Question about Lexmark S305 IMPACT LEXS All-In-One InkJet Printer
I keep getting unrecoverable scan error message and it sounds like the printer is trying to pull the paper, then none of the buttons work but the power indicator is still on....i have tried unplugging then re-connecting the power and the same to the USB. I don't know what else to do.
  • Lexmark
    Lexmark Apr 18, 2011
    This sounds like a hardware problem. Please contact Lexmark technical support for assistance.
5 Suggested Answers
stabelabel
  • 51 Answers
SOURCE: Scanner and copier not working
You have a problem with printer need to contact Lexmark your scanner is probably broken.
Posted on Mar 16, 2009
pineworks
  • 4041 Answers
SOURCE: When scanning documents a paper jam is indicated
Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 11, 2010
  • 10 Answers
SOURCE: X5650 Unrecoverable scan error. Does not feed the paper.
that sounds more like a mechanical issue. You might want to call Lexmark at 1-800-LEXMARK about the problem. Hope your printer is still within warranty. Hope this helps.
Posted on Mar 06, 2010
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: "unrecoverable scan error" .
    The error indicates a scanner hardware problem. Your printer, probably, won't be able to perform its normal functions. I would highly recommend that you contact Lexmark Technical Support for assistance. Thanks.
    Posted on Oct 27, 2011
    Service error 5200 Keep getting this message Have
    Your printer might be running out of ink, if you've seen that the ink button blinks, youy need to replace your cartrudge or refill your ink.
    Jul 03, 2011 | Canon PIXMA MP240 All-In-One InkJet...
    Try to scan and same error: unrecoverable scan error> But printing works perfect
    "Unrecoverable Scan Error" message indicates a scanner hardware problem in your printer. Please contact Lexmark technical support for further assistance.
    Jun 27, 2011 | Lexmark All-in-One Printer with PictBridge
    My printer is Lexmark x5650. It prints well, but when i try to scan it starts making knocking noise after few seconds and continues 15 sec. then i get a message on printer's control panel display...
    Unrecoverable scan error indicates a hardware problem. It's also evident with the "knocking noise" in the printer. I strongly suggest you contact Lexmark technical support for assistance.
    Aug 27, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
    Jan 27, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
    Mar 15, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
    E 2 and service error 5100 on Pixma mp160 printer
    You can try to clean out the printer check to see if there is any paper jammed in it somewhere
    Then realighn the printer cartridges and run a test page.
    Make sure that the paper tray is not overloaded
    Dec 24, 2008 | Canon PIXMA MP160 All-In-One Printer
    HP C3150 Printer Continuing Paper Jam Errors
    Sometime the ink jet mechnism is out of time or it gets stuck in the lock position. You might want to see if it looks like there crooked in the trays at the end of the printer.
    Jul 04, 2008 | HP Photosmart C3150 Printer
    Cant print or scan
    Hi carla;
    that sounds pretty weird but you may want to try resetting it to default factory settings,just navigate through the menu if it still doesnt work, try re-installing the driver.
    thanks
    Jun 02, 2008 | Lexmark X4270 All-In-One InkJet Printer
    Tally T2250 Matrix Printer does not pull up paper to be printed
    I would guess you are getting error messages on the diplay to tell you what the bleeping noise is about....Please read this message.....
    I would guess the message is something like LOAD SINGLE, and you are using tractor feed paper. If this is the case the paper path on the pritner has changed and needs to be changed to Tractor 1 again.
    To do this;
    • Stop any prin jobs gong to the pritner
    • If the printer has data in its buffer, power the printer off and back on again to clear this data
    • Ensure the printer is OFFLINE
    • Press the SETUP button
    • Press the button under ADJUST
    • Press the button under PAPER WAY
    • Use button 2 or 3 to change this to TRACTOR 1
    • Press SET
    • Place the pritner ONLINE
    You should be back in action, if not post the message you see on the printers LCD display.
    Dec 18, 2007 | Tally T2250 Matrix Printer
    Lexmark S305 IMPACT  LEXS All-In-One InkJet Printer Logo
    109 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
