Trying to determine age of a Park G10 guitar amp by Marshall through serial number # 103849 - any resources? appreciate any help
  • josephlgreco Apr 03, 2011
    Thanks Guru - any resources available you know about to narrow it down?
    I have an earlier serial number it appears
  • 80 Answers
That series of guitar amp was manufactured at some point during the early to mid-1980s.
Posted on Apr 03, 2011
    thanks guru, is there any published resources for info?
    i believe i have an early serial number based on the little info i can find
  • Gary Iverson
    Gary Iverson Apr 04, 2011
    Here are a couple of websites for decoding the serial number:
    http://www.superiormusic.com/page024.htm...http://www.guitarattic.com/how_to_date_y...
Can i find out the age of my eko guitar from the serial number
Unfortunatly, once you get past the well known Fender/Gibson/Gretch brands, info gets harder to come by.o can try contacting Eko directly in Italy. Here's a link
Numark Marshall Dunlop Korg PRS Akai Sonor EkoMusicGroup distributore di...
Or you can date the guitar off the codes on the pots. Here's some info on that-
Vintage Guitars Info dating vintage guitars amps by date source code
Feb 21, 2015 | Music
Where is V193037
Guitar Info This guitar is from the U.S. Vintage Series
made at the Corona Plant (Fender), USA
in the Year(s): Cannot be determined from serial number,
however you can consult this chart showing the
corelation between serial numbers and dates found on the neck
Fender MIA RI Serial Number vs. Neck Date
Fender: Corona Corona factory was opened in 1985, Corona California, with major guitar production starting in 1987. With the addition of a custom shop in 1987 the plant currently employs about 700 workers. Apart from general and Custom Shop Fender instruments and amplifiers, it also encompasses Guild acoustic & electric guitars.
May 12, 2014 | Fender Starcaster Strat Electric Guitar -...
Marshall mg102fx cuts out
I've seen a bunch of Marshall Combos and a very common failure comes from broken resistor legs at pre-amp and power amp modules insides, they are the low-value/2-3W rated and the soldered legs broke so easy because of enclosure vibrations, let me know a bit more to improve help...
Nov 04, 2013 | Marshall Amplification Marshall JMD1...
Where is the serial no. on a mhz40c
The serial number for this will be on a sticker on the back. If it is missing then perhaps someone removed it. You may be able to contact Marshal and they may be able to tell you as well. http://www.marshallamps.com/
Mar 22, 2011 | Marshall Amplification Marshall Haze 40...
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Can i fix one ampli marshall mg100 i had used my bass, and now my marshall have a very estrange noise
Well i know ive destroyed a guitar amp with a bass guitar before :-p this is why they make bass amps and guitar amps instead of just amps
Sep 25, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Where is the serial number on my marshall amp mg15fx
Behind the amp, right around where the power-supply is. Usually the right hand side at back of amp. Serial numbers are labeled as: S/N########
Mar 14, 2010 | Marshall Mg15dfx 15-Watt Combo Guitar...
Problem with marshall dfx250 just recently the volume on my amp is dropping and increasing at random, love the amp but needs fixed any ideas??
If you have no experience with amp repairs you are better off having it serviced. This problem seems to be related to bad solder joints in the FDD circuit exacerbated by the cooling fan aging and wearing out. Namely R107 and R96.
Mar 02, 2010 | Marshall Amplification Marshall MG250DFX...
Guitar amp shows power but has no sound, could it be a blown fuse
Nine times out of ten, any problem with an amp having no sound coming out, it's a wiring issue. Make sure all of the wires internal to the amp are propely hooked up. Also, try switching out the quarter inch cord you are using from your guitar to your amp. Could be a bad cable. Unless you have blown the speaker completely, something is loose or not hooked up properly.
Feb 27, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
141 people viewed this question
 Grubhead
Grubhead
