Question about Braun Tassimo Espresso Machine/Coffee Maker
For Tassimo - Ican't find descaling product. Went to 3 stores. Can I use lemon juice or vinegar.
I just spoke to Customer Service at Tassimo and they informed me that any descaler can be used as long as it does NOT have vinegar. It can be a liquid or powder and just follow the instructions on the packaging. Hope this works for you.
Posted on Apr 04, 2011
How much bicarb of soda do i use to descale my bosch tassimo
Sodium bicarbonate is not a descaling product. It makes a nice minimally abrasive cleaning agent when mixed as a paste. Sodium ions will exchange with calcium in a water softener when the calcium is dissolved in water. Once the calcium salt (calcium carbonate) forms, it doesn't go back into solution in a neutral or basic environment. A bicarbonate solution will be basic.
Descaling requires an acid. The Tassimo products say "Do not use vinegar" (acetic acid). I suspect they use citric acid in their descaling product. You can try the lemon-flavored Kool-aid (the version packaged in the envelopes that needs a sweetener added when it's a drink). Mix 1 tablespoon of the powder in 1 pint of water. However, you'll need to make more than a pint of the solution since you need 500 ml of liquid per cleaning cycle. (1 pint is ~473 ml.)
I hope this helps.
Apr 24, 2012 | Bosch Tassimo TAS4011GB Coffee Maker
What does it mean to descale my tassimo? the yellow light is on and the screen keeps saying "descale". thanks
In order to keep your Tassimo machine operational at full order, it is important to descale it every three months. Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Tassimo machine is intended for this specific use only. Mix the descaling product directly in the water container, following the instructions provided on the descaling packaging. Then replace the water container on the machine. Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down and close the brew mechanism. As soon as the AUTO light illuminates, press and release the start/stop button. This will fill the brew cycle with descaling solution. Empty the cup and let the machine stand for 15 minutes. Then open the brew mechanism and close it again, leaving the cleaning disc in place. Repeat this step two more times for maximum descaling effectiveness.
Discard the remaining descaling agent from the water container, rinse it well and refill with fresh, cold water. Clean the machine by flushing water through it in the same manner and emptying the cup as it fills. Make sure that all the descaling solution has been completely rinsed away, and then flush two full water containers through the machine before using it again. Remove the cleaning disc, rinse and refill the water container and your Tassimo machine is ready to use. Also, before you descale your Tassimo machine, always unplug it. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Tassimo machine. This method works for most espresso machines, including some of these popular models: the DeLonghi Magnifica EAM3200S, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5400, Gaggia 74507BCN Classic, Krups EA8080 Espresseria Automatic, DeLonghi PrimaDonna ESAM6600, the BC0255 DeLonghi coffee machine and the Krups Nespresso CititZ XN 7006.
May 16, 2011 | Microwave Ovens
My coffee maker seems to act like its plugged up because when its trying to fill from the water tank the water level very goes down and sometimes it goes down faster but then if it doesnt get enough water...
It has built up with calcium deposits. Regular vinegar will not clear it.
Add some baking soda with the vinegar. Then after this, use vinegar and lemon
juice to clear up any remaing lemon juice and vinegar from the first cleaning.
Feb 25, 2011 | Keurig Platinum B70 Coffee Maker
How do I descale a russell hobbs slipstream iraon - I have looked on your site for free user manual and can not find it.
If you talking about descaling the built up calcium deposits in an iron, then there are many commercial products. You can find them in your grocery store, and reading the ingredients you may find mild phosphoric acid which is used in descaling large boilers.
But I prefer to use white vinegar (mild apple acid?) half and half mixture, poured into the iron and let heat for a few minutes and after cooled down dump the mixture out, repeat if necessary. When you refill the iron to use squeeze a little lemon juice in the water to make the iron goods smell lemony instead of vinegary, and the lemon juice is also acidic and will remove some of the scale.
Dec 31, 2010 | Microwave Ovens
Red de scaling light won't shut off
Removing the red descaling light is simple.
1. Fill reservoir with half vinegar and half water (no need for the special descaling product from Tassimo).
2. Turn on machine.
3. Insert yellow cleaning disc found in back of machine.
4. This is where most people have the their problem...You must hold the start button for 3 to 5 seconds for the descaling program to start. Both green and red light will flash.
5. Once started, use a large cup to catch the output of water.
6. The machine will cycle through the descaling program in about 30 to 45 minutes. Be paitent!!!
7. Once completed, run many cups of plain water through the system to remove the vinegar taste.
8. Red light problem is solved.
Apr 11, 2010 | Braun Tassimo Espresso Machine/Coffee...
Can i use a cheaper descaler solutionfor my tassimo machine
You can use any citric acid based descaling product.
Do NOT use vinegar (acetic acid) based products on the Bosch machines as this can damage the aluminium in the heater block.
Mar 15, 2010 | Braun Tassimo Espresso Machine/Coffee...
Has anyone used vinegar to descale their tassimo machine without any damaging their machine? thanks
Never use vinegar to descale esrpresso machines since will destroy the copper parts in long terms. Vinegar is used onle on plastics and st. steel. Try to use special descaling powder which you can find online in ebay maybe
Feb 06, 2010 | Braun Tassimo Espresso Machine/Coffee...
Miele descaling funnel?
DO NOT USE THAT MUCH VINEGAR! Put a tiny bit of vinegar in the carafe and fill carafe the rest of the way with water. Run that vinegar/water through machine. Using another container, fill machine with plain water and run that through. Repeat until the vinegar taste is gone. If you do not run lots of plain water through the machine after, your coffee will taste like...um...disgusting! Also, use a spell-checker before improving this posting.
To clean hard water deposits from a coffee maker use distilled white vinegar. You may need to use as much as a gallon if the scale buildup is really bad. Fill clean coffee pot one half full of vinegar and run through machine as if making coffee. Repeat this process several times using fresh vinegar until it comes out clear. Do this once a week and your maker will work much better. **************
Use citric acid or LEMON JUICE CONCENTRATE instead of vinegar. It cleans just as well but doesn't leave the funky odor that vinegar does. You can run enough water to get rid of the vinegar taste, but the odor will linger for days or weeks. Much better to use lemon juice concentrate (no pulp!!) or one of the commercial products like the one available from Starbucks.
Sep 15, 2009 | Miele Coffee System
Descaling
No, you can not use vinegar. It will dissolve scale into chunks and block the water heating circuit.
Jan 07, 2008 | Braun Tassimo Espresso Machine/Coffee...
Braun Tassimo Espresso Machine/Coffee Maker Logo
2,341 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
