Problem with Germ Guardian Humidifier H2000B - Light turns red and the mist stops coming out after a few seconds of turning on the humidifier. There is plenty of water in the tank and the device is clean.
There are a few things to check that would cause the empty light to go on and the mist to stop.
Rinse the lid on the bottom of the blue tank. After you rinse it with warm water, dry it and then push the spring on the outside of the lid, it should move easily. Check the inside of the lid and make sure the rubber gasket is securely in place.
Remove the spray guide, and on the base of the humidifier to the side of the ultra sonic disk is a small white plastic pole with a washer-ring around it. This is the float, make sure it moves easily up and down the pole. Use white vinegar on a cloth or paper towel and wipe the pole down.
Reassemble the humidifier, use room temperature water in the tank, set to warm mist and let run for 30-40 minutes. Please make sure the humidifier is on a flat level surface, no carpeting or towel underneath.
Posted on Apr 04, 2011
Tank is full, but after a few minutes why does it stop and the 'Tank Empty' light comes on?
Reset light comes on, unit stops operating when tank is full ...
www.fixya.com/support/t384577-reset_light_comes_unit_stops_operating
Feb 6, 2008 - Question about Vicks Warm Mist V745A 1 Gallon Humidifier ... Tank is full. ... for about another 5 minutes when the unit stops, reset light comes on etc. ...the humidifier since the reset light keeps going on immediately after I turn ... water in the tank because of course, the heater is on, but no water is getting ...
How to Fix a Humidifier ' HomeTips
www.hometips.com/repair-fix/humidifier-doesnt-work.html
Jan 17, 2016 | Humidifiers
Humidifier will produce mist for a min then stop If you look you can see it producing mist within but it will not come out of the top Walgreens cool mist ultrasonic humidifier
I have had times where my Crane humidifier won't produce mist if I haven't turned it on for several days (4+) or more. The water that sits in the reservoir may develop a film on the ultrasonic element which inhibits the creation of the mist to come out the top of your humidifier. I would lift off the tank and empty the reservoir. Then VERY GENTLY with a piece of paper towel, wipe the ultrasonic element (looks like a disk the size of a quarter at the bottom of the reservoir) to clean off any film. Then replace the tank and let the reservoir fill up the tank and try it again.
If your humidifier runs properly for a minute and then makes a whirring noise and goes silent (like the motor stopping), then it's a motor problem. The humidifier motor may have gone out of alignment due to bumping or rough handling of the humidifier when cleaning or emptying it. If that is the case, you will have to empty the humidifier reservoir, unscrew the base, and find the screws holding down the motor and check for misalignment. Loosen them a little and put it back together and try again.
Best of luck
thebqe
Feb 13, 2014 | Humidifiers
Where do I find manual for germgaurdian H3000 humidifier.
http://www.guardiantechnologies.com/product-instruction-manuals/
Germguaridan website.
This manual can be found under discontinued models. This was most likely discontinued because it is very sensitive and quits working too soon because of the ultrasonic sensor.
Dec 10, 2013 | Germ Guardian H-3000 Ultra-Sonic...
Germ guardian h3000 not blowing air
I have a Vicks, similar, and it recomends a little table salt in the water to create a mist, read your manual and see if this helps. Don't go overboard on the salt, or you'll have old faithful instead of a mist!
Apr 07, 2013 | Germ Guardian H3000 Humidifier
Hi, I was cleaning my H3010 Germ Guardian Humidified and damaged the small round part with 2 wires (JR707). It is the part where the water mist comes from. Is there a way to buy this small thing ot...
For replacement parts contacting the manufacturer of the humidifier would be the best thing to do. They know what parts can be replaced and if they have service repair facilities or if you would need to work directly with the company. Germ Guardian website is www.germguardian.com. Toll free 1-866-603-5900.
Apr 09, 2011 | Germ Guardian Humidifiers
Hello, I've had the Germ Guardian H3000 for about 2 seasons. I clean it every year but it stopped working. I keep getting "Vacant" light turned on and get no vapor. I have the manual, but...
After thinking about the problem, it could be a problem with the level float being stuck in the empty position and therefore it thinks there's no water. Also, perhaps the ultrasonic mister is not working, which is related to this other Fixya I'll link to below.
What does the Vacant light on my germ guardian 300 mean because when press...
Jul 04, 2017 | Germ Guardian Ultra-Sonic Digital...
Humidifier Leaking over floor, not retaining water, excess bubles
My humidifier is leaking. I is a Vicks V3900 Germ Free Cool Mist Humidifier. How do I solve this problem
Feb 09, 2010 | Vicks Humidifiers
Humidifier makes a huge noise and no mist
According to the Crane's Troubleshooting section:
The power light is green but there is no mist being emitted:
- Check that there is water in the tank.
- Check for possible lime deposits on the water level sensor or the nebulizer.
- Make sure that nothing blocks the vapor output slots.
- Check that the fan vent on bottom of humidifier is not blocked.
- Empty the humidifier and rinse the water basin with cool tap water and allow to dry for 15 to 30 min.
This next part may or may not be relevant.
Humidifier power light is staying red and not turning green. Or, Humidifier is working then stops:
- Ensure that water level sensor is assembled properly.
- Clean water float.
- Call service center and request replacement water float.
Barring that, here is the service center contact info:
Dart Warehouse Corporation
Tel: 1-888-599-0952 (Business hours Mon-Fri 9:00 am - 4:00 pm Ct)
Website: http://www.crane-usa.com
1835 Ferry Road
Naperville, Illinois 60563
Jan 28, 2008 | Crane Cow Humidifier
Air-O-Swiss 7133
Okay, I just started getting this same deal with my 7133 on it's third season. I found in a blog that if you hold down the button that controls the heat while turning the mist knob on, it resets the machine. It worked. The red light went green and I turned off the heat button for cool air and the upper light still stayed green. Fingers crossed this continues to work. good luck!
Nov 27, 2007 | Air-O-Swiss 7133 Humidifier
Heating & Cooling Logo
167 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
