Question about Refrigerators
Water is leaking from the inside back of the freezer to the bottom
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 03, 2011
Water leaking from inside of freezer bottom
Check the defrost of the freezer which you are using right now.For More information please visit Clothes Dryer Element.
Oct 06, 2012 | Hotpoint HSS25GFP Side by Side...
Water leaking from under the freezer
Until defrosting the block of ice you canot see if is a hole or crack in the bottom. But I suppose is leaking from the door gasket under the pressure of the ice inside. Anyway, if you want to keep alife your refrigerator, better unplug it, defrosting and clean it before complete annihilation.
Sep 10, 2017 | Frigidaire Refrigerators
Water is leaking out from the bottom of the freezer
Below the freezer coil is a drain trough. Sounds like it is frozen. Use a hair drier to melt it and poor baking soda with warm water down it.
Jun 02, 2010 | GE Profile PSS26NGS Side by Side...
Leaking inside
The drain in the back of your freezer is frozen. When the defrost cycle runs, the water has no where to go except through the panel into your refrigerator.
Turn the refrigerator off. Take everything out of the freezer and store it someplace for a few hours. You can either let the freezer thaw on its own or help it out a bit. If you want to speed the process, remove the rear and bottom panels from the inside of the freezer to expose the coils and the bottom pan. Stay away from the coils. Melt/chip away all of the ice in the pan. With a hair dryer, melt the ice in the back of the pan. Soon you will see the drain - concentrate on melting the ice in it. Some hot water and a sponge can help speed the drain clearing process. When the water drains freely, finish drying out the rest of the freezer and reassemble the rear and bottom panels. Turn the refrigerator back on, and you are good to go.
Jan 30, 2010 | Kenmore Refrigerators
Ice build up on bottom of freezer. Water leaks out of freezer possibly from melting. Water leaks onto floor of kitchen.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
May 19, 2009 | GE Profile Stainless Bottom-Freezer...
Water building up on the bottom inside the freezer side
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
Apr 19, 2009 | Frigidaire Gallery Series GLRT83TEK 30"...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Water leaking from bottom right-rear near valve. Changed inside filter.
you might have a clogged drain in the bottom back of the freezer. When the freezer defrosts the water has no where to go and comes out the front.
Aug 11, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
