Question about Mitsubishi WD-52628 52" Projection HDTV
Problems after power outage
I can turn on the TV, but after that it won't respond to any buttons on the remote or on the pannel. Then if I try to shut it off, it won't, until about 15 seconds later when it just shuts off itself. I tried pressing the system reset button, but it doesn't work.
I figured out I could still get the TV Menu so I pressed that and then I pressed 123 and it did a TV reset and then it was working again.
Posted on Aug 06, 2008
Toshiba television won't turn on after power flicker
Free Fix For Toshiba 50" TV That Will Not Turn On. - YouTube
? 2:20
https://www.youtube.com/watch?v=8-0nQ57Bvow
Mar 21, 2012 - Uploaded by rstarre ten g
My flat screen tv cuts off and on while the power but is on what should i try before i buy a new one .... I have a ...
Toshiba TV power outage - AllExperts
en.allexperts.com > ... > TV/VCR/Stereo Troubleshooting
Feb 3, 2011 - TV/VCR/Stereo Troubleshooting/Toshiba TV power outage - no power... we had a power outage (they're calling rolling blackouts due to power grid ... but I admit I'm now afraid to turn it off for fear it won't come back on again.
Toshiba 32c120u LCD TV won't turn on - Tom's Guide
www.tomsguide.com/answers/id.../toshiba-32c120u-lcd-turn.html
May 27, 2015 - My toshiba tv is flashing but won't turn on with remote or power botton on tv itself ... dang this worked for me but after a minute it stoped working.
Dec 28, 2015 | Toshiba 58L7350U 58" 3D 1080p LED-LCD TV -...
Hitachi 55vf820 problem
Most likely the buttons on the tv are stuck or malfunctioning, replacment of the button pannel will solve the issue
Mar 17, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Sceptre tv won't turn on after power outage
You may have to open it to see if the line fuse that the power cord goes to is good or bad.
Dec 23, 2012 | Sceptre Televison & Video
Power button only one that won't turn power on
Have the remote tested either with a tester that most shops have or in a dark room with a digital camera the display will faintly flash when remote pointed at it and buttons pressed.
Also if button does not work (power) unplug the set for a while to see if it will reset. If the tester shows same problem--no working for power or have to press ******* buttons 99% chance something got spilled onto remote and got inside
Oct 24, 2012 | RCA TruFlat 27F520T 27" TV
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Mar 21, 2011 | Mitsubishi Televison & Video
My TV remote comtrol will not work when I try. I need the code.
Hi.
Manual Programming:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device.
3. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) until the POWER INDICATOR illuminates. The remote control is in programming mode.
3.Press and release power button. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
3. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on.
4. When the device turns on, press OK to store the code.
5. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Codes for orion TV are
096,10,146
Thanx
Jul 27, 2010 | Brookstone 538744 Remote Control
Power Outage Problems Sony Bravia 32" LCD TV
try cycling the power (unplug 2 minutes) and plug in and wait 30 seconds and turn back on. if this doesn't work, could have been a surge, your protector should have saved it, but could have been through cable or something. surge protectors will guarantee no damage for several years, check with the manufacturer maybe they'll cover the repair.
Jun 01, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Tv not responding to remote or buttons on tv
Well okay!
couple of questions?
1) Is a multi remote - does it or can it control other components like a DVD player or a VHS or Cable box?
2) If it does - you may have selected one of these other components to control
NOTE: Try depressing the TV button and then try the other buttons such as channel or volume to see if it's back working.
Blessings,
A/V Guy
Nov 19, 2009 | Element Electronics FLX-2210 22 in. LCD...
My remote is not responding to the tv even i have changed the new baterry
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Samsung BN59-00599A Remote Control
Mitsubishi WD-52628 52" Projection HDTV Logo
128 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
