Question about Maytag Refrigerators
I need to order a water filter for an Admiral sal2027gbs and I cannot find the part number as all part numbers are maytag brand Can you give me a part number and a supplier
  • 3,037 Answers
One of the four filters on the following link should match yours. I am not sure off-hand which one since they don't give your model number under any but they all look different so match your water filter up with one on the website and let me know if you need anything else
my best to you
Posted on Aug 05, 2008
Water solenoid connection
hello,
Check out the manual ... it differs in diff make
Mar 10, 2008 | Admiral 26 cu. ft. Side-By-Side...
Tip
Maytag recalls dishwasher/fires feared from heating element
Maytag is recalling dishwashers for fire hazards including Maytag, Amana, Jenn-Air, Admiral, Magic Chef, Performa by Maytag and Crosley brand dishwashers with plastic tubs and certain serial numbers.
Check these serial numbers to see if you have the dishwasher in question.
Call 1-800-544-5513 if you think you have one.
on Jun 04, 2010 | Dishwashers
MDB7130AWB thermal fuse
This might help. This is the thermal fuse you need if you need a replacement. Cost is somewhere around $25.00
Thermal Fuse
PartSelect Number PS342838
This part is used as a safety device to protect the dishwasher circuit from overload. If the temperature gets to high it will shut off the electrical current to the heating unit in the appliance.
This part works with the following brands: Whirlpool, Admiral, Estate, Inglis, Kenmore, KitchenAid, Roper, Maytag, Kenmore, Admiral, Crosley, Jenn-Air, Hardwick, Magic Chef, Amana, Caloric & Glenwood.
This part fixes the following symptoms:
  • Not drying dishes
  • Will not start
See part 26 in the diagram
Apr 08, 2013 | Maytag 24 in. MDB5600A Jetclean II...
Hello, I have been given an Admiral fridge. I can't seem to see an obvious model Nos but on the back 2 numbers: R134A and GC2227SDFW. Do these mean anything, as we would like to know if there is a...
HI,
The model number you gave was correct. I looked up the model and it does not list a filter, so you can use any in-line filter you find at the local hardware store or home improvement center. Just ask a clerk for a 1/4 in-line filter which should be installed between the water supply (valve on wall or source) to the fridge itself.
Not very expensive or time consuming task to do.
Good Luck
Jul 27, 2011 | Admiral 26 cu. ft. Side-By-Side...
I need to know when my admiral pns24h9 was produced.  It is a 23.6 cubic foot side by side refrigerator.  Any thoughts?
First you will need the Model # & Serial Number off the Tag off the refrigerator.
Admiral was Made by Maytag Corp. now owned by Whirlpool.
This link should help. I would use the Maytag link from this site. This link takes you right to the Maytag Link
Jan 14, 2010 | Refrigerators
What was the year of manufacture for refrigerator model HMG211747
go to this web site servicematters.com you will need the serial number off of your refrig. this is a maytag and whirlpool site but admiral is made by maytag. remember to use the serial number NOT the model number. thanks Peyton
Mar 12, 2009 | Refrigerators
Frig recall which model? Maytag refrigerator MTB2156GE* heard report of recall due to possible fire hazard
Name of product: Maytag®, Jenn-Air®, Amana®, Admiral®, Magic Chef®, Performa by Maytag® and Crosley® brand refrigerators
Units: About 1.6 million
Manufacturer: Maytag Corp., of Newton, Iowa
Hazard: An electrical failure in the relay, the component that turns on the refrigerator’s compressor, can cause overheating and pose a serious fire hazard.
Incidents/Injuries: Maytag has received 41 reports of refrigerator relay ignition, including 16 reports of property damage ranging from smoke damage to extensive kitchen damage.
Description: The recall includes certain Maytag®, Jenn-Air®, Amana®, Admiral®, Magic Chef®, Performa by Maytag® and Crosley® brand side by side and top freezer refrigerators. The affected refrigerators were manufactured in black, bisque, white and stainless steel. They have model and serial numbers printed on a label located on the top middle or left upper side of the refrigerator liner and have the following model and serial number combinations:
Serial Numbers ENDING with AND Model Numbers BEGINNING with Side by Side
Refrigerators AA, AC, AE, AG, AJ, AL, AN, AP, AR,
AT, AV, AX, CA, CC, CE, CG, CJ, CL,
ZB, ZD, ZF, ZH, ZK, ZM, ZQ, ZS, ZU,
ZW, ZY, ZZ ARS, CS, JC, JS, MS, MZ, PS Top Freezer
AT, AV, AX, ZK, ZM, ZQ, ZS, ZU, ZW,
ZY, ZZ AT, CT, MT, PT Refrigerators with freezers on the bottom are not included in this recall.
Sold at: Department and appliance stores and by homebuilders nationwide from January 2001 through January 2004 for between about $350 and $1600.
Manufactured in: United States
Remedy: Consumers should immediately contact Maytag to determine if their refrigerator is included in the recall and to schedule a free in-home repair. Consumers should not return the refrigerator to the retailer where it was purchased.
Consumer Contact: For more information, contact Maytag toll-free at (866) 533-9817 anytime,
Mar 10, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
Water Filter
Open the fridge site, look up at the top right corner, half way to the back, you'll see the filter laying horizontally against the top of the fridge.
Push a button with the arrow to pull down the cover, you'll see the filter.
Twist the filter counter clockwise to remove it. My filter name is Puriclean II. Yours could be different.
Feb 01, 2009 | Admiral 26 cu. ft. Side-By-Side...
Cant find pilot or maqnual
contact whirlpool to get a manual but be sure to give them the model number to get the correct one / whirlpool owns maytag now ,,,,,,,,,, you can even contact a sears service company to order one since the do the maytag service.
Nov 26, 2008 | Maytag 30 in. Admiral LGC1330 Gas Cooktop
Refrigerators Logo
93 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
