Question about HP vs15 15"LCD Flat Panel Monitor
I can not change the res on my monitor from 800x600-57-hz to 1024x768-60hz the screen tells me that 1024x768 is recommend but I can not figure out how it is done. Please help if you can.Thank you
    President:
  • 1,623 Answers
You need to change the res on the computer then it will change on the monitor
Posted on Apr 03, 2011
Tell me what is samsung syncmaster 794 default setting
The maximum resolution supported is 1280 x 1024 pixels at 65 Hz refresh rate, while the recommended resolution stands at 1024 x 768 pixels at 85 Hz. However, the maximum usable resolution is 1152 x 864 pixels at 75 Hz. Maximum usable resolution signifies the maximum resolution supported by a monitor at a refresh rate of 75 Hz or better. Though 85 Hz is an ideal refresh rate, 75 Hz is the lower limit. Any refresh rate, lower than 75 Hz, will give a flickered output and can cause some serious eye damage after prolonged usage...i hope this helps.
Aug 29, 2011 | Samsung 793DF 17" CRT Monitor
When i try to change to res it says out of range. it stays at 800 x 600.
Max Sync Rate (V x H) 76 Hz x 83 KHz
Max Resolution 1280 x 1024 / 60 Hz
Try changing the Hz to get it to accept a higher res.
Dec 02, 2010 | HP vp17 Monitor
I am getting a message traveling across my screen that says, "Input Signal Out of Range." Then, after about 1 minute I get a "going to Sleep" message, and the screen goes into sleep mode. I keep having to...
that message means, you have the unstated PC, set to a super high resolution, that is totally ******* on this old screen,
buy a newer screen,
or change the resolution.
no PC stated , at all. model , is it HP?
no OS stated, if XP hit F8 and run safe mode and lower the resolution to 1024x768.
only these work,,never higher.
1024 x 768 / 60 Hz
1024 x 768 / 70 Hz
1024 x 768 / 75 Hz
800 x 600 / 60 Hz
800 x 600 / 72 Hz
800 x 600 / 75 Hz
640 x 480 / 60 Hz
640 x 480 / 72 Hz
640 x 480 / 75 Hz
832 x 624 / 75 Hz
720 x 400 / 70 Hz
Aug 28, 2017 | Compaq FP 5017 15" Flat Panel LCD Monitor
How do i fix my blurry fonts problem on the computer ? i reformat my computer and there are blurry fonts.
fonts ar blurry because u had selected incorrect screen refresh rate select proper config right click on desktop goto properties now display property dialog will be show click on settings click on monitor change trefresh rate select 60 hz if res is n1024x768 or more and 85 if its 800x600 or less
Jul 09, 2010 | Computers & Internet
I have a Samsung SyncMaster 901B, it's not new, a friend gave it too me, i connected it to my computer,i start the computer, it works fine until windows finishes loading, then the screen goes black and i...
What happen when you hook this monitor up to other PC that has the video setting 1280 X 1024 60 Hz? Just ant to narrow down the problem before opening up the monitor. You may have logic problem in the logic board. If it does the same with other PC, then open it up and inpsect the inside for such thing as failed caps on the logic board or on the main power supply board, I think more likely to be ROM chip on the logic board is scrambled.
See typical failed monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 30, 2010 | Computers & Internet
VIDEO PROBLEM
HAVE YOU TRYED CHANGING YOUR RES ?FOR A MONITOR THAT SMALL YOU MIGHT WANT TO CHANGE TO A HIGHER RES AND NO PATCH OTHER THEN CHANGING THE MONITOR
Mar 09, 2009 | Electronic Arts Harry Potter and the Order...
Samsung sync master 510 monitor display problem
It may be that the LCD monitor will not display all screen resolutions so you may need to change your resolution to match the desired resolution and refresh rate of the LCD. In your case the computer should be outputting:
1024x768 pixels
60 Hz
You can change these settings by right clicking on the desktop and clicking properties and they're under the settings tab. Change the screen resolution by moving the slider to the recommended setting (1024x768)
and
under the advanced button click the "monitor" tab - make sure the screen refresh rate is set to 60 hertz (60 hz)
May 21, 2008 | Samsung SyncMaster 510N 15" LCD Monitor
Acer will not run 640x480 screen res
It probably will support. It most likely gives this message because the refresh rate is too high when it switches to that resolution. An LCD monitor runs best at 60Hz. I'm currently on a mac so I can't recall clearly the PC steps, but I believe you can right click on the desktop to get a menu. Click on Properties. Then click on the settings tab. In there you will see an advance button. Then a new window will open with more tabs. In there I think the refresh rate is in there maybe in the monitor tab. This will although, probably only change the resolution you're on. But if you have an extended driver support for your model, you may also have a list somewhere of the Refresh Rate Hz for different resolutions with out having to change the res in order to change the Hz rate. ALSO - in game settings or menu options somewhere of the game, there might be a Refresh Hz Rate somewhere. Confusing enough?? :-)  I know you'll figure it out, I only hope this helps a bit. - Scotty
Apr 30, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Not optimum mode
change windows resolution and refresh rate to 1024 X768 and 60 Hz.
start->control panel->display->settings-> change the screen resolution to 1024 by 768 pixels-> advanced-> monitor->change refresh rate to 60 Hz-> ok-> yes -> ok.
Mar 03, 2008 | Samsung 710V 17" LCD Monitor
A_turkovsky@yahoo.com
ya u enable vga mode hit f8 at start up in xp select vga mode ok resets u then use 60 hertz man and its native res ok only update drivers ect mark me ask fit ya ok thx nick
Feb 08, 2008 | ViewSonic VX1935wm LCD Monitor
HP vs15 15"LCD Flat Panel Monitor Logo
55 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
