Question about Linksys E3000 Wireless Router
I purchased e3000 linksys, i am nt sure if it support adsl or not ... how shall i know
    Master:
  • 451 Answers
If your DSL provider requires a PPPoE login it will support it. if your DSL does not require a PPPoE then just set up your linksys router for obtain a IP and disable PPPoE.
if you do need to PPPoE then use the login that your ISP provided to you.
Posted on Apr 03, 2011
He code to the wi fi
The default password and login to the router are 'admin' and 'admin'. For instructions to log in to the router, see Linksys E3000 Login Instructions
Through these instructions, you can change the Wifi password.
Feb 11, 2015 | Cisco linksys E3000 Wireless-n Router
How to replace linksys-g home router with linksys e3000
Use the laptop with a network cable to check connection. Just connect the NEW? e3000 to the ISP modem. It should work right from the start. If the e3000 is not new, there is a reset in the back.Hold it till it cycles.
The wireless on the laptop should pick up the new router as a new network.
You can even go further back by cycling the ISP modem as well.
Oct 16, 2012 | Linksys Wireless-G WRT54G Router
Went from wildblue internet service to dsl and need to know how reconfigure linksey router
Wildblue is DSL Internet service provider.
You can change the Internet connection settings of Linksys E3000 manually.
Or you can simply reset the router and reconfigure it by running the CD.
See How to setup Linksys E3000
Oct 17, 2011 | Linksys E3000 Wireless Router
Trying to set up e3000 router on iMac lion and keep getting window saying unsupported os need mac os x 10.6.1 or later. I have 10.7
Try to setup router manually.
You don't need to run the CD.
Open the setup page of the router and change the settings manually.
See How to setup Linksys E3000 router.
Aug 16, 2011 | Linksys E3000 Wireless Router
I am using SPA2012 with TG585v7 ADSL on PPPoE, i am not getting any incoming calls, my out going calls are ok. I have done port forwarding still no solution. When i run same SPA2102 on linksys ADSL it...
You may need to reset your device and you will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.But please make sure to backup your all settings first.
May 10, 2011 | Linksys SPA-2102 NA Analog VoIP Adapter...
How do I find the guest password for my linksys E3000 router. I don't know my user name and when i put admin in to the field i get an error
you may have to reset the router back to its "out of the box settings" unplug and there should be a small button on the back--you may need a paper clip
Dec 29, 2010 | Linksys E3000 Wireless Router
How do you connect 2 routers into one network? I have a Linksys E3000 and a WRT110...I've had the wrt110 for over a year but I found I needed a second router to cover my entire house so I purchased a...
The easiest way is to run a long Ethernet cable from one of the 'LAN' (or 'network') ports on the "first" router to the 'WAN' (or 'Internet') port on the second router. The "first" router is the one connected to your cable-modem or DSL-modem. Both routers will auto-configure themselves for this "wired" connection. Configure the wireless-adapter in the second router as per normal.
Or, run a long Ethernet cable from the cable-modem (or DSL-modem) to a location in the "center" of your home, where you can put your wireless-router, such that its signal spans the entire building.
Or, move the cable-modem (or DSL-modem) to a location in the "center" of your home, and connect the one router at that location.
Dec 15, 2010 | Linksys E3000 Wireless Router
I just purchased a linksys E3000 and am getting a message "cannot find router" when using the cd to install
Take a "straight-through" Ethernet-cable, and connect the network-port on your PC to one of the LAN ports on the router.
Turn the router off.
Turn the router on.
Restart your computer.
Rerun the Linksys CD-ROM.
Sep 09, 2010 | Linksys E3000 Wireless Router
Linksys E3000 Wireless Router Logo
172 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
