Question about Sport & Outdoor - Others
Hi I have an older (but in great shape) Mitchell 302 saltwater spinning reel...I do not know how to put a new spare spool on the reel so that hte drag works properly...can you help me please Thanks
SOURCE: shakespeare 2660 coarse fishing reel,cant remove spool cover
According to the intructions and I quote "Take off the cowling that covers the spool, twist off the pick up mechanism clockwise and a half turn anti clockwise will remove the spool"
Posted on Jul 12, 2009
SOURCE: The Drag on my 750ss does not work what could be the problem?
This happens after you screw the drag too tight so that the plastic washer under the spool is pressed out. The fix is simple: cut excess of that washer and tighten properly.
Posted on Oct 12, 2009
mikesreel
  • 76 Answers
SOURCE: I have a Penn 650 SS spinning reel Ihave
If the knob is not stripped, replace the drag washers under the drag knob.
Replace key #'s 6 and 56T with 3x 6-155 carbon drag washers, available here: http://www.mikesreelrepair.com/product_info.php?products_id=7806
this will bring your drag back to better than new condition!
Here's a schematic: http://www.mikesreelrepair.com/schematics/displayimage.php?pos=-4123
Best of luck!
Mike
Posted on Nov 13, 2009
absolutely spot on
Posted on Apr 18, 2010
  • 44341 Answers
SOURCE: My mitchell gold series reel will not retrieve line the motion is but the line will not wind around the spool
wrong type of knot at the start perhaps . A small bit of tape usually will fix that .
Posted on May 23, 2015
Tip
Best Saltwater Spinning Reel for 2016-2017
Now that you know a little bit more about what you're looking for in a saltwater spinning reel, you probably want to know what some of your better options are. So here is a list of ten of the best saltwater spinning reels currently available.
Saltwater Spinning Reel Archives Top Spinning ReelS
on Nov 24, 2016 | Omega Speedmaster Day Date 3520.50.00...
How to take reel apart to reload line
Hi Karen:
If this is a fishing reel, pull off the old line into a plastic bag or wind it on to an old spool so it can be safely discarded. Tie the new line on to the reel, and wind the new line on.
There used to be a closed face spinning reel that you would unscrew the face cover to access the spool.
If this is a weed eater, grass whip, some of the older units had a threaded centre with a left hand thread. Once unscrewed, the spool lifted off and you could wind on the new cutting cord.
Happy fishing, or gardening.
May 14, 2015 | Sport & Outdoor - Others
I have a Ryobi spinning reel SX4N,in excellent shape. Ineed to know how the springs go onthe bail to makr it work. Thanks
With the new line threaded through all of the fishing rod's eyelets, open the bail. You open the bail by pulling it over across the spool, until it locks in an open position. Tie the line in a knot around the reel's spool, and loosely wrap the line around the spool at least 7 to 8 times, then pull slowly on the line, to tighten the line that is wrapped around the spool.
Holding the box or spool of fishing line between your feet, so that it will remain close to you, start reeling in your casting rod. When you start reeling it in, the bail automatically closes, and makes the line wrap onto the spool properly. Reel the new line in until the spool is about 75% full, or to the lines marked inside the reel's spool. Cut the new line about 8 feet from the outer-most eyelet of your fishing rod.
Hope this solution has been helpful?
Jul 08, 2011 | Sport & Outdoor - Others
How do you stop winder from turning backwards
flip the switch that is located under the spool/body.
Jan 11, 2011 | Penn Spinfisher 7500SS Saltwater Spinning...
Drag automatically tightens as line is pulled from spool
Clean and grease the reel. Make sure all washers that belong on inside are installed properly
Oct 31, 2009 | Penn Spinfisher 950SSm Saltwater Spinning...
How to I fix a spin casting reel?
You should be able to remove the spool by removing the knob on the front of the reel which also is the drag adjustment. With the knob off the spool should pull right off. Hope this helps you
Oct 18, 2009 | Shakespeare Agility Spinning Reel 6825
May 30, 2009 | Penn Spinfisher 7500SS Saltwater Spinning...
Sport & Outdoor - Others Logo
37 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
