Question about RCA HD52W59 HDTV Projection Television
Need to perform a convergence on my tv can not seem to find the buton
  • RCA Master
  • 3,459 Answers
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
need
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
578ba6c.jpgTV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 15, 2011
Picture not in focus
Devices: All projection TV's (HD or analog), especially Samsung
If its a Samsung HCN653W (or similar model), the first thing to try is the menu option named "Magic Focus", which tunes the set's focus.
Otherwise, it sounds like a job for a convergence. Perform a convergence procedure on your TV, and if the problem recurs within a few days/weeks, then your TV's 'convergence amplifier' board (aka "convergence amp board") is starting to fail.
This board may fail completely, in which case, your convergence procedure will fail to improve the picture.
A "convergence procedure" can be performed entirely by just using the appropriate setup menu option and your remote control.
This board may partially fail, in which case your convergence procedure will properly converge the Red, Blue, Green colors on just part of the screen, whereas a properly functioning convergence amp board will allow complete convergence of the colors across the entire screen.
Your TV's convergence procedure instructions will be found in your TV's Owners Manual.
At least one Projection TV manufacturer recommends that the consumer perform a convergence procedure every 30 days, but most TV owners find that excessive, and might only do one when (a) there's an evident color convergence problem in any part of the picture, or (b) once every 3-6 months.
How-to video: www.youtube.com/watch?v=esk4nYZKFcg
how-to instructions: www.ehow.com/how_2034880_perform-convergence--tv.html
cost to you: $zero
If the convergence amp board is bad, cost for a service call would be $300 (USD) plus $100 for a new board plus 50% markup on parts = about $450 (USD)
Cost to order a new board online: about $100 (USD) + shipping + sales tax.
Alternatively, if you can solder/desolder STK's (Power Amplifier Integrated Circuits), one can repair a convergence amp board for as little as $30 (USD) or so.
Dec 04, 2011 | Sony Televison & Video
Tip
"double vision" caused by bad solder points on convergence chips (check before...
Before you order new convergence chips to try to fix the double vision or 3D look on your tv check the solder points for the chips. If you are able to smack the side of the tv or tap the heat sink for the chips and it corrects the problem than chances are the chips are fine butone or more of the solder points are bad. When I looked at the joints for the chips I noticed hairline cracks around the base of the joint. Re-soldering the joints for the convergence chips solved my problem.
on Jun 02, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Mitsubishi rear projection picture that has a blue/green tint
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then yourconvergence is broken and needs to be repaired.
  • Screen looks 3D
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
What you will need to do is convergence. You can get a repair kit fromTvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Dec 01, 2011 | Sony Televison & Video
Colors are separated, double vision in lower right corner.
Oh, yea - another misaligned projection TV. All rear projection TV's seem to eventually get this disease.
Fix: perform a "convergence," which will converge all 3 color projectors to the same point.
Dec 11, 2010 | Sony KP-53XBR200 53" Rear Projection...
Screen looks distorted when on, what should i do?
Tried push the FOCUS buton on the remote or tried convergence aligment,R,G,B colors lines don't lines up,picture have colors shadows or 3D pictures?The tv have a convergence pronlems,it dead.The tv convergence board is dead.Try website like Tvrepairworld.com to buy a whole convergence board for the replacement.The AKAI/SAMSUNG tvs are using the same convergence board.
Sep 22, 2010 | Samsung PCL6215R 62" Rear Projection...
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Convergence wont align on Magnavox 51MP392H/17
You will need the original remote to perform a convergence touch up on Magnavox TV sets. If you are using the original remote - but still can't get it working - go back to the site where you purchased the tv repair kit and ask for their help
Feb 06, 2010 | Philips Magnavox 51MP392H Rear Projection...
Iqc60h95w zenith=hitachi i can set up convergence but when i press swits on the main board to retorne the picture the convergence wont stay on memory.witch butons on the remote i have to press before press...
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 01, 2010 | Zenith IQC60H95W 60" Rear Projection...
52"projection tv colors overlap
Your convergence is bad. If after trying the Auto Convergence option on the TV it doesn't correct itself, you can try manually adjusting the convergence Here is a link to perform a manual convergence on your set. Good luck!
Greg
http://www.ehow.com/how_2034880_perform-convergence--tv.html
May 23, 2009 | RCA Televison & Video
Phillips 55pp9527/79 convergence
Two things may have happened. First you may just need to degauss the CRTS. Let me explain when you move your TV you often cut across flux lines (magnetic lines of force) these have then tendency to magnetize your screen mask (a metal component in the CRT that slows down electrons) and cause what is sometimes misdiagnosed as a convergence problem. All that has to take place is a once over with a degaussing coil and the problem is fixed. The other thing that could have happened is the your convergence correction amplifiers have gone bad. This will require that you replace both modules (STK392-110). If you have a background in electronics you can perform these tasks, however if you don not have a background in electronics, I would suggest that you contact a qualified TV repair shop to service your TV set.
I hope this helps,
Thank You,
Shuttle83
Oct 18, 2007 | Philips Magnavox 9P6034C 60" Rear...
RCA HD52W59 HDTV Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
