Question about Garden
Murray RT6000x92B tiller has huskey motor. Tiller works in forward, trying to put reverse belt on and can not figure out how it goes on, wondering if the guy who gave it to me switched some pulleys around, don't have a diagram to show how the belts go on
  • 3 Answers
SOURCE: New belts on Garden Star Tiller but now no neutral
It may be your belt tension or you may have the wrong belt it may be to short.
Posted on Mar 15, 2009
SOURCE: both belts shredded. Atlas garden tiller model 12 -5100
I bought a repair manual from Clymer and found the belt sizes for my Atlas 12.5022 tiller. The manual lists a 1/2 inch by by 36 inch forward belt and 1/2 inch by 32 inch reverse belt for the model 12-5100. Good luck. Don't bother to buy the Clyme manual. It isn't very complete.
Bob Mortimer
mortimer5918@bellsouth.net
Posted on Apr 27, 2009
rockitman187
  • 2559 Answers
SOURCE: what's the gas/oil ratio for CT 16 tiller
Husqvarna says 50:1
Here is a link to the break down repair manual for future use
I will send a link to the user manual when located.
Please rate this fixya solution
Posted on May 13, 2009
Typus
  • 69 Answers
SOURCE: Roper tiller 26 inch front tine Pulley/belt diagram
I am not sure either, but I think that it would be alot cheeper to buy a new tiller, than to use your strenght fixing a old tiller that you didn't bother to keep the instructions for (no, I am not trying to be harsh. I am trying to be nice. and I am not sure about it coming with instructions, they usually do.)
29259605.jpgSorry, that is the closest picture that I can get.
Here is a link that may help. (IDK, because it is blocked where I am at.) http://www.google.com/aclk?sa=l&ai=CqcKEPGEMSvvXJJyotgeEiOyLB_jqoUWYtdrOBMib0rsYEAMoB1DU-N7X_P____8BYMmOo4qkpMQRoAGUt9H9A8gBAaoEIU_Q6ppHU85NtRLlGbCSz8M4YQ7k6yZkGAMPo_XJ9i4rSQ&num=3&sig=AGiWqtyvlB5FasgaU109ezFuPnc-65WzHg&q=http://www.fixya.com/support/roper%3Fcmpid%3DG3372595023
Posted on May 14, 2009
  • 221 Answers
SOURCE: I have a MTD yard machine rear tine tiller. Goes
You will have to get into the gearbox. It isn't too hard but is time consuming. Sounds like the drive for the tiller has broken. Could just be the chain in the gearbox for the tiller drive.
Posted on Jul 01, 2010
The motor runs fine, it stopped tilling, and the belts do engage properly. What happened
Randy, The gear in the gear box may have sheared a key, or damaged gear. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Tiller Gearbox Trouble
Murray Ultra Tiller Tines Won Keep Spinning
Update Craftsman rear tine tiller repair stuck gears
Apr 23, 2016 | Garden
Transmission will not come out of reverse
what year is it does it have Belt Driven or chain drive ? do you put it gear with lever does it have handle to put it in gear ?is ther something stuck on the blades ? does it turn either Way ?
May 26, 2014 | Garden
The Tinds will not engage and I have problem getting the tiller in forward/reverse gear.
you need grease on your power shaft that has the forward/reverse this is where the power goes to the wheels slids back and forth A round wheel one side forward the other side reverse
Mar 24, 2011 | Yard Machines Tiller 208cc 18in Tilling...
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 | Mtd Garden
I just bought a used Pony tiller. It runs good, but after tilling for a couple no hours the forward and tines just stopped. Had not hit anything. It goes in reverse and the tines work in reverse, but I...
Check under the metal or plastic cover just behind the engine. This covers the forward and reverse belts. Your belt either broke, jumped off fthe pulley, or needs a tension adjustment.
Frank
Jul 04, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Tiller will not till in forward motion.
sounds like your drive belt is worn or the handle bar adjustment is too tall and your handle is not adjusted.
Apr 26, 2009 | Troy-Bilt Pony Garden Tiller
Looking for owners manual
I have a manual for the Wizard 5HP tiller. The reverse belt basically makes a figure 8
The belt goes over the motor pulley and over the idler pulley then makes a twist in the middle and around the bottom pulley. This cause it to basically rotate the opposite direction from the rotation of the drive pulley
Apr 05, 2009 | Garden
Pony Tiller (1985). Pull cord does not pull/frozen in machine.
see if the motor turns over pull the spark plug put some lubricant inhole other wise pull off pull cord assembly try turning crank becarfull not tobreak rings moveback and forth little bit at atime if it turns over check pull cord out
Mar 28, 2009 | Troy-Bilt Pony Garden Tiller
Both belts shredded. Atlas garden tiller model 12 -5100
Bob Mortimer
Mar 24, 2009 | Garden
Garden Logo
73 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
