Question about Gateway Computers & Internet
Pc turns on then goes to orange lite on monitor
    Problem Solver:
  • 19 Answers
Simple stuff first - power and connections to monitor good? Anything at all displayed as the machine is switched on? Yes: can you access safe mode (F8 when windows starts), if so enter windows and right click on desktop and choose properties, change display resolution to 1024x768 for example. No:
Any work inside the machine you should disconnect power first and preferable earth yourself when you are touching the boards.
Video card (where the monitor is connected) is seated correctly. Take out and put back in.
Try another monitor and cable to ensure these are working.
Check you have the 12v cable connected to the motherboard from the PSU. It is an additional cable that is required on some motherboards and can prevent display.
Does the motherboard make any beeps? Just one is good, more is not.
If you only get one beep and you have checked all above, then maybe a problem with video card - is it a separate card - see inside in slots where your monitor cables are plugged in. Could be loose, need reseating.
Best of luck
Posted on Apr 04, 2011
I have a gateway sx2865-ur308 and it powers on but screen so t come on
Did you make sure that everything is plugged in correctly? Are you sure that the monitor power cord is plugged into the wall and is receiving power? those are one of the signs that the power cord or the cable to the desktop is not plugged in when you are not able to see the monitor and the light at the bottom of the monitor is not lite up. If it is lite up and it is green and it still does not show your operating system when you turn on the computer, then it is more than likely your video card. but if your monitor is plugged in and the light at the bottom is orange then it is the monitor that needs replacing.
Jun 02, 2014 | Gateway SX2865-UR308 DT.GDPAA.001 Desktop...
Dell 8200 green power lite comes on green hard drive lite off
Check your fans o see if they are running and if the PC isn't getting too hot because that will cause it to stop and not boot up.
Dec 29, 2009 | Dell Dimension 8200 PC Desktop
Viewsonic VG700b bug
The light turning to orange means the monitor is not getting a signal from the computer. Check your monitor cable at both ends and make sure it is in very tight and secure at the computer end as well. Also check to see if the computer stays on when the light goes to orange on the monitor. The power cord for the computer might be loose.
May 20, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
NEC 17'' Multisync CRT monitor does nothing when turned on
the green is working ok but orange is usually waiting for an input from the pc (no input signal)
Mar 08, 2009 | Computers & Internet
DEAD IIYAMA AS4636D
Hi Sammy7!!
I have such iiyama AS4636D monitor. In this day purchase.
I have such problem with you.
My solution:
Desktop pc and lcd power off (230VAC or 110VAC)
Power on lcd, after early desktop pc.
This moment, when running the pc booting, press and hold you the " + " button.
In this moment come in one blue screen. May be running on the sreen short message: check or select input mode: VGA DVI 1 2 . Select your correct cable connection type.
Have a nice day! and happy new year!
Lajos from Hungary
Dec 13, 2008 | iiyama Pro Lite AS4636D (Black) 18.1 in....
1511 TLXB used as PC Mon
You have to use the TV remote to access the set menu.
From there, you can set the TV to monitor mode.
Jun 17, 2008 | Polaroid 1511-TLXB 15.4 in. LCD Television
Screen suddenly goes blank
when you open your pc now,do you still hear a click sounds like you hear before ,when your computer has no problem yet? now there is no sounds .do the ff..
1.try to press the numlock key and observe it ,if the indicator LED lite on and off,the problem of your computer is your video card,
2.if you can't hear anything, when you open your unit and the indicator of your monitor goes the color orange,pls..check your memory .clean the memory and the memory slots using the contact cleaner .before you replace a new memory.
3. and try to use a another monitor,maybe your monitor has the problem.
Apr 01, 2008 | Samsung SyncMaster 551 15" CRT Monitor
No display
if your monitor is not connected to a pc, then it cannot find a vga signal input and therefore go into power saving mode, which is indicated by the orange light, but as soon as you connect to the pc and power on the light will go green and the monitor will power up.
May 07, 2007 | BenQ T701 TFT 17" LCD Monitor
Computers & Internet Logo
43 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
