Can i connect my lap top to a tv with a vga to rga lead
    Genius:
  • 1,479 Answers
I think you mean rgb to rca and the answer is yes, BUT, the tv must be able to display the resolution output of the laptop (800x600 or whatever else you can set it to). You will also need an audio kead from the laptop earphone socket to audio in on tv.
Posted on Apr 03, 2011
  • Computers & ... Master
  • 27,725 Answers
Yes you can do this but you will have to change the settings in the control panel to an extended desktop once you have this lead connected click start control panel display change display settings you should a no 1 and a no 2 with detect and identify keep an eye on the television screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended tesktop always click apply after making any changes
hope this helps
LAP TOP CONNEECTION WITH VGA CABLE
Check the cable first. Connect it with an other RGB cable, and check. It wounds to be a cable fault.
Jul 01, 2013 | Televison & Video
Hi i need to know what cable i need to conect my lap top to tv ? my lap top is a dell latitude d610
Depends what your TV supports. You could do vga to hdmi cable if your tv is newer, this will only do video since vga doesn't support sound. You would need a headphone jack to whatever your tv supports for sound adapter.
Dec 29, 2011 | Computers & Internet
Can i hook my lap top up to this tv to get netflix? How?
Hello
This model CRT tv cannot be connected directly to lap top. Laptop has VGA output and there is no VGA input to this TV. Tv has only AV sockets to connect in. You must have a VGA to Audio Video converter to be used in between TV and Laptop. This device can be bought from electronc shops. It will have a VGA input, and audio video output. You have to connect your laptop to this device using a VGA to VGA connecter, and from this devices' output, you will get audio video output, which can be connected to TV and select the TVs' input to AV. OK.
Jun 03, 2011 | JVC AV-27F702 27" TV
How do I Connect a Dell Latitude E6500 to a Sanyo Television
Check your ports on the lap top see if you have s video or hdmi or dvi or VGA the best is hdmi if you have that get a cable for either one of you connections also match connections from the lap top to what you have for your TV more than likely if they are both fairly new you should have hdmi connections for both get a cable that is long enough. I get my cables at amazon.com their prices are the bomb.
Connect them together both ends to lap top and to tv then make sure that you have a line in jack stereo jack with RCA ends hook that to the back of your tv and your lap top in stereo jack even better to your surround sound system. Set your TV to AVI 1 or 2 or DVI or whichever is your connection start a movie on the lap top and turn your sound on and see if you have a picture on your screen you should have the same thing as what is showing on your monitor on your lap top. Adjust settings and have fun!
Jan 08, 2011 | Dell Latitude E6500 Laptop
Trying to connect my inspiron 15 to my toshiba 32af44 and i can't get a picture on my tv. I have bought a pig tail that goes from VGA(the lap top side) to s-video/audio-video cables(tv side) but still...
A simple pigtail won't convert VGA to S-video. The VGA output consists of separate RGB lines and horizontal and vertical synchronization lines.
If you have an adapter that really converts VGA (this output has no audio path) to S-Video and audio lines, then you probably just need to re-select the input through the TV's menu system.
Nov 21, 2010 | Toshiba 32AF44 32" TV
I have a samsung lcd tv and am trying to connect my lap top through an hdmi lead. The tv shows an error that there is no signal. I have followed the instructions shown in the tv manual and have changed the...
Does your notebook have HDMI or DVI outputs? If no, then use standard VGA cable, which is supported by this TV and quality is fine also on 1920x1080 resolution. Also for VGA input on TV you can use almost any resolution the notebook supports (for HDMI only few resolutions are supported).
Oct 05, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
How connec my lap top to my tv?
if your laptop has vga output and your tv has vga input then connect vga output to vga input on the tv with a VGA cable that simple. With no real information onverning model numbers - i cant tell you what else you need to do.
Jun 30, 2009 | LG 42LC2D 42 in. LCD HDTV
No RGA input detected
through the Remote .. press menu .. and make sure that the VGA output is one that the Monitor can handle (if LCD 1280x1024) ... lower the refrech rate or definition until the monitor 'sinc's
Sep 26, 2007 | V-Stream Xpert 1280x1024 LCD TV Box...
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
