Question about Canon CanoScan LiDE 70 Flatbed Scanner
How can I scan and save a 35 mm slide? I can't find instructions any place.
  • Canon Master
  • 739 Answers
Hi
I think the reason you can't find instructions is because (according the Canon Website) this scanner can't do it.
Flatbed scanners that can also scan transparencies have fairly thick lids and usually a power connector going into the lid so that the transpaerncy can be lit from above. The LIDE 700F is the model you need.
Posted on Apr 03, 2011
Does the HP photosmart 2710 scan negative ansd 35mm slides?
This multi function printer/scanner cannot scan 35mm slides and negatives.
Some flat bed scanners with a lighr scource that shines through 35 mm slides and negatives can scan them.
You will be better off getting a dedicated 35 mm slide/negative scanner.
Check out this WEB site foe slide scanners.
http://www.google.com.au/#q=35mm+slide+scanner&hl=en&prmd=imvns&source=univ&tbm=shop&tbo=u&sa=X&ei=dYFIUPKBKMSyiQedl4G4DQ&ved=0CEkQrQQ&bav=on.2,or.r_gc.r_pw.r_qf.&fp=4469b7ccc4340a33&biw=1016&bih=535
Sep 05, 2012 | Epson Office Equipment & Supplies
How can I use my HP6210 officejet scanner to scan 35 mm slides
You cannot scan slides with this scanner.
Slide scanners need a light source that shines through the slide not a reflecting light like your scanner.
Jul 11, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Simply how to use the scanner which does not come with instructions. Many t hanks for your assistance
  • Click Settings > Scan Settings > Button Settings at the bottom of the left pane.
  • Click the Scan Picture Button tab. Under "Scan to" select the program you would like to edit the image with after the scan is finished.
  • Repeat step 2 for the Scan Button, the Scan Document Button and Scan Film Button. Select the program you would like to use to open each type of scan, or select "Save to File" and the desired file type. Select your preferences under the Document or Picture menus based on the type of image or document you will scan most often using this button. Ensure that the "Show Preview" check box is checked for each button type. Click "OK."
  • Place your document or picture on the glass. If scanning film, place the 35 mm negative or slide in the special adapter provided by HP. Select the Scan Picture, Document or Film button depending on what you are scanning. Select the Make Copies button to copy the document or picture directly. Click "Scan" and then "OK" to see the scan preview.
  • Crop your image by clicking the small black boxes at the edges of the selection area. Drag your mouse until the portion of the image you wish to scan is selected. Select the image correction settings in the menu on the right to fix any problems with the picture or document. You may also change the image resolution and resize the image in these menus. When you're finished, click the "Accept" button. If you'd like to scan another image, select "Yes" in the next dialogue box. If not, select "No."
  • Feb 21, 2011 | Office Equipment & Supplies
    Can i scan negertives 35 mm photos
    I looked at the manual and it does not have any references to 35 mm slides scanning.
    The manual:
    http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#BrochuresAndManuals
    Click on this link or copy and paste the complete link into your browser.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    Jan 19, 2011 | Canon PIXMA MX310 All-In-One Printer
    My Epson Perfection 4490 Scanner insists on scanning my 35 mm slides as regular color photos. How can I switch the dscanner to scan my slides as slides?
    Of course that is what it will do. The same as ti will do as a negative. Neither can be printed out other than as a picture.
    Sep 01, 2010 | Epson Perfection 4490 Office Flatbed...
    How do i scan a photo with hp deskjet f340 all in one?
    Place your document or picture on the glass. If scanning film, placethe 35 mm negative or slide in the special adapter provided by HP.Select the Scan Picture, Document or Film button depending on what youare scanning. Select the Make Copies button to copy the document orpicture directly. Click "Scan" and then "OK" to see the scan preview.
    Jan 08, 2010 | HP Deskjet F340 All-In-One Printer
    The 2400 Scanner quit scanning 35 mm slides as the top lid light
    problem in the driver so pls check latested driver in the internet and download it then you problem will solved
    Mar 17, 2009 | Epson Perfection 2400 Photo Flatbed...
    SCANNING SLIDES ON TO PC
    Hi svengoransso - it's not clear what your problem is! Yes, you can scan slides onto a PC using a variety of scanning methods. I use both a flat bed scanner with slide attachment, and a dedicated slide scanner. Do a google search for 35 mm slide scanner - you will get lots of info. If you have a more specific problem than this, please post a new comment explaining the problem as clearly as possible.
    Mar 10, 2009 | Epson Stylus C86 InkJet Printer
    After scanning one photo slide and storing it on my computer, I can't delete this first scan to scan another
    It's not necessary to delete the previous scanned photo. To scan another slide, place it in the scanner and press the PREVIEW button.
    Mar 02, 2009 | Nikon Super Coolscan 4000 ED Film Scanner...
    Scanning 35 mm slides
    SOUNDS LIKE A SOFTWARE CONFLICT.BUT IM NOT SURE
    Jul 28, 2008 | HP Scanjet 4470c Flatbed Scanner
    Canon CanoScan  LiDE 70 Flatbed Scanner Logo
    136 people viewed this question
    old marine
    old marine
