Question about JVC Audio Players & Recorders
I have an old JVC RX-707 VTN that powers up and I hear the click however it has no output at any of the speaker output terminals. I would like to ask is where to start looking to fix it. Thanks..Jim H.
  • Jim H Apr 04, 2011
    Test Post
    Tried exactly as you stated. I do have (distorted) sound from the headphone jack using FM tuner..And intermittent sound thru the "front speaker" jack using the "speaker 1" button on the front of the unit. However all sound is low and distorted and the amp clicks on and off with the speakers hooked up as if the protection circuit is coming on . Any more advice would be very nice.. Thank You !!
    Brigadier General:
  • 8,546 Answers
Start looking at all the indicators and switches that might reveal an unwanted source, tape, mute selection. Does it tune an FM station? THAT would be a good source to use for troubleshooting as it relies on NO external devices or connections. How about headphones?
Posted on Apr 03, 2011
Testimonial: "Thanks fort the quick reply to my post !! Tried what you said !! Moved me forward a bit.. THANKS !! "
  • David Dunn
    David Dunn Apr 04, 2011
    Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
    Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
    You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
    If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
    If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
    Old units suffer from oxidized or corroded contacts which can lead to silence or crackly intermittent sound.
    Everything in the signal path can interefere with good audio, especially the rarely used switches as their contacts never get any physical exercise to wear off the corrosion. Typically, it might be a switch you rarely use, like a Tape Monitor or Mute. It's wise to occasionally (with power OFF) manipulate all manual controls throughput their ranges a number of times to wipe oxides from their contacts or apply spray contact cleaner (Tuner cleaner as we called it in the 60's) to switches if you have access to them.
Have jvc rx-2020v receiver with mono rca out for sub and trying to hook it up with polk audio rm 1000 w sub woofer with +/- terminals for both left ane right channels plus blue terminal(?). How to?
Your Polk Audio subwoofer is a passive sub and your JVC mono output is for connection to a powered sub. If the JVC does not have an amplified output for a passive sub, you'll either need to get an amplified sub, a different receiver, or buy a dedicated mono subwoofer amplifier.
Oct 14, 2016 | JVC Audio Players & Recorders
How to connect a jvc Rx 516v amplifier to a four terminal sub woffer
Connect both speaker outputs from you amplifier to the left and right inputs on your sub woofer. Connect your normal speakers to these connections on the sub woofer.
Mar 04, 2015 | JVC Audio Players & Recorders
JVC rx 817vtn
From experience, a protection circuit has cut in, most likely due to a short in one of the DC output voltage rails on the PSU, thus giving the result of red standby LED, then green, then back to red. If the standby LED is not flashing/blinking, chances are you won't see any error codes.
This unit consists of several surface-mounted components, transistors, diodes, capacitors and resistors (many of which are miniature and often glued to the PCB) - this could become very costly, just in replacing modules as opposed to individual parts and spending hours fault-tracing looking for the problem which could cost a lot more in terms of labour.
I would recommend that you get a second opinion - take it to a service centre, obtain a quote for the estimated cost of repair (and fault diagnosis at the same time) - then you can make a decision after that.
It's up to you but before spending ANY money on it, throwing it out, or selling it somewhere as is, or whatever, get that second opinion from an authorized service workshop first. See how you go. *Nothing is impossible to fix, some things are complex.*
Aug 24, 2013 | JVC Audio Players & Recorders
I turn the power on to my RX-318 and a few seconds later it sounds like something else is kicking on....then I dont hear any sound from my speakers. I dont know if theres a fuse blown, the amp is going out...
Sounds like the automatic circuit protection. Check to make sure you have good speakers and NO shorted wires to them. Too many spearkers conected to the outputs will cause the same problem.
Sep 12, 2011 | JVC RX-318 Receiver
I have a JVC RX618V stereo receiver which is about 20 years old that suddenly is not outputting a stereo signal. Any idea what the problem could be?
Please clarify. No "stereo" output or no output, period?
What source(s). Try FM.
Is Tape Monitor On? Turn it Off.
Speakers On or Off?
Jun 26, 2010 | JVC RX-618V Receiver
JVC Receiver RX-6040B turns it self off after 10 seconds
the amplifier is seeing a short,or the internal components like one of the output ic are causing dc to show at the speaker terminals.the speaker protect is causing it to shut down.
May 14, 2009 | JVC RX-6040 Receiver
JVC RX-9010VBK receiver - premap section won't turn on normally
It sound like a bad connection. The first thing that I would do is tighten all the ground screws that hold the circiut boards and the heat sink to the chassis. If that doen't fix it, flex the circuit boards slighty to see if the relays chick on and off (disconnect the speakers first). It could be on the input board, on the relays themselves or just about anywhere.
Feb 01, 2009 | JVC RX-9010V Receiver
Speaker wire for subwoofer
Usually, a subwoofer will have its own built-in power amplifier. Thus, it will be designed to plug into a standard RCA jack (the type used for DVD players, etc). rather than having wires to connect to a speaker terminal block. Look for a jack on the back of the receiver called "Subwoofer", or simply "SW". If your subwoofer has 2 single wires, it WON'T work with your reveiver's subwoofer output, as this output only carries a line-level signal and is not amplified. You would need a separate power amplifier for this type of SW. If your SW speaker has a DVD-type plug, it should work fine with the receiver's SW output jack.
Jan 02, 2009 | JVC RX-554V Receiver
No output to speakers
Yes inside should be 2 for the speakers and phen a power fuse
Dec 16, 2008 | JVC RX-318 Receiver
635 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
