when timer is used for single pole operation.
OR connect red wire and blue wire together if you want Dawn-to-dusk operation instead of dusk-to-dawn
Open following link and scroll down to bottom for wiring diagrams.
Mar 22, 2012 | Intermatic Inc. ST01C Digital In-Wall...
Utilitech #0192773 setting the timer for not working
I do not have repair for defective timer.
Open following link for clear large-print instructions.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Add a comment about part of manual that does not work, for possible additional help.
1) Timer replaces single-pole light switch only.
2) Timer does not have a battery and must be wired correctly before programming can take place.
3) Choose either dawn-dusk or programmable on-off:
Timer can be set for dawn-dusk operation
-OR-
Timer can be set with 7-day on-off functions of your choice
Aug 18, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I have an Intermatic ST01C timer. Works great. I just noticed that I cannot set the DUSK time past 9:11pm. Any minute before that is fine such as 9:10pm but I wanted to set it to about 9:15pm. It has...
Call Intermatic.
You can set dawn-dusk parameters a bit longer or shorter than pre-programmed dawn-dusk times.
There is a limit to how many minutes you can add or subtract to pre-programmed times, and I'm not sure how many minutes exactly.
All astronomic timers have limited number of additional minutes, and folks write to fixya occasionally about wanting to extend the limit. But there is no work-around unless you choose to set fixed on-off times instead of using astronomic feature.
If timer begins to malfunction, you reset timer and change CR2 battery, and then reprogram the timer.
Instruction manual has troubleshoot checklist.
Timer comes with 1 year limited warranty.
Open following links for ez instructions, wiring diagrams, and battery illustration:
Jul 29, 2011 | Intermatic Inc. ST01C Digital In-Wall...
In setting the sunrise -sunset do I have to program it for every day of the week, or just the first time.
The answer is no. You can program dawn to dusk for whichever block of days you choose:
Individual days Mo thru Su
M-F Monday thru Friday
WDK for weekend
ALL for all days of week
Step-by-step instructions for ST01C dawn-to dusk appear on following page:
1) Press + to display DUSK or DAWN for program 1 ON
2) Press ON/OFF to display days you want Dawn-Dusk to operate.
For example ALL is all days of week
3) Press ON/OFF and display will show SAVE
4) Next you set program 2 OFF and be sure to select same days for OFF that were selected for ON.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 20, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I am an electrician and my client wants me to reprogram the digital timer (Intermatic) I don't know the model # but it looks like the one on the previous page. Probably the most popular digital wall timer...
Below are links to digital timers to help identify your timer.
Manuals for each timer appear on page.
Programming takes patience, which might be why your customer wants you to do it.
And these 1-year warranty timers go bad, and then timer will not reprogram, which may be another reason why customer wants you to do it.
Intermatic EJ500 and ST01C are battery operated, and will not program if battery is low.
Aube has rechargeable battery that is not replaceable, and this timer will not program if battery is bad.
Other timers shown below have clocks that operate on 120V circuit and require white neutral before display lights up.
Generally each programming is same: You set current time. Some timers you set daylight savings time. Some timers are 7-day, and some offer dusk-to-dawn. For 7-day, you set event1 ON and then event1 OFF for up to 7 programs. You choose the days for each event to operate. Before programming, make a schedule so there are no overlaps or conflicts in programming.
With Intermatic EJ500 and ST01C, event1 is the ON event and event2 is the OFF event, up to 40 events.
Add a comment if you hit trouble spot when programming.
Also fixya offers live phone support for a price.
Intermatic EJ500 with 7-day or dusk-to-dawn
Programming remains in memory forever, so you may only have to re-enter current time.
http://waterheatertimer.org/Flipdown.html
Intermatic ST01C with 7-day or dusk-to-dawn
Intermatic EI500 7-day
http://waterheatertimer.org/Programmable.html#EI500
Aube timers are either dusk-to-dawn or 7-day
http://waterheatertimer.org/Aube-timers.html
Utilitec 0192773 with 7-day and astro dusk to dawn
Utilitec 0141224
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
GE 15071 - 15086 in-wall timers: one has daylight savings time
http://waterheatertimer.org/GE-timers-and-manuals.html
Woods 59018 in-wall
http://waterheatertimer.org/Woods-timers-and-manuals.html
Tork SS720 in wall:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
Dec 17, 2010 | Intermatic Inc. ST01C Digital In-Wall...
How to set utilitech wall timer for dusk/dawn settings
The Utilitec 0192773 timer has astro dusk-to-dawn functions.
The manual is very unclear at the exact point you need it to say how to set dusk-to-dawn.
The following page has the manual, with explanation how to find the astro dawn-to-dusk setting
When you are programming the timer, press TIME button and hours start flashing.
Press the +/- button ... the trick is to keep pushing the +/- button until it finally gets to astro, and the sun-moon symbol shows on display.
When the sun-moon symbol shows, the display also shows AM.
Press the +/- again and PM show.
So if you want Program1 to turn lights ON at dusk (PM), then your display needs to show: 1 ON PM sun-moon.
To continue setting astro, do not set hours, just press PROG button.
Then repeat the steps above until: 1 OFF AM sun-moon show on display.
Nov 08, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I have the DT620CL and want to disable the Dawn and Dusk settings.
See "Changing Program Times--Skipping and ON or OFF Event" in the attached manual: http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt620cl.ashx
Find the Dawn or Dusk program time and follow the instructions in step 5 (Turn the selector knob until SKIP shows
in the display and “-- --” replaces the
time (Fig. 17), then press PROG to accept
the new setting.)
Nov 19, 2009 | Intermatic Hardware & Accessories
Solar Intermatic Self-adjusting 7 Day Wall Timer St01c Logo
232 people viewed this question
Top Solar Hardware & Accessories Experts
Gil Shultz
Bill Boyd
Gene Haynes
Are you a Solar Hardware and Accessory Expert? Answer questions, earn points and help others
