Question about Weber Spirit SP-310 Propane Grill
The middle burner doesn't lite and can be removed easily by hand without a screwdriver
  • 43 Answers
Www.ibuygrillparts.com for all your burner, igniter, grids, etc!
Posted on Apr 25, 2011
The top burner {broiler} workes OK. The bottom burner doesn't lite at all. Both glow plugs [liters ] work fine.
ould be the thermocouple or sensor senseing the ignition. more info would help
Feb 12, 2013 | Kitchen Ranges
Jandy Lite 2 igniter replacement how to
go in through the bottom follow the two white cloth wires either bottom center or right side bottom on burner
Jul 21, 2012 | Jandy Lite 2 Natural Gas Pilot Light...
Jenn- Air rotisserie burner wont lite. Doesn't
Try removing the cover on the back of the grill hood and finding the orifice for the rear burner. Check to see if the orifice is plugged.
Jul 31, 2011 | Jenn-Air Grilling
My son took game out of console without powering off now screen is frozen and I cannot even power off have tried other games screen stays the same
Hi.
You will need to remove the battery to get the DS Lite to turn off.
Get yourself a Philips screwdriver and a small flat headed screwdriver, then close the lid on the DS. Next turn the DS upside down with card slot facing towards you.
On the right hand side of the DS you will see a Philips screw head near the bottom, unscrew that screw and remove the battery cover. This will expose the battery itself. Use the flat headed screwdriver to gently pry the battery out from the right hand side.
Once the battery is out the DS will shut down. Reinsert the battey again and screw the cover back on.
Switch the DS on and it should work properly again. If it freezes again just repeat these steps.
Regards.
Jun 14, 2011 | Nintendo DS Lite Console
Minute hand and second hand
There is a tool available in the market to remove second hands.
If you have a watch screwdriver you can easily remove both the hands. Just keep the screwdriver in between minute hand and second hand and gently twist the screwdriver. But be careful, it may damage the dial.
Sep 07, 2009 | Casio Watches
Magic chef rv oven burners work fine oven pilot hard to get lit and when it does lite the oven burner will not lite can you help me
thromo stat bad the tempature knob has a gas valve attached to it along with two gas lines you will have to remove the oven to acess all lines as they run on the backside of the case remove the burners and gas input line copper line remove gas supply tube to all burners remove valve and take to dealer they need the numbers off the vavle for exact repacement not just the numbers off the stove itself east fix with simpl hand tools thermost has a themocouple attached to burner assembly and this is your problem bad part is themocouple is built into thermostat and is no serviceable only fix is to replace "thermostic gas valve"
Apr 08, 2009 | Magic Chef 30 in. 8241RT Gas Cooktop
Igniter Problem on One Burner
Peace,
ngafm here at your service,
You may have some food that spilled into the burner and it could be causing the gas not to fully flow out of that one burner.
Or you just have a bead igniter.
If you have sealed burners and the cap and burner where the gas comes out, is removable by hand without tools!
You may want to check the gas holes in the removable burner is clear and or clean them out if they are clogged.
How old is the range?
I hope that these measures will help you remedy the problem simply and easily!
Bless you,
ngafm
Please give me a good rating in at this site before you sign off!
Thank You
Sep 04, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Two burners wont ignite
Sounds like the electric sending unit for the right burners is not working. Do you hear the cliking noise on the right side when you turn the knob to LITE? If not then you need to replace the electric sending unit, they are located under the knobs, they are a smal square box that goes on the switch valve rod, they have tow wires on the side, just unplug and lift, and look for greasse or anything that might interrup contact, you might be able to use the same ones, or just replace with new ones....Good Luck
Eddie Rentas
Tupper LAke NY
Jul 14, 2008 | Cooktops
My maytag gas range has sealed burners. They need to be adjusted because they dont ignite properly and they blow out when you turn it on high
Peace,
How old is the range ?
You may have some food that spilled into the burner and it could be causing the gas not to fully flow out of that burner so
it will come out with force.
Bless you,
ngafm
Thank You
Jun 08, 2008 | Maytag MGR5751AD Gas Kitchen Range
My LITE-ON DVDRW LH-20A1H thinks its a cd burner???
It seems Lite-on Has a lot of Probs.In fact I had the same model on an SATA system.It would not burn dvd's or cd's.You can try updating your burning software,and reinstalling the drive through device manager.I actually ended up buying an LG burner....lo-and behold...it works without any problems.Good luck
Feb 12, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
Weber Spirit SP-310 Propane Grill Logo
70 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
