Question about Nintendo Wii Fit for Wii
Wii fit board blinks but will not connect, brand new first time using with new batteries
You need to press the red sync button located inside the battery panel with the power on. Then turn board over and let it connect to the console.
Posted on Apr 03, 2011
How to connect wii fit board to the wii
Important Note!
Do Not use "One-Time Mode" sync.
Syncing can be completed only if a compatible game disc is running in the console.The Wii Balance Board may need to be synced to each compatible game individually.Some games may require you to go into a specific screen to sync the Wii Balance Board.These sync settings will be saved even after the console is turned off.
1. Insert a Wii Balance Board compatible game disc in the Wii console.
2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game.3. Open the SD Card slot cover on the front of the Wii console.4. Remove the Battery Cover on the bottom of the Wii Balance Board.
5. Press and release the SYNC button on the Wii Balance Board. The Power LED on the board will start blinking.
6. Press and release the SYNC button on the console while the Power LED on the board is still blinking.
7. The Power LED will stop blinking and light steadily once the synchronization is complete.8. Replace the battery cover and return the board to the normal operating position.
Nov 16, 2011 | Nintendo Wii Fit for Wii
The wii fit game is telling me to push the power button on the balance board with my foot. It blinks blue and that's it. The batteries are fine. So what do I do?
You need to sync the balance board with the Wii. It's easy to do and takes 10 seconds.
1) Start Wii Fit.
2) When it asks you to push the power button as you're describing, open the SD card slot on the front of the Wii and observe the red button.
3) Now, flip over the balance board. Remove the battery cover on the bottom of it, and press the red button beside the batteries, and the blue light should start to blink.
4) While the blue light on the balance board is still blinking, quickly press the red button on the Wii. If they are both blinking at the same time, they should be syncing to each other.
5) Your Wii Fit Balance Board should now be synced with your Wii! If it has been synced successfully, you will no longer need to sync it, and should now automatically connect when the button is pressed with your foot.
Apr 09, 2011 | Nintendo Wii Fit for Wii
Wii board
Make sure that you have synced the board to the wii (similar to a controller). You have to take the battery cover off the board and push the sync button. The blue light will start flashing. From there you need to open the front cover of your wii under the power button.
From there you start up wii fit and it will prompt you to turn on your board. You should get a solid blue light. If you don't, you may need to try syncing again.
Jan 04, 2010 | Nintendo Wii Fit for Wii
How do i fix my Wii Fit so it will turn on?
try pressing the red butten on the wi console and then take the wii fit board and open the part where you put the batteries in and press that little red butten on the side and it should work:)
Nov 07, 2009 | Nintendo Wii Fit - Balance Board + Game...
Balance board on wii fit doesn't turn on? power light flashes
All i had to do was SYNCHRO the board by pressing the synchro button on the wii balance board were the battries go, the power LED will blink (note once the power LED has started blinking, stop pressing the synchro button)
THen you need to press the synchro button on the wii console, while the wii balance board's power LED is blinking
Oct 17, 2009 | Nintendo Video Game Consoles & Games
My wi power source just quit
Guest: Rechargable batteries are only 1.2 V each. You should get up to 4.8 V.
I highly suggest running your Wii Fit on nothing other than Alkaline batteries. I've had my Wii Fit for over 3 months and still use the original batteries.
If you feel like you need rechargables, that's fine, but I recommend a quality set of regular AA rechargable batteries that comes with a quick charger (IE: 1-hour). Stick to the same brand of batteries and buy enough for each Wii-Mote, Wireless Guitar, Wii Fit Balance Board, etc.
Amy - Keep in mind that your Wii Fit balance board will ONLY turn on when your program (ie: Wii Fit) is loaded and ready to go. Since the balance board takes up one of the four available Wii-Mote channels, make sure all but one Wii-Mote is turned off before starting Wii-Fit.
Apr 29, 2009 | Nintendo Wii Fit for Wii
Wii Fit board not staying on
Best suggestion is to make sure the game is fully loaded before pressing the power button.
If it's not working, make sure you press the red sync button on the Wii Fit Balance Board AND the Wii Console.
I know you tried new batteries, but make sure they are really NEW batteries (My experience is that the alkalines work best).
If it still doesn't work, then you may need to contact Nintendo direct.
Apr 08, 2009 | Nintendo Wii Fit for Wii
Wii fit board blinking
Did you try pushing and holding sync on the wii and the board? that should work
Mar 13, 2009 | Nintendo Wii Fit for Wii
Power
    Try these steps!
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
Sep 09, 2008 | Nintendo Wii Fit for Wii
Nintendo Wii Fit for Wii Logo
157 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
