Question about Ingersoll Rand Ingersoll-Rand IR 315 Heavy Duty Air Twin Piston Inline Sander
After a minute my IR 315 slows down and bairly moves and starts working as if something breaks free it does this over and over . my air is not the issue ive got plenty of pressure
How to assemble an ingersoll rand sander 315
Gear timming in line sander
The above link may help as the unit is similar to the Central Pneumatic Straight Line Sander
Mar 02, 2015 | Ingersoll Rand Ingersoll-Rand IR 315 Heavy...
Hotpoint 1100 banging very loud when spinning,can thi be repaired please?
the chances are its the bairings in the drum that have gone,can you move the drum towards and away from the door easily? if so its prob the bairns,just like on a bike wheel they make the drum spin free but if they break it wobbles out of true causing problems and loud noise
Mar 19, 2013 | Hotpoint Washing Machines
Hello brothers i have Suzuki Reno 2007 ...few days ago the shifter was not coming out of park and brake lights was not working ..i was pressing the shift lock release button to move the shifter out of park...
You may have a fault with your number 2 lambda sensor. You need to get the fault codes checked to see if there Is any faults stored on the ecu.
If this helps let me know
Cheers
Dec 31, 2012 | Cars & Trucks
In my toyota yaris, when i use breaks in low speed my car goes slightly forward, then breaks works.
Check the condition of the pads, disks, and operation of both. They should be freely moving.Also check that your brake lines are free of air and that your fluid is clean.
Also check that the vacuum line to your brake servo is intact, and that you have adequate vacuum to your servo.
Nov 18, 2012 | Toyota Yaris Cars & Trucks
1987 el camino power windows moved very slow then stopped working 2 days later started working again very slow now they stopped completly. HELP!!!
There may not be enough power going to window switches.Remove and test with volt meter.You might have to remove door panels and lubricate all the working (moving) parts.After several years the factory lube breaks down.I hope this will help you.
Jun 15, 2011 | Chevrolet El Camino Cars & Trucks
A/C starts up/Cools/Fan Slows, Unit Shuts down in 4 minutes
Ensure proper voltage to the unit. Check for overheated/damaged wires and/or connections in the control panel as well as at the fan motor and compressor.
Apr 03, 2010 | Dometic Rooftop RV Air Conditioner
Breaks will not work at random times?
YOU HAVE A BAD MASTER CYLINDER
HAVE IT REPLACED AHD YOU PROBLEM WILL GO AWAY
Mar 02, 2010 | 1995 Toyota Camry
2002 tahoe breaks lock up during driving
i would check front and rear brakes if rears are drum brakes i would inspect springs and hardware making sure everthing is conected and in place also make sure they are adjusted properly in the front and if rear disc i would make sure to grease caliper slides these allow caliper to move and its important that all moving brake parts are free push caliper pistons in alittle to see if they are sized or not booster is ok and most of the time when master goes it will leak where it meets booster and you will have a low brake pedal or no brakes
Mar 31, 2009 | 2002 Chevrolet Tahoe
Engine light flashes
it is the catalist that is obstructed,the stone is broken inside,by temp it fails to let enough air through,
or replace,or open,break out one part for better air stream and weld closed again,
Feb 13, 2009 | 2002 Volkswagen Passat
SLOW SPEED MISSING AND POOR IDELING
Your I.A.C.(idle air control) needs service either its dirty or needs replacing.
Jun 24, 2008 | 1990 Chevrolet Cavalier
Ingersoll Rand Ingersoll-Rand IR 315 Heavy Duty Air Twin Piston Inline Sander Logo
73 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
John Trevino
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
