Question about ViewSonic N2751W 27 in. LCD Television
The tv had no power so I put a fuse in where the power cord is and it fries out when I plug it in. Its the same fuse that came out of there. Is there a - & + to the fuse.? thank you
    Scholar:
  • 67 Answers
There is no positive or negative polarity to a fuse. A fuse is just an in circuit protective device designed to blow when there is excessive current flow. A shorting transitor, coil or numerous other components in the power supply circuitry can cause this. Take power supply to television store, this will save you a fee from them having to come out, and have them diagnose the power supply, which they are good at. You might want to consider going online and ordering a new power supply.
Posted on Apr 03, 2011
Coleman Lantern TV #D269 appears to be DOA
If it doesn't work with batteries, and the correct power cord is being used, then it's fried. Try wiggling the lantern end of the plug slowly, to put it in a bind at each end. As long As it's turned on, you should see some sign of life if it's not fried. The plug shouldn't move much, but if it moves, the solder points inside of the lantern to the circuit board could be broken off. If none of that works, it's fried.
Oct 15, 2017 | Cars & Trucks
Www magnavox com usasupport
fried power supply board replace it but first check power cord if ok check the fuse in the plug for the inside of the tv u will need the tech
Jul 07, 2013 | Televison & Video
How do I find the power board in a 1997 big screen Sony TV to check the fuse? How do I check the fuse? I live in a house built in the 1890's, and last year there were 2 different tornados ,within 2...
With it unplugged remove the rear cover and follow the power cord inside the set to the power supply board===the cord goes directly to the line fuse which in a set of that age will be in a plug in holder----look to see if strand of metal in middle is broken or even blackened.
Amperage will be marked on end of such a fuse--my guess is 6.3 amps but there will also be a marking on the board with the value.
May 24, 2012 | Sony Televison & Video
Can't turn on/off using either switch on front or remote. was plugged into outlet on cable set-top box. perhaps something was fried by sudden power outage.
In that case if ther is no power you better check first the power in the outlet they have.Then check the continuity of AC cord of the TV.If they are good,check the fuse,located inside at the power supply section near the AC supply voltage input.Replace same value of fuse if busted.Then try to turn on again..Try this procedure,hope will it help you..Thanks..
Aug 26, 2011 | Toshiba MD20FN3 20 in. TV/DVD Combo
LG47LH30 lightning took out several appliances. TV won't turn on or any lights at all - acts as if it is not plugged in. Should I even try to fix? Are there interior fuses?
The lightning has fried at least the power source of the tv. Even if you you replace the source there are big chances that other components/boards have been also damaged.
There is nothing you can do to it, take it to a repair shop to have it diagnosed professionally.
Jul 03, 2011 | LG 47LH3000 LCD TV
No power coming through even red light won't come on tried different cords. That didn't work either. And we had the tv on a surge strip along with the computer and it is fine.
Try plugging the tv in a different outlet in the strip. Maybe the outlet it was plugged in during the surge got fried. I would bet thought the fuse on the power supply has blown and needs replaced. You will have to take the back cover off of the tv to find the power supply. Good Luck!!!! Hope this helps.
Mar 08, 2010 | Protron PLTV-32 Television
Hi i have a ploblem i bought this proscan lcd 19inch tv a year ago now it doest turn on
Unfortunately, many new electronics are made cheaper nowdays and the power supplys do burn out quickly. It should be tested with voltmeter to determine if it needs to be fixed or replaced. The power supplies have capacitors and resistors in them that tend to fry out.
Aug 28, 2009 | Televison & Video
1800HG Gateway Router, no power light
no fuse, the system just may be fried. try the reset button located on the bottom of the unit if no reaction router is dead.
Jul 10, 2009 | 2wire 1800HG Router (RG1800HG00)
Ps3 has no power
Well I think your house might have killed the PS3. I would recommend talking to an electrician about what happened.
You can try using a different TV and see what happens. However...
Unfortunately the PS3 is pretty much dead now. Hopefully its still under some kind of warranty or can still be returned (tell them it won't turn on). To replace the parts needed would require precise installment and should only be done by professionals.
Sorry for the death of the PS3.
Don't forget to rate :)
Apr 08, 2009 | Sony PS3 40GB Best Sellers Bundle Console
Power outage fried my TV
Usually,the AC fuse is located by following the AC cord into the tv and the culprit will be close to where the cord attaches.Note:if the replacement fuse blows,then additional parts need to be changed.
Sep 30, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
ViewSonic N2751W 27 in. LCD Television Logo
69 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
