Question about Philips PET941D/37 9 in. Portable DVD Player with Screen
Battery won't charge on my philips pet941d/37b portable dvd player
Shilon
  • 104 Answers
SOURCE: Insignia PD10135 Portable DVD Player Battery won't work
It sounds like your battery is dead. Maybe yuo should consider replacing the battery in a new one.
Posted on Apr 05, 2007
  • 3 Answers
SOURCE: Need replacement battery
http://www.1800customersupport.com/products.aspx?type=pad&view=107&p=71&sc=5
that link will take you to buy a replacement for 28.00. It may seem like a lot but its worth it in the long run.
Posted on Mar 15, 2008
  • 303 Answers
SOURCE: craig portable dvd player
You can buy a new one by clicking on the hyperlink:
buy replacement ac adapter power charger cord for Criag portable dvd player
Posted on Mar 05, 2009
SOURCE: Philips Portable DVD Player PET 730/98 Unlock Code Needed!
Philips PET730/05
Using remote control
Setup
Down arrow
Down arrow
Right arrow
212225 (you won't see anything!)
Left arrow
Down arrow
should now show region code box
Enter 0
Setup to save
Posted on Apr 09, 2009
  • 814 Answers
SOURCE: dvd player will not reconize a dvd when trying to play
Try cleaning the dvd compartment of all dust and debris with a can of compressed air. Check and make sure all the dust and debris is cleared of the laser transport and lens. Use cotton swabs and small amount of isopropyl alcohol to clean off the laser lens and tracks and gears of the transport . Use a cotton swab with a small amount of alcohol on the tip to clean the laser lens. Rub the swab gently across the lens, until it appear bright and shines. Use the other side of the swab to remove any excess moisture from the lens. Use cotton swabs to clean the rails and gear of transport. Applie small amounts of alcohol to the tips to loosen caked on dust or dirt. Use compressed air again to clear the dust and debris from transport area. After the through cleaning. Try the player again, using a dvd to see if the operation returns to normal. If not, try resetting the dvd player to factory setting. You can do this using the on screen menu to go into the settings. Use the remote control and press the settings button. Use the up and down arrows to highlight the preferences section and press enter. Once in the sub-menu use the up and down arrows to highlight the default function and press enter. This will have reset the dvd player to the factory settings. Now try using a dvd to test the player to see if it operates normally. If it does not play normally, you may have a proplem with the spindel, check it to make sure its is making good contact with motor, if it appears loose, applie a drop of super glue to snug up the grip. After it dries completely. Test the player again with a dvd. If the unit still fails to operate normally, you may be having problems with either the drive motor or the power supply circuits. For these problems you need to contact a service center. They will have all the service information to troubleshoot these problems properly. You can call Phillips customer support at this telephone number 1-888-744-5477. They will be able to tell you how to get the dvd player tested and serviced. I hope this information helps you with your problem.
Posted on Jun 01, 2009
DC2017 PORTABLE DVD PLAYER WILL NOT CHARGE
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 14, 2012 | Audiovox D2017 10.2" Portable Widescreen...
PET941D/37 won't load dvd says no disc
Some DVD players are proprietary. See if it will play in other devices. If it is a burned copy the player may not like that brand of DVD.
Apr 23, 2012 | Philips PET941D/37 9 in. Portable DVD...
Dvd won't load model pet941d/37
The laser pickup overtime becomes weaker until it can no longer read the disc. Take some rubbing alcohol and a Q-Tip and gently clean the lens, allow several minutes to dry, if no change! the whole assembly needs to be replaced, not cost effective to repair.
Battery won't hold charge Protron PFV-288 portable dvd player
Tries websites like Partstore.com,Amazon.com,Ebay.com to buy another new battery or a compatible one for the replacement.
Jun 13, 2011 | Protron PDV-288 7" LCD Portable DVD Player
I have a philips portable dvd player, modet PET941D37. I've had it for less than 1 year and the disc spinner in not working properly...where can I get it looked at. I live in pittsburgh, pa
rtr2,
The Phillips website say to contact customer support if less than a year old. Please copy and paste the link below or call: 1-888-744-5477
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?tmplt=ePlatform%20-%20Philips&scy=US&slg=AEN&sct=PORTABLE_DVD_PLAYERS_SU&cat=PORT_TV_DVD_CA&session=20110306203746_71.98.167.73&grp=SOUND_AND_VISION_GR&ctn=PET941D/37&mid=Link_HTS_US-SOUND_AND_VISION-OTHER&mode=iframe
Please rate this answer if I was able to help.
Thanks,
Chris-
Mar 07, 2011 | Philips Televison & Video
Philips Portable DVD Player Battery will not charge Where can I get it repaired@
Actually its a lithium battery. All you have to do is open up the back, take the battery holder / battery out and take that to a store with you to have it replaced. :)
Nov 13, 2008 | Philips Televison & Video
Portable DVD Player will not power up
This player should be charged up until the green light goes out to be fully charged. I usually leave them on over night.
Glenn
Mar 16, 2008 | Philips DCP855/37 Portable DVD Player
Philips PET941D/37 9 in. Portable DVD Player with Screen Logo
246 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
