Question about Bosch Classixx WFL 2462 Front Load Washer
My Bosch Maxx 1650GR/10 Washing Machine carbon brushes has burned-out causing the non rotation operation. What Part Number to look for a replacement brushes? I belive I need the R Type plastic housing with the brushed mounted in. Please advise what and where to purchase such replacement. Thanks for your support. Pini Alezra
    Guru:
  • 500 Answers
Your local Appliance Spares Outlet should have it.
Part Number 154740 should do the trick.
LINKS:
http://www.mytub.co.uk/product_information.php?product=397069
http://www.amazon.co.uk/SIEMENS-WASHING-MACHINE-BRUSHES-Equivalant/dp/B0019Y1EFG
Hope it helps!
* If you found this solution helpful, please rate 4 thumbs up and leave a small testimonial. :-)
Posted on Apr 04, 2011
Bosch maxx 900 manual
It could be caused by a damaged heater element.. remove and check for damage. One way to check is to remove the two wires and tape up to prevent accidental short circuit. set machine to a cold wash if it does not trip you know what you have to replace. if it still trips then remove the motor and check carbons/ brushes for excessive wear. good luck..
May 10, 2014 | Washing Machines
Can anyone tell me where I can get carbon brushes for a Bosch WFMC1001UC/09 washing machine. Bosch does not sell or list the part. They say you have to replace the motor as a unit. The number on the old...
I realize that this post really old but I wanted this to be available for the next guy. I bought Bosch part number 154740 which are brushes that worked for me from repairclinic.com. They will tell you it wont work but it did for my Bosch (wfmc1001uc/09) washing machine.
Dec 28, 2011 | Washing Machines
Bosch washing machine model WFF1401GB/01, 10 years old, motor was replaced 5 years ago (so motor is 5 years old now). Drum has stopped rotating, pump etc all OK. Carbon brushes replaced, drum did work for...
Check the motor control board for dry joints, poor contact, signs of excessive heat around plugs/pins
I would try new brushes again or thoroughly inspect whether they are contacting the commutator.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Mar 01, 2011 | Bosch Washing Machines
My washing machine is not spining
It is likely that the Carbon Brushes of your Bosch washing machine need replacement. Get them from your nearest Bosch Spares stockist (P/N: 154740) Replace these on the motor armature, and it will be alright again. To be certain that it is indeed the Carbon brushes, open your washing machine and look on the motor (opposite side of the pulley) There has to be 2 grayish chalk type brushes running on a copper armature, these brushes have a lifetime of about 4 - 6 years before being diminished.
Hope this helps
* If you found this solution helpful, please vote positively.
Feb 18, 2011 | Bosch Washing Machines
Washing machine wfm 2010 not rotate just fill and drain water
sounds like the carbon brushes in motor,Or motor has had it.
Oct 11, 2008 | Bosch Washing Machines
Bosch Maxx 6 WFL 2061 Front Loader W/M
brushes usually available on ebay,
if the drum rotates but does not spin, this could likely be brushes or component problem (i.e triac or relay) on control PCB. - the latter was the problem i had and this was easily spotted as a blackened track on the Relay on the pcb.
Brushes should be ~£5. - check the existing brushes first before buying them.
fitting is easy, BUT a word of warning..which you probably know anyway..
before meddling though in the machine, locate the large capacitor and with electical screwdriver and discharge all the terminals to earth first! - YOU MUST DO THIS TO AVOID ELECTRIC SHOCK!! - even if the machine is unplugged.
remove motor & undo the back plate to release old brushes.
clean of motor of any excess carbon dust, - this can eventually cause arching if not cleaned away.
reassemble and fit all plugs back.
THEN TAKE 5 MINUTES TO CHECK WHAT YOU HAVE DONE BEFORE SWITCHING ON. -
Do not rush anything - take your time.
Mar 24, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing machine
UNPLUG THE MACHINE BEFORE CHECKING!
It is Usually the Brushes on the Motor that cause the problem. The Brushes DO wear out on all Brush Motor washing machines eventually. How quick depends on USE and Manufacturer.
In my experience Most Bosch Brushes last between 3 - 8 years before requiring renewal. You will need to remove the brushes to check how much carbon is remaining.
Replacement Brushes are available. It would help if you provided your E.NR ( number ) which you will find on a label on the inside of the Door.
Mar 16, 2008 | Washing Machines
Bosch Maxx WFL 2260
My drum stop, then I put in new carbon brushes. It works very good in 2mouth, now it stop again. Wht can be problem?
Jan 17, 2008 | Washing Machines
Bosch Classixx WFL 2462 Front Load Washer Logo
262 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
