Question about Dryers
Type:DWSR-NAT-1206006-CV22. The Kenmore gas dryer runs and spins but does not heat up -the clothes remain wet. Lint is not the issue . Iclean the lint trap every load. I also vacuumed out the coil vent tube.
  • Dryers Master
  • 3,361 Answers
If it does not heat at all your glowbar ignitor is bad.
If it heats and does not re-light your gas valve coils are bad.
Posted on Apr 03, 2011
  • Dryers Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
My kenmore dryer with serial number: DESR-NAT-1206006-FM22 doesn't have heat at all and my clothes are still wet. What to do before I call the repair guy?
Clean lint screen could be clogged a dryer sheet can sometime block the grille if a loads to large and heavy that will result in wet clothes.some dryers have an option for air dry if that is selec
Jul 24, 2015 | Kenmore Dryers
MR0849046 DWSR-NAT-1206006-CV22
Could be the element or any of the fuses.
Jul 12, 2014 | Kenmore Dryers
Dwsr nat 1206006 cv22 fm22 whirlpool ser
take a picture or more info where is it center side back wall ?
Nov 09, 2013 | Kenmore 74602 Gas Dryer
Hi more info. I posted wrong. my dryer is model 11079912990. ser # mj1607152. type ddot-nat-1206006, cv22. 120 volt, 60 hz. 22000 btu .27 inch wide kenmore gas dryer. The dryer would run for a few...
You could have a blown fuse because of a clogged vent or a bad thermistor. A thermistor is used by electronic controls to measure temp changes inside the dryer. If the sensor is open then the brain does not have a clue how hot the dryer is. So it shuts down. Repair clinic has an excellent thermistor replacement video.
Oct 25, 2013 | Sears Kenmore 7.3 cu. ft. Gas Dryer Model...
My Whirlpool mod# lgb6300pwo ser # mso902052 type dwsr-nat-120606 fm22 runs without any heat. Therefore, no drying. Checked the exaust ,the gas is on . What is the next point to check?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 11, 2010 | Whirlpool Dryers
Light comes on wont spin wsr-maytag mod m6d5600tqo ser mw2607338 type bwsr-nat-1206006-fm22 light wont turn off even with door closed dryer is not old new in 2008
Check the door switch. It just might be sticking which is why the light remains on and the dryer won't spin...
J. Lewis
Dec 21, 2009 | Maytag Dryers
My Kenmore Series 400 dryer spins & heats, but the clothes stay wet. I've cleaned the lint basket & have checked the vent from dryer to outside. Any suggestions?
Check the outside vent again while the dryer is running. There should be a good strong air flow, if not then your problem is in the exhaust system somewhere
Jun 21, 2009 | Kenmore 73952 Gas Dryer
Kenmore Elite Elec Dryer Model # 110 62032100
Kenmore Ellite Dryer - Model 110.73952102 Type DDOT - NAT 1206006 - EH22
The Heat does not turn on! It spins and spins but no Heat? Any suggestions and how to fix intructions would be greatly appreciated. Thank you!
Oct 14, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
834 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
