Question about Maytag Refrigerators
REPLACED WATER FILTER .LIGHT STAYS ON - Maytag Refrigerators
Press and hold the light and lock buttons and the same time for about 5 seconds.
Posted on Jan 15, 2009
Frigidaire filter status light will not reset
Check to be sure your water source is on. Low pressure may make the filter sensor think there is a plugged filter.
Mar 17, 2014 | Frigidaire Refrigerators
Wate Filter Light stays on after filter has been changed.
  • After changing your water filter you have to reset the light for it to go off as it does not reset right away.
  1. Just press and hold the "FIGHT" and "LOCK" buttons until the water filter light flashes. Now the light will be off.
  2. Don't forget to run a couple gallons of water through the new filter to remove any carbon out of the incoming water after installing a new water filter. This is not poisonous by any mean but it can leave a bitter taste in your mouth until the carbon wears off.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 20, 2011 | Maytag MSD2756G Side by Side Refrigerator
On this Frigidaire water filter system, there is a filter state light, wich was red when i bougth the frige second-hand, changed to green, when i changed the filter, normal, but it stays green, even after...
HI, if yours is similar to mine with ice maker and gets used several times a day my light comes on about every 6 mo. but i do have three kids so i use a lot of water. depending on use it could last 11 mos. but i would not go past a year if not used as much.
Mar 12, 2011 | Refrigerators
Red light stays on after changing the water filter and running about 2 gallons through it
Water Filter Status Indicator
Light (select models)
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Nov 27, 2009 | Maytag MZD2665HE Side by Side Refrigerator
Changed water filter red light stays on
you will wither have to push the light switch button 5 times or push and hold reset button or 2 at a time. Look at the display carefully it usually will tell you what you need to do
May 27, 2009 | Amana ARS2464B Side by Side Refrigerator
Afer you change the filter and have run the water for about 1 minute you then hold down the light & lock button together and this should turn the change filter light off.
Apr 23, 2009 | Refrigerators
Water filter light won't reset itself
look closely at the panel it will state which buttond to hold for 3 secs to "reset " filter light
Jan 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
135 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
