Question about LG WM-2077C Front Load Washer
What does code LE mean - LG WM-2077C Front Load Washer
  • 1,543 Answers
Load Error
Most commonly caused by a bulky or off balanced load set to spin at too high a speed. (low speed spin required for those loads) If not a load issue, the next most common reason is a bad Hall sensor (located on the motor windings. easy replacement, and part is covered under the 5 or 7 year motor warranty) After those causes, next on the list, could be a stripped out spline on the motor rotor, the shaft of the drum drive spider could have broken loose, there could be a poor electrical connetion or bad wire between the Hall sensor and the main board, the main board could be bad, well, you get the idea. You may need a service call if it wasn't a load issue.
Posted on Apr 04, 2011
Code p0303 changer coil bougi et injecteur sur le piton 3 et verifier le couran sur injecteur et coil ces correcte et le code p0303 revien et le moteur a des rater quoi faire
P0303 Code - Cylinder #3 Misfire
A code P0303 may mean that one or more of the following has happened:
  • Faulty spark plug or wire
  • Faulty coil (pack)
  • Faulty fuel injector
  • Burnt valve(s)
  • Poor cylinder pressure
  • Faulty PCM
Aug 31, 2016 | 2004 Nissan Murano
LG washing machine loud and error code LE
Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
heatman101
Jul 02, 2011 | LG WM2301HW Front Load Washer
What does code LE mean? The washer stops and LE appears
Code LE signals an overload to the motor. Wait 30 minutes and restart the cycle. If the code is not released, you need to call a service technician.
Jan 07, 2011 | LG WM2487H Front Load Washer
What does error code LE mean?
heatman101
Sep 20, 2010 | LG Washing Machines
I have an LE error code
yes it can mean serveral things. Please check this SITE this is the service manual for your dishwasher. You can get parts at www.sears.com
just find your model. Service manual should help you a lot
Jan 12, 2010 | LG LDF6810ST Stainless Steel Built-in...
LG Tromm washer WM2077CW reading code LE
LE means "Overload in Motor" Unplug the washer, remove clothes, wait 15 minutes for motor to cool down. try again. If problem persists you'll need a certified technician.
May 31, 2009 | LG WM-2077C Front Load Washer
Error code LE
Hello and welcome,
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Jan 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
LG WM-2077C Front Load Washer Logo
104 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
