Question about Garden
I have a rider mover with a Techumseh OVH 130 (13 HP) with electrioc start. I thought it was the starter but the starter engages but can't move the crakshaft. The batter seems fully charged. Does this seem to be the starter or the enginee? I tried to rotate the engine but hand but it does not do more than a 45 degree turn. As I try to turn it I hear some metal scraping and suspect that it may be a metal malfuntion inside the block. Should I be able to manually rotate the crakshaft or will it only turn so far? I looked on-line for a replacement unit but I am thinking this might be not in production any more. THe complete model munber is OVH130 2068 10C Engine family is WTPXS 3582AA with a 358 displacement. BIll Lanctot
SOURCE: Stalling Briggs & Stratton engine
Try taking the air filter off ,start the motor and try it. If this works replace air cleaner element
Posted on Oct 05, 2008
thabrain
  • 76 Answers
SOURCE: murray riding lawn mower
with switch off try crossing out the solenoid. take an old screwdriver and place it on the two metal contacts jetting out from the solenoid usually by the battery or close to the ignition. if strarter engages when this is donr replace solenoid. if not replace starter. hope this helps.
Posted on Oct 28, 2008
  • 12 Answers
SOURCE: 2004 Kia Sedona wont start but i can hear starter.
if the starter is revving very slowly it is the battery, charge battery. if not, It can be three things happing. 1 no spark 2 no fuel 3 no crank signal or the car computer is bad- you will need to unplug one of the spark wires and remove the spark plug and put the spark plug in the spark plug wire boot, and touch the spark plug on any metal on the car and have some start the car. donot touch the spark plug itself and see if there is a spark. if spark is bright, then it is not spark plug and wires but if no or spark is not bright, check the spark plug wires by applying a little bit of water on the spark plug wire and take a 12v test light, connect the clap to ground and and have some one to crank the vehicle, touch allover the spark plug wires with the tip of the test light, if you see spark, replace the wires and change the plugs.. they are not good. if spark is present, check for fuel by removing any one of the spark plugs and see if it is wet. if wet fuel pump is ok but if not go look for the fuel pump fuse and relay. is fuse blown, replace, check the relay resistor with a volt meter. it should be around 40 to 80 ohm. if everything is good from this point check the fuel pump itself by disconnecting the connector to the pump and apply 12v and ground using jumper wires or some wires to the fuel pump if you donot hear the pump,replace pump. if you, the crank signal or computer may be the problem
Posted on Jan 02, 2009
  • 1388 Answers
SOURCE: My briggs&stratton ohv 17 hp electric starter will not turn over
I worked at a tool rental center while attending college and encountered the problem that you are having many times. The problem was caused be a variety of issues however can be determined by checking the following:
Worn starter motor bearings that would be indicated by higher than normal amp draw. Check for hot starter motor or hot cables.
Weak battery. The battery should be removed and tested for free at auto parts store. The battery should be replace every season to extend the life of the starter motor.
Belts or hydraulic pump that is not fully releasing from engine pulley or output shaft. Remove the spark plugs from the engine and tune engine by hand, it should turn rather freely.
Finally, compression release feature of engine is not working properly. Check engine service manual for proper adjustment of valves so that compression release will work. Finally check oil level for over full. Too much oil will raise compression. Good luck with your problem and email for more info.
Posted on Feb 13, 2009
  • 190 Answers
SOURCE: cylinder head torque specs
Cyl. Head Bolts torque
200in.lbs
16.5ft.lbs
22.5Nm
Posted on Mar 26, 2009
Put new solinode and starter on LT 160 and starter stayed engaged after starting whst did ivdo wrlng? csn the 2 wires on solinode be reversed?
Is this a lawn mover?
I tired to look at your starter motor, it appeared to show only one terminal. Should not be hot with key in the run position. The starter driver gear isn't hung-up?
