Question about Woods InWall 7 Day Digital Programmable Timer (59018)
Why is timer have a load clicking sound? - Woods InWall 7 Day Digital Programmable Timer (59018)
    Scholar:
  • 133 Answers
Newer thermostats and timers use small relays on their circuit boards that can be heard when they switch on and off. It is normal.
Posted on Apr 03, 2011
Geyser timer stopped working
Check circuit breaker.
Click fully off and then back on.
Check for burned smell at breaker or loose crackling sound that says breaker is bad.
Reset timer. Then Reprogram.
Possible geyser timer manual
http://waterheatertimer.org/pdf/Digital-Geyser-Timer 24H-7-Day-Timer-230V Brochure.pdf
This timer has a non-replaceable internal rechargeable battery.
If battery has gone bad, then timer is defunct.
Use manual override button to turn timer ON-OFF.
Then test across terminals 3 and 4 for 240Volts.
Turn timer OFF, and test across terminals 4 and 5 for 240Volts
If no voltage shows then timer does not have output.
If test shows 80% undervoltage, that can cause load not to activate, depending on type of load.
Have electrician check for voltage issues at power company transformer.
Unknown what load timer is connected to.
Max load for this timer at 240 volts is 3680 watts, 16 amps.
Motor load is 230 volt 8 amps.
Check label on load for watt or amp rating.
Volts x amps = watts
Watts divided by volts = amps
Oct 31, 2012 | Hardware & Accessories
Washer works but does not run through the spin cycle. it will if i go to it with the timer switch. but not with the timer. when washer gets to the off pos. still has water in it. sat and watched it on...
Sounds like the timer isn't advancing does'nt it.
See if there is power getting to timer motor, but sounds more like timer getting stuck ,especially if older model .replace timer if out of warranty
good luck
Aug 15, 2011 | Maytag Washing Machines
Power is good going into the timer but the timer is not running. I am wondering if there is a fuse that needs to be changed or a reset switch? The timer has been replaced in the last year.
If I understand correctly, you have T-104 240V timer.
Timer was running fine before, and recently stopped working.
If this is not your timer, add a comment.
1) Click manual override back and forth to see if Load turns on-off.
If Load does not turn on-off, then check power at Load.
Timer has 5 terminals A 1 2 3 4
Check terminals 2 and 4 for 240Volts when Load is ON
2) Check terminals 1 and 3 for 240Volts to make sure timer has full 240V and breaker is not tripped OFF on one leg. If timer has 120V, it appears to have voltage, but clock will not rotate and Load will not turn on-off. Check breaker for 240V across both screws.
3) Is dial rotating?
If dial is not rotating or is stuck in place, replace 208-277V clock motor.
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK2?Pid=search
4) If dial is rotating, but trippers don't flip on-off lever, then trippers may be worn down. Buy new trippers.
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
5) How to wire T104 timer
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
How timer works
Clock motor rotates dial.
ON-OFF trippers on dial contact lever.
ON tripper pushes lever one direction.
OFF tripper pushes lever other direction.
Lever moves electrical contacts together, or pulls contacts apart.
When lever moves on-off, manual override lever also snaps back and forth with audible clicking sound.
Nov 24, 2010 | Intermatic T104 24h 208-277v Mechanical...
I have a Kenmore Top load Washer won't drain
You must have a lid switch problem . I have a page I compiled which features lid switch replacement: HERE
Jan 11, 2010 | Washing Machines
Whirlpool LSB6300 died mid-cycle now only clicks
HOPE THIS WORK, DON'T FORGET TO RATE ME
  • Timer is fried.
  • Washer went off-balance and tripped the off-balance switch.
  • Dec 28, 2008 | Whirlpool LSB6300PW Top Load Washer
    KENMORE 80 SERIES
    Open and close lid, listen for 'clicking' sound. If no 'clicking' sound, replace lid switch. If this washer has a hidden lid switch, check the lid hinge screws and make sure they are screwed in tight.
    Jun 01, 2008 | Kenmore 24032\24036 Top Load Washer
    Will not work
    check the lid switch first, can you hear any "clicking" just before the lid is closed, try opening and closing a few times listening closely for he click, if not sounds like a bad lid switch(not recognizing the lid is closed and for safety reasons will not advance further.(far more common issue hen the timer)
    Mar 24, 2008 | Maytag Atlantis MAV6451 Top Load Washer
    Washer make clicking sound
    First locate were the sound is coming from. put your ear very close to the timer and listen for this clicking sound. remember a timer will make a clicking noise which makes the timer go around. Timers can get noisey with age. The sound might be coming from below also .I would run your washing machine until the part fails. They might also have a motor controller in this unit which is seperate to the timer which will make a high pitch clicking noise.
    Aug 18, 2007 | GE WHRE5260E Top Load Washer
    Woods InWall 7 Day Digital Programmable Timer (59018) Logo
    67 people viewed this question
    Top Woods Hardware & Accessories Experts
    Gene Haynes
    Colin Stickland
    Colin Stickland
    Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
