Shut down my Acer 2480 wrong by pressing the power button. Now it doesn't reboot or boot up. I tried to pressing F2 to reboot but it doesn't do anything. Any suggestions?
  • doggone_deli Apr 04, 2011
    Thank you for the advice. It worked perfectly!!! You guys @ Fixya are AWESOME!!!
    Sergeant:
  • 236 Answers
Look at the power indicator:
If it is not lit, no power is being supplied to the computer. If the computer has a battery, it may be low and unable to power the computer. Connect the AC adapter to recharge the battey pack and make sure the AC adapter is properly plugged into the computer and to the AC power outlet.
If the power indicator is lit, check if a non-bootable (non-system) disk or USB thumbdrive is in the computer. If so, remove it and press Ctrl + Alt + Del to restart the system.
Pressing F2 by itself is only used to enter the system's BIOS on startup. If the power indicator is lit but nothing appears on the screen - The computer's power management system automatically blanks the screen to save power. Press any key to turn the display on.
If pressing any key does not turn the display back on, check the following....
1. The brightness level might be too low. Press Fn and the right cursor key to increase brightness level
2. Display device might be set to an external monitor. Press Fn and F5 to toggle to the internal display
3. Backlight might be turned off. Press Fn and F6 to turn on the backlight.
4. If the Sleep indicator is lit, the computer is in Sleep mode. Press & release power button to resume.
Posted on Apr 04, 2011
My aser aspire say the oprating system not found but the hard disk has the oprating system and ot works properly what can i do to fix this and how can i enter in bios mode
Shut down your Acer Aspire if it is running. Once the computer is off, press the power button to start it. Press "F2" immediately while your computer is booting up and displaying the "Acer" logo. Keep pressing "F2" until the BIOS Setup screen appears.
Aug 16, 2016 | Aspire Computers & Internet
Tip
To Reboot or recovery from CD/DVD problem with OS "Aser"
If you don't press the Alt+F10 key combination or use the recovery CDs, can you get into Windows? Boot with the recovery CDs in. When at the Acer logo during POST, press the F12 key. Then, select boot off CD or DVD. Alternatively, you can enter the BIOS by pressing the F2 key at the Acer logo and go to the Boot tab. There, you can set the CD/DVD drive as the first item in the boot order.
When turning your laptop on, before Windows starts booting, a splash screen appears first (usually with the logo of the manufacturer). Look on the splash screen (usually at the bottom) for a key (usually F10 or F11), assigned for System Recovery. Some manufacturer(s) (e.g. HP) place the recovery files to a hidden (mostly) partition of the hard drive, the others give a Recovery CD/DVD with the laptop.
or
  1. Press the start button from the start menu depending on your operating system(win 2000,xp)
  2. Press Ctrl+Alt+delete combination from the keyboard.
  3. If you have a power button on your laptop keyboard,it could also be useful by pressing and hold it down for few seconds
N.B: "Ctrl+Alt+Delete" can exit you from usage and trigger a reboot
or Shutdown. Try and reboot using the operating system. Attempt to use the key combination that will allow you to exit from the operating system and restart the laptop. Be patient, as it may take some time if it has locked up. Hold down the power button. If the operating system's answer to the rebooting will not work, find and hold down the power button of the laptop. This should cause the device to shut itself off. You'll have to press the power button again to power it back on, completing the reboot.
Unplug from the wall and remove the battery. If restarting via the operating system and the power button do not work, unplug the laptop from the wall outlet, and remove the battery from the laptop. This will cause it to power off immediately. Allow time to reboot. Give the laptop time to cool down before you power it back on if you had to do this manually.A few seconds should do unless you have additional problems.
All the Best!
on Sep 13, 2010 | Computers & Internet
My acer aspire 1 725 wont load due to errorcode 0x00000f and cant get into bios to change boot options how do i fix this problem
Shut down your computer completely. Once it has been turned off, press the power button to the "On" position to restart the system. Within the first 10 seconds, press down and hold the F2 button for about three seconds and then release it. Within five to 10 seconds after pressing and holding this button, you should see the BIOS setup screen on the monitor.
Dec 30, 2013 | Acer Computers & Internet
My netbook keeps returning to start win normally
try to go to the BIOS setting by pressing F2 or del while in POST (exactly after you press the power button and the screen is on)
try to set the BIOS to it's default setting,save & exit,restart your computer
if it still doesn't work,go to BIOS again and look for something called "boot device priority". it usually placed in advanced settings
then set your hardisk as your 1st boot device. save&exit,restart
Aug 19, 2012 | Acer Aspire One AO532h-2727 Netbook
How do I get my Acer travelmate 2480 to reboot when I do the steps it doesn't work. A screen showed up and said reboot and press f1. Then the windows. XP shows up.
What happens when you press the power button to boot it up?
Is the system hanging and not rebooting? Try running the check disk utility?
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 15, 2012 | Acer Computers & Internet
Acer aspire one netbook was working fine now it won't start up. the previous night I had used the computer until the battery died. when I restarted it the following day it initially opened with the...
In order to recover the Operating System using Acer Recovery Media please perform the following:
  1. Press the F2 key to enter BIOS Setup during Power-On Self-Test (POST while the Acer logo is being displayed).
  2. Using the keyboard arrow keys, arrow over to Boot.
  3. Refer to on screen instructions to set the first device to CDROM.
  4. Press the CD-ROM drive eject button and insert the System CD.
  5. Close the CD-ROM tray.
  6. Press the F10 key, and then the Enter key to save the changes and reboot the system.
  7. The computer will boot from the Acer Recovery Media, follow the prompts to reinstall the Operating System.
Note: If you do not have a set of Acer Recovery Media they may be purchased at our online Acer order form..
Oct 28, 2010 | Acer Aspire One Netbook 8.9" Notebook
Getting message bootmgr missing press ctl alt del, but when i do this nothing happens
try this.. reboot your computer, or hold down the power button to shut it off then turn it back on, at the acer splash screen hit f2 to enter into setup. hit f9, load setup defaults and exit. it will reboot your computer and should let you in.
Oct 10, 2010 | Acer Aspire 5536-5224 Notebook
My Acer Aspire One boots up but only runs for 5 seconds then click, and it goes blank. It has a charged battery and does this even when plugged in to the charger. I have tried to boot it up using F2 and...
hi there,
use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that’s important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn’t reboot by itself wait 5 minutes before turning it off, just to be safe that it isn’t still flashing the BIOS.
Jul 11, 2010 | Acer Aspire One PC Notebook
Acer shut down
ok go to control panel, then power options and check that the option states that when you press the shutdown button, it powers down. You also may need to check inthe bios (F2 or Del on boot up) and go to standard cmos settings or the advanced cmos settings and see if ACPI is enabled, if not enable, then save settings and exit and a reboot will follow.
Apr 25, 2007 | Acer Veriton 5600GT PC Desktop
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