So there is a separate solenoid/relay? Did you wire it back the same way? It would have to receive signal from ignition switch crank position. I don't have a wiring diagram for this.
Apr 15, 2017 | Cars & Trucks
Have a craftsman EZ3 917.272121 mower engine e stalls when blade switch is pulled
If you are sitting on the tractor seat and the engine stalls when engaging the PTO mover blades I would check the switch under the seat.
This seat has a saftey switch to assure that the operator is in a safe location before engaging the the blades. Also if the blades are engaged and the operator leaves the seat the blades will stop. If a young rider with insufficient weight the blades will not engage.
26147998-f1dbbl4o5m3nghfc10hihvyr-4-0.jpg Hope this helps?
Mar 31, 2016 | Craftsman Garden
HOW DO I AJUST MY GOVERNOR ON MY 10 HP TECHUMSEH
This is a great place to start donyboy73 on youtube does pretty thorough set of videos on these
Feb 16, 2015 | Tecumseh Snowblower Snow Blower Starter...
I have a 2004 Dyna Low Rider. I just replaced the battery, and after a short ride, I was opening garage door, left it running and propped it on kickstand. Heard a small rattle as I walked away. Returned...
Sounds like the solenoid relay is stuck up and shorted your starter! Better check the starter, pull it down and look if the bendix drive is still intact, upon driving and engine is running the bendix drive is still engage, thus it might have broken and loosen up.
If you can't repair it, a mechanic can certainly repair it, hope that bendix drive is still okay, if damage is already done, just replace that part. The solenoid that gives power and pushes the bendix drive is at fault, better check that too, it is the first one that malfunctioned and damages the bendix.
Hope that helps you out!
thanks for using FixYa!
Jul 03, 2011 | 2004 Harley Davidson FXDL - FXDLI Dyna Low...
17 hp 42'' rider with hydrostat with hand controls wont move.... mis their oil in the rearend?????? or what else could it be,the belt is on
mowre will start but will not go into gear shaft will turn but not engage how can i get to trany without complete breakdown of *** end
Jun 27, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
20 Hp 42" Deck Lawn Tractor: I have a craftsman rider that starts idels and dri...
sounds like one of the pullies is locked up . check all the pullies for free movement the plastic pullies are junk. replace with metal ones if you find a bad one.
May 17, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have 13.5 hp White Tractor that will not start. I replaced the battery because I thought it was bad. The Starter will crank once but not turn engine over. I jumped the 2 large post on the solenoid and...
Yes Will the engine turn over if turned by hand ? If so it probably is you starter that needs work on. You replaced the battery but are you sure it is fully charged? These are things to check before spending a lot of money.
Dec 29, 2017 | Mtd LAWN MOWER PART # 683-04163B FRAME...
IV A PROBLEM WITH MY 91 SUZUKI DR 650 I JUST FITTED NEW STARTER CLUTCH AS I THOUGHT THIS WAS MY PROBLEM BUT IT ISNT,WHEN YOU HIT THE START BUTTON TO START THE BIKE THE SPROCKET BEHIND THE FLY DOESNT SEEM...
Sounds like your starter solenoid is not engaging. Try tapping it with a dead blow hammer or a hammer and block of wood (gently! Not to hard!) If it bumps over that is your problem. Also check all connections to solenoid and starter.
The whirring noise you are hearing is your starter motor but your bendix gear is not engaging.
Hope this helps!
Rob
Sep 21, 2009 | 1990 Suzuki DR 650 RS
1999 silverado clicking but not starting
Might want to chg. the starter switch under dash, sounds like its shorting out or something and keeping the starter engaged, try starting it in neutral and see if it does the same thing. I am not sure if the starter switch and park neutral switch are one in the same or not, but i'am thinking they are, that would account for the starter drive kicking out of the engaged position when you move the shift lever. Also make sure your connections to the battery are clean and tight.
Mar 20, 2009 | 1999 Chevrolet Silverado 1500
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
