Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424
Tempeature control panel
The digital temperature control is fluctuating between -2 to -6 and cannot be reset
  • 639 Answers
Hi Robert,
Happy to help.
If the unit is ten years old or more, buy a new one and save a lot of money on electricity!!!!!!!!
OR
If you call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Posted on Aug 25, 2008
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    www.samsung.com/sa_en/support/skp/faq/239315
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    https://www.youtube.com/watch?v=DFzTGKVo79g
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 | Freezers
Setting the controls
These are computer run items now. If you unplug it for 2 or 3 minutes does it reset itself? If not try pressing refrigerator an ice buttons together. If that does not work the evaporator fan or control panel needs to be replaced. That about all one can do these days other than keeping the air ways clean so fan is clear. But ecen that will not stop these voltage spikes on the line from ruining good appliances.
Jan 29, 2015 | Kenmore 27.6 cu. ft. French-Door...
Why is the temperature fluctuating.
Service engeener always checks the average temperature inside freezer or refrigerator compartment. When you turn on freezer, the compressor starts to circulate gas through the system and the temperature in the freezer is decreasing (go to minus). When inside of the freezer reaches the set temperature the compressor is switched off and temperature will increasing. What will be the difference of inside temperature depends on the type of refrigerator and type of thermostat or sensor and moves to max. 8-9 degrees. With the advent of new "No Frost" refrigerator, this difference was reduced to only a few degrees Celsius, thanks to the fan inside the refrigerator and NTC sensor.
So 29 + 14 = 43; 43/2 = 21.5 which means that your average temperature of -21.5 which is not too much deviation from the set temperature of -18 and I think that is ok.
Dado
Jun 13, 2014 | AEG 10.35 cu. ft. / 293 liter Upright...
Freezer reset button
Hello Stella, based on the symptoms you are describing it sounds like the temperature control is in the OFF position. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Did you try activating the freezer by pressing the UP arrow until display shows "4" or desired setting and allowing 24 hours for temperature to stabilize? For future reference you can lock the control to keep from accidently changing the temperature setting. If so, I recommended resetting the unit by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes, then turn the freezer on and redo the previous steps. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Aug 05, 2013 | Frigidaire Freezers
Lffh21f7hwa
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My freezer keep running all the time...meet and everything frozen but will not cut out. cannot find a dial inside to turn down.is it behind.
dear sir /madam
please find the thermostat setting controller in your freezer,s inside of door and on the control panel after make reset it on correct temperature .
i hope after that it will work with temperature setting.
hope answer the question
thank you
please vote!
Aug 18, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
FREEZER TEMPERATURE UNSTABLE
if assited check air circulation within cabinet.
check condenser if air assited, clear and clean if necessary.
failing that air probe might be dodgey
condenser fan ?
or thermal over load on compressor
Feb 19, 2008 | Freezers
Cannot control internal temp plus clicking relay on control panel.
Where is the fast defrost button on Kenmore chest freezers?
Nov 20, 2007 | Freezers
Fluctuating temperature..
could be a freon leak check condensor lines were you see the oil if lines have oil on them then it is leaking slowly and you need system work
Aug 26, 2007 | Turbo Air 49 cu. ft. / 1388 liter...
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424 Logo
54 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
