Question about Toro Garden
I have a 2002 toro proline mower. There is a clear hose coming off the top of the carberator. does that hose connect somewhere or is it a breather hose?
    Novelist:
  • 111 Answers
It is an overflow tube. If the carburetor gets turned upside down the fuel will drain out of it. Also if the carburetor is flooding it will run out of this tube as well. It is a safety feature on certain engines.
I hope this answers your question.
Posted on Apr 05, 2011
Starts, then stalls after 10 min
Make sure the fuel filler cap breather hole is clear if its blocked it will create a vacuum in the tank which prevents the fuel flowing forward. Also check out the links below
Small Engine Repair Help
Lawn Mower Troubleshooting Guide Engine
May 03, 2015 | Toro 20372 Recycler Personal Pace...
Why wont my mower start and gas comes out of muffler
carb is flooding out ether bad plug or your carberator needs rebuilt
Aug 25, 2014 | Toro Lawn Boy Self Propelled CARB Walk...
Toro push mowers
Try some P.T.F.E. tape from a plumbers merchants. It's thread seal tape.
Jun 15, 2013 | Toro Garden
Oil leak toro recycler 6.5hp lawn mower
Sounds like the bushing is bad where the crank shaft comes out.
May 19, 2013 | Toro Garden
How to fix a vapor lock on a toro lawmower?
Try spaying WD40 in cylinder, pull rope several times to blow out cylinder. Ensure oil breather hose is connected to back of air cleaner. Spray down hose with a little carb cleaner. Ensure oil is full, 30w oil. All engines have a low oil cutoff. Use Stabile in gas always!
Jul 30, 2012 | Toro Garden
Valve breather shots out oil when engine is running
I do not think this is a gasket issue, if the machine has beed tipped up oil will travel up the breather tube and enter the air filter case, over filling will also cause this, if its been tipped it will clear if you run it for a time with the filter off.
Jul 03, 2012 | Toro Lawn Mower With Toro Power Tools
Proline toro commercial 32 inch won't run
try starting fluid that will see if its a fuel problem then check for spark
Apr 19, 2012 | Toro Garden
I have a Toro Proline walk behind . Problems with the self propel
I suspect the drive belt, not the Hydro. Especially if the drive belt was never replaced. The belts are known to stretch and wear out over time. It's a cheap part.
Jun 04, 2010 | Toro Lawn Mower With Toro Power Tools
Toro Proline 400 blades fall out of engage
if your unit desengages have the clutch gap checked. also you should check for shorts in your safty wiring. the other would be a bad switch. finely your under warranty this my be warranted.take it to a toro dealer or call one to make sure
Sep 07, 2009 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
Garden Logo
111 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
