Question about Numark ttUSB Turntable
Converting to itunes
My ttusb turntables was working fine and everything was going to itunes fine now when i'm done and convert it to itunes it won't play what i record it shows up but instead of show the time of the song it just says 789:57 and won't play the song
  • 515 Answers
Have you recently upgraded any software (iTunes, Windows, etc)
- OPTiC
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
Posted on Aug 08, 2008
Ringing when recording into mac
This sound like it could be somekind of feedback hum, or earthing problem. Check all the connections.
Mar 14, 2014 | Numark ttUSB Turntable
Www ionaudio com ezvc
Sounds like a formating issue. Itunes takes mp4's only. A PC usually works with mp3's or other formats. See if the software you are using offers you to record them into an mp4 format and that should fix it for you. If it will not let you record in mp4, you can download a simple device that can convert them. Honestly I thought ITunes converted them already, may be a setting in ITunes to convert as well! Good Luck, let me know if that isn't the issue.
Aug 26, 2013 | ION Audio iTTUSB Turntable
Numark PT-01 USB Portable Turntable EZ Vinyl/Tape Converter
Pull an old iTunes itl. Lib file from one of your older backups and use that to replace the newer iTunes itl. file
Nov 16, 2017 | Numark ttUSB Turntable
EZ Audio Converter does not export files to iTunes
I've had exactly the same problem, and so far no resolution from Ion. A small bit of good news: the .wav files are on the hard drive, although without any track info. At least on Vista, they are in username/AppData/Local/Temp. The files are name Temp0, Temp1, Temp 2, ...
You can use iTunes to add these files (File/add file) and then convert them to .mp3s, or whatever format you prefer. Or you could convert them first using the tool of your choice, such as Audiograbber.
This is inconvenient, but a lot better than re-ripping the vinyl after EZVinyl hangs.
Jul 25, 2009 | Numark PT01 Turntable
No sound from iTunes audio files
it sounds like EZ A C did not get the audio or EZ put it in a format tha Itunes Cant play. download VLC media player and install it. open the file with VLC and se if it will play it. It will play just about anything it has most of the codex's need to play anything too. if it doesent play it then something is wrong with the input to EZ A C you might have the input muted.
Jun 23, 2009 | Audio Players & Recorders
Need drivers for my ION Audio USB Turntable
Hello
USB audio turntable can be found on this site: Driver Update. have a nice day
Jun 22, 2009 | ION Audio iTTUSB Turntable
Numark turntable records record AND sounds in the room
the mic is in the computer somewhere, there will be a way to mute the microphone either in the vinyl software or in the system settings of the computer!
Jan 10, 2009 | Numark ttUSB Turntable
Playback Problem
They should be recording in mp3.  Then converted into ITunes using AAC.  Itunes will play MP3 format from the turntable.  The best thing to do is to record in that format, then test the files before converting them.  That way you can find out if the problem is with Itunes conversion or the turntable.
Oct 06, 2008 | Numark ttUSB Turntable
Numark ttUSB Turntable Logo
262 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
