Question about Roper Microwave Ovens
I have lost the User Guide to my Roper FES310BL Self Cleaning Electric Range. I need the instructions on how to use the self cleaning feature.
  • 520 Answers
SOURCE: lost manual
Here's the link to find your manual.
http://genet.geappliances.com/DocSearch/Dispatcher
Posted on Jan 01, 2009
jtd866
  • 71 Answers
SOURCE: Oven works but it no longer is self-cleaning. No
Hi! the problem you have stated indicates that the magnetron its not functioning, check for busted fuse.
Posted on Sep 16, 2009
dcramer531
  • 1654 Answers
SOURCE: WHEN TRYING TO SELF CLEAN
The E1 - F5 error code indicates that the oven door lock assembly is not operating. The oven will not begin the self clean cycle unless the oven door is properly locked. This failure is normally caused by a failed door lock assembly. In rare instances, it can be caused by a failed control board or a wiring failure. The normal troubleshooting for this problem is to unplug the range and check the wire harness connections between the control board and the door lock assembly. The first image below shows the access information for the components in this model of range. The second image shows the wiring diagram with the door lock circuit highlighted. If you are able to unplug the range and check the wiring connections, you can likely fix this problem yourself. If the wiring connections are okay, the next step in troubleshooting is to replace the door lock assembly (part W10107820). You can order this part from the Sears PartsDirect website. Replacing this part will likely fix your problem. If you replace the door lock assembly and still have the same problem then the electronic oven control board may also need to be replaced. If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website: Sears Home Services .
Posted on Nov 23, 2010
alpug
  • 1961 Answers
SOURCE: I have a Beaumark Self-Cleaning
The closest manual I could give is the Maytag Beaumark Self-Cleaning Oven Manual
Its a pdf file so you need Adobe Acrobat Reader installed in your system to view this file
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0811498.pdf
self-cleaning operation can be found on page 15.
Posted on Jan 30, 2011
heatman101
  • 43501 Answers
SOURCE: I have a Caloric stove
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Posted on Feb 22, 2011
Testimonial: "It didn't tell me how to set the cleaning option BUT...It help me to see it may not be a safe practice to use that function."
MY OVEN DOOR REMAINS LOCKED AFTER CLEANING. I GET A F1 DISPLAYED. I LEFT IT UNPLUGGED ALL NIGHT AND IT STILL SAYS THE SAME THING AND IS LOCKED. IS THERE ANYTHING I CAN DO?
I could be more specific with a model number from the range.
The F-1 code on most ranges is a bad electronic control board. The oven lock is controlled through this board.
If you replace the board you should be able to open the oven.
You may also have a blown thermal fuse behind the rear panel on the oven as a result of self-cleaning.
Self cleaning is a nice feature but is not recommended by appliance repair technicians.
Sep 04, 2011 | Maytag Microwave Ovens
Need a manual.
Hello.
The name of the oven is need to solve the problem as do it your self offer and also the serial number of the microwave oven will also be needed .
Get all the above instruction reading from the receipt or on the body of the oven the visit the below address to get your self a user manual.
oven user manual guide .com or operating manual guide .com
Thanks.
Sep 03, 2011 | Microwave Ovens
HOW DO I USE THE SELF CLEAN FEATURE?
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Apr 14, 2011 | Microwave Ovens
Lost my oven control guide. how do I set the self clean function on the kenmore elite dual fuel range
heatman101
Jan 04, 2011 | Microwave Ovens
I am just wanting to know how to use the self clean feature on my oven
heatman101
Nov 24, 2010 | Whirlpool Microwave Ovens
The machine says it needs water but there is water in it and i do not have an users guide so i also need to know how to use the self cleaning feature
If you go onto the manufacturers web site, owners manuals are normally freely available and free of charge for current models.
Hope this helps.
Regards
Oct 19, 2010 | Microwave Ovens
I just used the self cleaning feature for the first time. Next time I went to use the oven it would not heat up. What happened?
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Aug 30, 2010 | Microwave Ovens
DOOR SHOWS OPEN BUT IT IS NOT
After self cleaning the range the door won't open....
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Hope this may help;
DON'T FORGET TO HELP
Sep 06, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Gas electric with convection oven ( 48600)
Old message but maybe you are still living with the problem.
There are safety switches that must close with the oven door before  the cleaning cycle will initiate and one or more of these may have failed. Sometimes these are actuated by metal tabs on the oven door that fit into slots on the mating surface. If yours is so constructed, use a popsicle stick or similar non-conductive probe and poke it into each slot listening carefully for a quiet 'click' or a change in resistance to your insertion. If one of these sounds or feels different than the other, one of them is probably bad although finding an action doesn't guarantee that the switch is electrically functioning. Unfortunately, if your oven is constructed as described, the switches are only accessible by removing the side panels from the range.
The door lock feature is a must since the self-clean temperature must reach 900+ degrees to enable the catalytic action to occur.
Feb 04, 2008 | Jenn-Air JMC8130DD Microwave Oven
Microwave Ovens Logo
129 people viewed this question
Top Roper Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Mark Cheong
Mark Cheong
Are you a Roper Microwave Oven Expert? Answer questions, earn points and help others
