Question about Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue
Very loud screeching ,continuous when turned on
  • 710 Answers
Hi dfabin,
Does the screeching come from the motor area or the brush/belt area?
If it's from the motor. Turn it off. It needs repair.
If it's from the brush/belt area, most likely your belt is either slipping or rubbing on something.
Do you have an owner's manual?
If you do, and the noise come from the belts, take the belt(s) off and check them for wear, stretching, anything imbedded in them. Be sure to clean all debris out of the area. and reassemble. If still noisy, the belt may be slipping and needs to be replaced.
Here's a site where you can view the parts breakdown and order parts: http://www.vacpartswarehouse.com/Bissell-Healthy-Home-Models-5770-5990-6100-6405-s/600.htm
Hope this helps. If it does, I'd appreciate a vote. Thanks,
Handie Andie
Posted on Apr 03, 2011
Bissell vacuum model # 4104 Powergroom has loud screeching noise when turned on
most likely the belt check for obstruction on agitator(spining brush on bottom) 1st.if there is no obstruction you will need to remove bottom cover(usualy 4 to 5csrews to inspect rubber belt&replace if needed bypulling agitator remove belt&replace.belt may be purched at most stores selling bissel.
Apr 10, 2012 | Bissell Vacuums
Hi, my dc07 cleaner has developed a very high pitch screech its not a constant sound but intermittent and last for a second or two and is very unpleasent, its a loud cleaner anyway but this noise is so...
hi.
it sounds like the bearings in the motor are worn out. the only solution is to change the motor, or the entire hoover. motors are available from ebay for about £35 and it will then need to be fitted. unfortunately these bearings do wear out eventually. once they start to make screeching noises like this, there is not much life left in them, and they will get worse rapidly.
if you decide to change the motor yourself, please feel free to ask for more details on how to do it.
hope this helps
Aug 16, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
E2 gold series - makes loud noise on start up
That is normal. All E2 two speed Rainbows make that sound. It is because it has a brushless motor that the computer is controling, and the computer is controling everything. The motor rotor has no coils on it on the rotor, which is very small and light, and the computer gives it a small power boost when you first turn on, then increases the power until ir reaches full speed.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Jan 02, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Loud screech when engaging brush
you will need to have the clutch change or the brushroll replaced. to change the brushroll you will need a special belt tool. you can get one on ebey for about $15. you could call dyson and find one of the service centers in your area.
Oct 13, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Easy-Flo 1525 will not turn off
There is a relay back on the master unit. When the hose is plugged into the inlet the metal on the coupling completes the electrical circuit to the relay. In your case the coupling has a split and the circuit continues to the switch in the handle. As long as there isn't any conductive surface left across any of the contacts in any of the inlets, the relay is hung up. I never heard of that happening until today when I responded to the exact same problem on a different machine. The relay needs to be replaced.
The "screeching" on the other hand should have nothing to do with the relay. That sounds like a motor bearing without proper lubication and/or going bad.
May 22, 2009 | Easy Flo EF1400 Central System Vacuum
Kenmore Quick Clean loud whistling noise from air exchange
Sounds like you may have a clog or restriction somewhere in the vacuum.
Oct 08, 2017 | Kenmore 34720 Upright Vacuum
We have a Bissell Clearview Revolution #3595 and the motor when turned on Screeches, loudly, it does ****, just incredibly noisy we have already changed the belt
Sounds like a bad motor, part # 2032211It would cost around $60 for a new one. Did you check the brush roll to see if it is making alot of noise, if it is then replace it.
Nov 29, 2008 | Vacuums
Bissell Healthy Home HEPA Bagless Upright Vacuum - Metallic Blue Logo
296 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
