Question about Philips MX5100VR System
I received my Philips DVD5140 player years ago as a present. A few months later, my player began to act up. It now takes a long time in the loading process until finally after a while responds with "No Disc" each time I try to use a DVD. I have changed the region code to 0, i have used a lens cleaner DVD on the player and I have even resent the player to default to get it to work. Nothing seems to work. Do you have any other suggestions? Any help would be greatly appreciated. Thank you.
  • Philips Master
  • 5,455 Answers
You need to look at the lens of the DVD player. With it switched off of course! If the lens has a scratch on it the player will not read the disc.
Posted on May 22, 2017
  • 4 Answers
SOURCE: philips DVP642 DVD Player "No disc" problem
if its still under warranty, do that.
if it's not, try taking it back to the store and asking for a replacement. don't let the floor salesman tell you no. insist on speaking to the manager. my strategy is to: "be polite, appear slightly stupid, and dont take no for an answer" it works 80-90% of the time.
if you cant get anywhere (or dont want to try that route), then you have nothing to lose. open the case and try to clean the mechanism and lens
two screws on either side of the unit, and i think another 4 screws on the back side. this will allow you to pull the top cover off the unit.
clean the mechanism, and clean the lens. you can buy cleaner if you want, but i just use a soft cloth and some "no-streak" type window/glass cleaner (windex)
clean your disks as well. this DVD player seems to be sensitive to scuffs and dust more than some other players. you just have to be persistent.
or you could buy another DVD player. at $60, its really a pretty good deal anyhow.
good luck
Posted on Mar 09, 2008
SOURCE: PET702 Portable DVD player 'No Disk'
try this:
Press setup on the remote
Use the arrows to navigate to Prefreneces (pref)
type 9 6 5 3
Select Region code (press down arrow to set to 0, open for all codes)
Press setup again to exit
is working :D
Posted on Mar 28, 2008
SOURCE: Convert DVD Player to all regions
I found solution: Go to Google and type - DVD help. There is a site with codes for DVD players. http://www.videohelp.com/dvdhacks/philips-dvp-3260/9309
Just type in the codes by: Press "Setup"
Scroll to "Preference" using the LEFT/RIGHT arrow key
Press "138931" and a pop-up screen will appear.
Use the UP/DOWN arrow key to choose the desired number.
Press "OK"
Posted on Jul 15, 2008
SOURCE: UNLOCK REGION CODE FOR PHILIPS DVP3140 DVD PLAYER
Perfect!!!
Posted on Sep 01, 2008
  • 35 Answers
SOURCE: Want to unlock Philips DVD player (DVP320)
Did you follow these instructions exactly? If you pressed 9990, as you mentioned, it will not work. You need to press 99990. Do you see region "0" on the display?
start the player without any DVD in it.
open the lid.
while the lid is open press 9,9,9,9,0
you should see region 0 displayed.
close the lid.
Your DVD player is now region free.
note:
replace 0 with 1 to 6 at to set the wanted region number if needed.
Posted on Mar 05, 2009
I began to have issues with my '05 Hummer H2 a few weeks ago.....
P0496 = "Evaporative emission system high purge flow"
At the dealership, we get a lot of complaints like yours and they all started with running too low on fuel or running out.
Start with replacing the fuel filter and get back to me.
Running low/out tends to suck up micro trash from the bottom of the gas tank and that gunk clogs the fuel filter.
Feb 02, 2013 | 2005 Hummer H2 SUV
Afew years ago my low beams both went out at the same time, I took it in and had repaired, a few months later received recall for the problem, had my money refunded and everything worked well, until 2...
yes easiest solution since it was a recall take it back to suzuki and tell them politely it has the same problem and let them deal with it..good luck I hope they look after you
Dec 21, 2009 | 2005 Suzuki Forenza
My Denon AVR-788 receiver switches off by itself after it has
If you've changed it's location or added speakers, or placed anything on top of it since the problem started then consider that it may just be over heating.
Dec 19, 2009 | Audio Players & Recorders
I have had my tiburon less than a year but about a month ago the transmission started to act weird. At first it began shifting between i think third and fourth gear which made the rpms go higher than they...
the trans computer has seen a problem possible a bad sensor, or an internal problem, and puts it into a safe mode, or limp home mode , it wont shift , it will stay in 3rd gear, this way this reduces the possibility of further damage trans damage, when you turn the ignition off and back on it resets the tcm, my advice is to take it to your local dealer, they can diag your trans as they know the product, i dont advise pep boys, or discount auto parts.
Nov 18, 2009 | 2001 Hyundai Tiburon
Kenmore top load portable washer, model 110.42722200
i had same prob. at my daughters house, similar model. first time a hose popped off the top(i removed the lid), later i noticed leaks because my son in law was using oxy clean and it foamed over. my advice is, put machine on its side and look for loose/popped off hoses, dont use too much soap or additives, which will trick the water level sensor or just pour over that little drum
Jul 16, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
I have a Ford F-150 Sport. I have had some
It might be the PATS system or the ant. problem its the peace around the key switch
Jul 09, 2009 | 1993 Ford F150 SuperCab
Can't turn it on, l;ock switch isn't on
Reset the PlayerUse the Philips Device Manager to perform a Repair
Sep 09, 2008 | Philips GoGear SA178 MP3 Player
Hoizontal lines in images
The problem is faulty CCD sensor ( this device converts light into image ) so faulty sensor means either poor quality pics or no pics at all. Have sensor replaced and camera will work fine.
Sep 11, 2007 | Konica Minolta DiMAGE E50 Digital Camera
Philips MX5100VR System Logo
27 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
